Maxior02 Napisano Czerwiec 3, 2011 Zgłoszenie Share Napisano Czerwiec 3, 2011 Witam;] Otóż mam taki problem, gdy chcę sobie zaktualizować system Fedora 15 wpisuję komendę yum update i wtedy pobiera informację o aktualizacji i konsola wyrzuca mi o to takie błędy: [Maxior@Computer-first ~]$ su - Hasło: [root@Computer-first ~]# yum update Loaded plugins: fastestmirror, langpacks, presto, refresh-packagekit Loading mirror speeds from cached hostfile updates/metalink | 23 kB 00:00 * fedora: ftp.icm.edu.pl * rpmfusion-free: ftp.icm.edu.pl * rpmfusion-free-updates: ftp.icm.edu.pl * rpmfusion-nonfree: ftp.icm.edu.pl * rpmfusion-nonfree-updates: ftp.icm.edu.pl * updates: ftp.icm.edu.pl fedora-chromium | 3.4 kB 00:00 google-chrome | 951 B 00:00 google-chrome/primary | 1.5 kB 00:00 rpmfusion-free-updates | 2.7 kB 00:00 rpmfusion-nonfree-updates | 2.7 kB 00:00 updates | 4.7 kB 00:00 updates/primary_db | 1.2 MB 00:09 updates/group | 1.8 MB 00:15 google-chrome 3/3 Setting up Update Process Resolving Dependencies --> Running transaction check ---> Package NetworkManager.i686 1:0.8.999-3.git20110526.fc15 will be updated ---> Package NetworkManager.i686 1:0.8.9997-1.git20110531.fc15 will be an update ---> Package NetworkManager-glib.i686 1:0.8.999-3.git20110526.fc15 will be updated ---> Package NetworkManager-glib.i686 1:0.8.9997-1.git20110531.fc15 will be an update ---> Package NetworkManager-gnome.i686 1:0.8.999-3.git20110526.fc15 will be updated ---> Package NetworkManager-gnome.i686 1:0.8.9997-1.git20110531.fc15 will be an update ---> Package bind-libs.i686 32:9.8.0-3.P1.fc15 will be updated ---> Package bind-libs.i686 32:9.8.0-5.P2.fc15 will be an update ---> Package bind-libs-lite.i686 32:9.8.0-3.P1.fc15 will be updated ---> Package bind-libs-lite.i686 32:9.8.0-5.P2.fc15 will be an update ---> Package bind-license.noarch 32:9.8.0-3.P1.fc15 will be updated ---> Package bind-license.noarch 32:9.8.0-5.P2.fc15 will be an update ---> Package bind-utils.i686 32:9.8.0-3.P1.fc15 will be updated ---> Package bind-utils.i686 32:9.8.0-5.P2.fc15 will be an update ---> Package evolution.i686 0:3.0.1-1.fc15 will be updated ---> Package evolution.i686 0:3.0.2-1.fc15 will be an update ---> Package evolution-NetworkManager.i686 0:3.0.1-1.fc15 will be updated ---> Package evolution-NetworkManager.i686 0:3.0.2-1.fc15 will be an update ---> Package evolution-data-server.i686 0:3.0.1-1.fc15 will be updated ---> Package evolution-data-server.i686 0:3.0.2-1.fc15 will be an update ---> Package gnome-dvb-daemon.i686 0:0.2.0-1.fc15 will be updated ---> Package gnome-dvb-daemon.i686 0:0.2.1-1.fc15 will be an update ---> Package gnome-settings-daemon.i686 0:3.0.1-4.fc15 will be updated ---> Package gnome-settings-daemon.i686 0:3.0.1-6.fc15 will be an update ---> Package js.i686 0:1.70-13.fc15 will be updated --> Processing Dependency: libjs.so.1 for package: avidemux-qt-2.5.4-8.fc15.i686 --> Processing Dependency: libjs.so.1 for package: avidemux-cli-2.5.4-8.fc15.i686 --> Processing Dependency: libjs.so.1 for package: avidemux-gtk-2.5.4-8.fc15.i686 ---> Package js.i686 1:1.8.5-4.fc15 will be an update ---> Package libcgroup.i686 0:0.37.1-2.fc15 will be updated ---> Package libcgroup.i686 0:0.37.1-3.fc15 will be an update ---> Package parted.i686 0:2.3-8.fc15 will be updated ---> Package parted.i686 0:2.3-9.fc15 will be an update ---> Package selinux-policy.noarch 0:3.9.16-24.fc15 will be updated ---> Package selinux-policy.noarch 0:3.9.16-26.fc15 will be an update ---> Package selinux-policy-targeted.noarch 0:3.9.16-24.fc15 will be updated ---> Package selinux-policy-targeted.noarch 0:3.9.16-26.fc15 will be an update ---> Package setroubleshoot.i686 0:3.0.31-1.fc15 will be updated ---> Package setroubleshoot.i686 0:3.0.35-1.fc15 will be an update ---> Package setroubleshoot-server.i686 0:3.0.31-1.fc15 will be updated ---> Package setroubleshoot-server.i686 0:3.0.35-1.fc15 will be an update ---> Package shotwell.i686 0:0.9.2-1.fc15 will be updated ---> Package shotwell.i686 0:0.9.3-1.fc15 will be an update ---> Package xorg-x11-server-Xephyr.i686 0:1.10.1-14.fc15 will be updated ---> Package xorg-x11-server-Xephyr.i686 0:1.10.2-1.fc15 will be an update ---> Package xorg-x11-server-Xorg.i686 0:1.10.1-14.fc15 will be updated ---> Package xorg-x11-server-Xorg.i686 0:1.10.2-1.fc15 will be an update ---> Package xorg-x11-server-common.i686 0:1.10.1-14.fc15 will be updated ---> Package xorg-x11-server-common.i686 0:1.10.2-1.fc15 will be an update --> Finished Dependency Resolution Error: Package: avidemux-cli-2.5.4-8.fc15.i686 (@rpmfusion-free) Requires: libjs.so.1 Removing: js-1.70-13.fc15.i686 (@fedora) libjs.so.1 Updated By: 1:js-1.8.5-4.fc15.i686 (updates) Not found Error: Package: avidemux-qt-2.5.4-8.fc15.i686 (@rpmfusion-free) Requires: libjs.so.1 Removing: js-1.70-13.fc15.i686 (@fedora) libjs.so.1 Updated By: 1:js-1.8.5-4.fc15.i686 (updates) Not found Error: Package: avidemux-gtk-2.5.4-8.fc15.i686 (@rpmfusion-free) Requires: libjs.so.1 Removing: js-1.70-13.fc15.i686 (@fedora) libjs.so.1 Updated By: 1:js-1.8.5-4.fc15.i686 (updates) Not found You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest [root@Computer-first ~]# Co mogę zrobić żeby to naprawić ? Proszę o pomoc i wyrozumiałość. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
jjj Napisano Czerwiec 3, 2011 Zgłoszenie Share Napisano Czerwiec 3, 2011 Poczekaj na nowsze wersje pakietów w rpmfusion. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Maxior02 Napisano Czerwiec 3, 2011 Autor Zgłoszenie Share Napisano Czerwiec 3, 2011 Czyli na razie nic się nie da z tym zrobić ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Czerwiec 3, 2011 Zgłoszenie Share Napisano Czerwiec 3, 2011 Jak dasz --skip-broken to masz duza szanse, ze avidemux sie nie uruchomi, bo bedzie brakowalo mu bibliotek. Wtedy mozesz zrobic link symboliczny na libjs.so.1, ale nie wiem czy to pomoze. Mozliwe, ze trzeba przekompilowac program z nowym js. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
jjj Napisano Czerwiec 3, 2011 Zgłoszenie Share Napisano Czerwiec 3, 2011 Jak już nie możesz wytrzymać, to yum update -x js* Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Maxior02 Napisano Czerwiec 3, 2011 Autor Zgłoszenie Share Napisano Czerwiec 3, 2011 Rozumiem, dzięki za pomoc i wyrozumiałość Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Czerwiec 3, 2011 Zgłoszenie Share Napisano Czerwiec 3, 2011 Na avidemux przyjdzie jeszcze trochę poczekać. Zaktualizuj tak jak pisze jjj. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
takori Napisano Czerwiec 3, 2011 Zgłoszenie Share Napisano Czerwiec 3, 2011 (edytowane) sprawdzilem u mnie jest ok tylko... nic nie idzie przez ftp.icm.edu.pl ... wiec moze to problem mirror (?) Ops nie doczytalem - sprawdzilem odruchowo, bo nie mialem nijakich error ostatnio. (sorry) - mam inna wersje Edytowane Czerwiec 3, 2011 przez takori Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Czerwiec 3, 2011 Zgłoszenie Share Napisano Czerwiec 3, 2011 A co robi parametr -x? Nie mogę sprawdzić, bo nie mam fedory, a na sieci są jakieś stare manuale chyba, które nie zawierają opisu takiego parametru. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Czerwiec 3, 2011 Zgłoszenie Share Napisano Czerwiec 3, 2011 -x to pewnie --exclude Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Czerwiec 3, 2011 Zgłoszenie Share Napisano Czerwiec 3, 2011 Aha. W takie razie należy się spodziewać kolejnych konfliktów Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Czerwiec 4, 2011 Zgłoszenie Share Napisano Czerwiec 4, 2011 Paczki potrzebujące js-1.8.5-4 to na początek te. Przebudowa avidemux gładko nie pójdzie link. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Maxior02 Napisano Czerwiec 9, 2011 Autor Zgłoszenie Share Napisano Czerwiec 9, 2011 Problem został rozwiązany, avidemux został zaktualizowany w rpmfusion, i aktualizuję się teraz bez większych problemów. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
