Fedora 16 Nie Działa Gnome Shell
huzar
Witam serdecznie zainstalowałem Fedora 16 obraz dvd.
Gnome shell działał mi normlanie przez live cd a jak tylko zainstalowalem to przełączyło mnie w tryb zastępczy i nic nie moge z tym zrobic :/ Posiadam laptopa Acer Extensa 5220
Na laptopie pisze mi Mobile Intel Graphics Media Accelerator X3100
00:00.0 Host bridge: Intel Corporation Mobile PM965/GM965/GL960 Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (primary) (rev 03)
00:02.1 Display controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (secondary) (rev 03)
00:1a.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 03)
00:1a.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 03)
00:1c.2 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 3 (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 03)
00:1d.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f3)
00:1f.0 ISA bridge: Intel Corporation 82801HEM (ICH8M) LPC Interface Controller (rev 03)
00:1f.1 IDE interface: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 03)
00:1f.2 IDE interface: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) SATA IDE Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 03)
02:00.0 Ethernet controller: Broadcom Corporation NetLink BCM5787M Gigabit Ethernet PCI Express (rev 02)
04:00.0 Ethernet controller: Atheros Communications Inc. AR242x / AR542x Wireless Network Adapter (PCI-Express) (rev 01)
0f:06.0 CardBus bridge: Texas Instruments PCIxx12 Cardbus Controller
0f:06.1 FireWire (IEEE 1394): Texas Instruments PCIxx12 OHCI Compliant IEEE 1394 Host Controller
0f:06.2 Mass storage controller: Texas Instruments 5-in-1 Multimedia Card Reader (SD/MMC/MS/MS PRO/xD)
0f:06.3 SD Host controller: Texas Instruments PCIxx12 SDA Standard Compliant SD Host Controller[/color]
[color=#000000]
Bardziej przydatne pewnie byloby wyjscie polecenia lspci, ale pewnie Intel to Intel, chociaz o ile pamietam, to czasem od chipsetu zalezalo czy cos dziala czy nie.
Sprawdz na dobry poczatek czy masz zainstalowane xorg-x11-drv-intel (pewnie tak) i czy polecenie
glxinfo | grep "direct rendering"
pokazuje "Yes" - moze tylko trzeba przelaczyc sie z trybu zastepczego na normalny (gnome-control-center → Informacje o systemie → Grafika → przelaczyc tak, zeby widziec "I" na niebieskim tle) i potem restart.
Zrobilem tak i nic sie nie zmienilo :/
$ glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
   GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
   GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
   GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
   GLX_SGIX_pbuffer, GLX_MESA_copy_sub_buffer, GLX_INTEL_swap_event
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
   GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
   GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_framebuffer_sRGB,
   GLX_MESA_copy_sub_buffer, GLX_MESA_multithread_makecurrent,
   GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
   GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
   GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
   GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap,
GLX version: 1.4
GLX extensions:
   GLX_MESA_multithread_makecurrent, GLX_OML_swap_method,
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: Gallium 0.4 on llvmpipe
OpenGL version string: 2.1 Mesa 7.11.2
OpenGL shading language version string: 1.20
OpenGL extensions:
   GL_ARB_multisample, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
   GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
   GL_EXT_copy_texture, GL_EXT_polygon_offset, GL_EXT_subtexture,
   GL_EXT_texture_object, GL_EXT_vertex_array, GL_EXT_compiled_vertex_array,
   GL_EXT_texture, GL_EXT_texture3D, GL_IBM_rasterpos_clip,
   GL_ARB_point_parameters, GL_EXT_draw_range_elements, GL_EXT_packed_pixels,
   GL_EXT_point_parameters, GL_EXT_rescale_normal,
   GL_EXT_separate_specular_color, GL_EXT_texture_edge_clamp,
   GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
   GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_ARB_framebuffer_sRGB,
   GL_ARB_multitexture, GL_EXT_framebuffer_sRGB,
   GL_IBM_multimode_draw_arrays, GL_IBM_texture_mirrored_repeat,
   GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_transpose_matrix,
   GL_EXT_blend_func_separate, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
   GL_EXT_secondary_color, GL_EXT_texture_env_add, GL_EXT_texture_lod_bias,
   GL_INGR_blend_func_separate, GL_NV_blend_square, GL_NV_light_max_exponent,
   GL_NV_texgen_reflection, GL_NV_texture_env_combine4,
   GL_SUN_multi_draw_arrays, GL_ARB_texture_border_clamp,
   GL_ARB_texture_compression, GL_EXT_framebuffer_object,
   GL_EXT_texture_env_dot3, GL_MESA_window_pos, GL_NV_packed_depth_stencil,
   GL_NV_texture_rectangle, GL_ARB_depth_texture, GL_ARB_occlusion_query,
   GL_ARB_shadow, GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
   GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
   GL_ARB_window_pos, GL_EXT_stencil_two_side, GL_EXT_texture_cube_map,
   GL_APPLE_packed_pixels, GL_APPLE_vertex_array_object, GL_ARB_draw_buffers,
   GL_ARB_fragment_program, GL_ARB_fragment_shader, GL_ARB_shader_objects,
   GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ATI_draw_buffers,
   GL_ATI_texture_env_combine3, GL_ATI_texture_float, GL_EXT_shadow_funcs,
   GL_EXT_stencil_wrap, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
   GL_NV_primitive_restart, GL_ARB_fragment_program_shadow,
   GL_ARB_half_float_pixel, GL_ARB_occlusion_query2, GL_ARB_point_sprite,
   GL_ARB_shading_language_100, GL_ARB_sync, GL_ARB_texture_non_power_of_two,
   GL_ARB_vertex_buffer_object, GL_ATI_blend_equation_separate,
   GL_EXT_blend_equation_separate, GL_OES_read_format,
   GL_ARB_pixel_buffer_object, GL_ARB_texture_float,
   GL_ARB_texture_rectangle, GL_EXT_pixel_buffer_object,
   GL_EXT_texture_mirror_clamp, GL_EXT_texture_rectangle,
   GL_EXT_texture_sRGB, GL_EXT_texture_shared_exponent,
   GL_ARB_framebuffer_object, GL_EXT_framebuffer_blit,
   GL_EXT_framebuffer_multisample, GL_EXT_packed_depth_stencil,
   GL_ARB_vertex_array_object, GL_ATI_separate_stencil,
   GL_ATI_texture_mirror_once, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
   GL_EXT_gpu_program_parameters, GL_EXT_texture_env_combine,
   GL_EXT_texture_sRGB_decode, GL_OES_EGL_image, GL_ARB_copy_buffer,
   GL_ARB_draw_instanced, GL_ARB_half_float_vertex, GL_ARB_instanced_arrays,
   GL_ARB_map_buffer_range, GL_ARB_texture_rg, GL_ARB_texture_swizzle,
   GL_ARB_vertex_array_bgra, GL_EXT_separate_shader_objects,
   GL_EXT_texture_swizzle, GL_EXT_vertex_array_bgra,
   GL_AMD_draw_buffers_blend, GL_ARB_ES2_compatibility,
   GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
   GL_ARB_explicit_attrib_location, GL_ARB_fragment_coord_conventions,
   GL_ARB_provoking_vertex, GL_ARB_sampler_objects,
   GL_ARB_shader_texture_lod, GL_EXT_provoking_vertex, GL_EXT_texture_snorm,
   GL_MESA_texture_signed_rgba, GL_ARB_robustness
Hmmm... Do tej pory zylem w przeswiadczeniu, ze wystarczy rendering 3D, zeby dzialal gnome-shell.
Sprawdz moze jakie moduly jadra sa zaladowane, gdy uruchamiasz z LiveCD (lsmod) a jakie sa ladowane przy uruchomieniu systemu zainstalowanego na HDD. Moze to cos wyjasni albo chociaz naprowadzi na wlasciwy trop.
No i ew. próba dosc rozpaczliwa :) Zainstaluj System z LiveCD a nie z DVD, skoro z LiveCD dziala. Moze po prostu czegos nie zainstalowales lub zmieniles domyslny zestaw pakietów przy instalacji z DVD?
A moze próbowales doinstalowac jakies rozszerzenia G3?
Czy próbowałeś po prostu wyłączyć tryb zastępczy w ustawieniach? Ustawienia -> info o systemie -> grafika -> cośtam, zapomniałem?
Było...
i dalem przelaczenie na normalny tryb ale nic to nie pomoglo i od razu daje na zastepczy.
Gnome 3 w F15 jest bardzo zabugowane w porównaniu do G3.2 z F16. To nie jest zadne rozwiazanie. Jak juz byles w tym fallback mode to mogles odpalic emulator terminala i jako zwykly uzytkownik wykonac gnome-shell --replace. Nawet jesli nie bedzie dzialac to przynajmniej w dostaniesz na wyjsciu informacje, dlaczego nie dziala. To jest na pewno bug w sterowniku Intel lub Gnome, bo powinno dzialac. Inna sprawa, ze powinienes zaraz po instalacji wykonac pelna aktualizacje systemu nawet w trybie fallback.
