alastis Napisano Styczeń 4, 2018 Zgłoszenie Share Napisano Styczeń 4, 2018 Witam dzisiaj tj. 4 stycznia dostałem aktualizacje systemu i miedzy innymi nowszą wersję jadra czyli 4.14.11 niestety po restarcie komputera moje Xy się już nie uruchomiły a wydając polecenie startx wypluło błąd: [ 201.335] (--) Log file renamed from "/var/log/Xorg.pid-16564.log" to "/var/log/Xorg.0.log" [ 201.336] X.Org X Server 1.19.5 Release Date: 2017-10-12 [ 201.336] X Protocol Version 11, Revision 0 [ 201.336] Build Operating System: 4.12.9-300.fc26.x86_64 [ 201.336] Current Operating System: Linux localhost.localdomain 4.14.11-300.fc27.x86_64 #1 SMP Wed Jan 3 13:52:28 UTC 2018 x86_64 [ 201.336] Kernel command line: BOOT_IMAGE=/vmlinuz-4.14.11-300.fc27.x86_64 root=/dev/mapper/fedora-root ro rd.lvm.lv=fedora/root rd.lvm.lv=fedora/swap rhgb quiet LANG=pl_PL.UTF-8 [ 201.336] Build Date: 12 October 2017 07:35:27PM [ 201.336] Build ID: xorg-x11-server 1.19.5-1.fc27 [ 201.336] Current version of pixman: 0.34.0 [ 201.336] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 201.336] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 201.336] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 4 13:00:40 2018 [ 201.337] (==) Using config file: "/etc/X11/xorg.conf" [ 201.337] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 201.337] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 201.337] (==) ServerLayout "Layout0" [ 201.337] (**) |-->Screen "Screen0" (0) [ 201.337] (**) | |-->Monitor "Monitor0" [ 201.337] (**) | |-->Device "Device0" [ 201.337] (**) |-->Input Device "Keyboard0" [ 201.337] (**) |-->Input Device "Mouse0" [ 201.337] (==) Automatically adding devices [ 201.337] (==) Automatically enabling devices [ 201.337] (==) Automatically adding GPU devices [ 201.337] (==) Automatically binding GPU devices [ 201.337] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 201.337] (==) FontPath set to: catalogue:/etc/X11/fontpath.d, built-ins [ 201.337] (==) ModulePath set to "/usr/lib64/xorg/modules" [ 201.337] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled. [ 201.337] (WW) Disabling Keyboard0 [ 201.337] (WW) Disabling Mouse0 [ 201.337] (II) Loader magic: 0x821e00 [ 201.337] (II) Module ABI versions: [ 201.337] X.Org ANSI C Emulation: 0.4 [ 201.337] X.Org Video Driver: 23.0 [ 201.337] X.Org XInput driver : 24.1 [ 201.337] X.Org Server Extension : 10.0 [ 201.339] (++) using VT number 1 [ 201.342] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c503 [ 201.344] (--) PCI:*(0:1:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xfd000000/16777216, 0xd0000000/268435456, 0xce000000/33554432, I/O @ 0x0000ac00/128, BIOS @ 0x????????/131072 [ 201.344] (II) LoadModule: "glx" [ 201.345] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so [ 201.351] (II) Module glx: vendor="NVIDIA Corporation" [ 201.351] compiled for 4.0.2, module version = 1.0.0 [ 201.351] Module class: X.Org Server Extension [ 201.351] (II) NVIDIA GLX Module 384.98 Thu Oct 26 14:35:55 PDT 2017 [ 201.351] (II) LoadModule: "nvidia" [ 201.351] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so [ 201.352] (II) Module nvidia: vendor="NVIDIA Corporation" [ 201.352] compiled for 4.0.2, module version = 1.0.0 [ 201.352] Module class: X.Org Video Driver [ 201.352] (II) NVIDIA dlloader X Driver 384.98 Thu Oct 26 14:06:45 PDT 2017 [ 201.352] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs [ 201.352] (II) Loading sub module "fb" [ 201.352] (II) LoadModule: "fb" [ 201.352] (II) Loading /usr/lib64/xorg/modules/libfb.so [ 201.352] (II) Module fb: vendor="X.Org Foundation" [ 201.352] compiled for 1.19.5, module version = 1.0.0 [ 201.353] ABI class: X.Org ANSI C Emulation, version 0.4 [ 201.353] (II) Loading sub module "wfb" [ 201.353] (II) LoadModule: "wfb" [ 201.353] (II) Loading /usr/lib64/xorg/modules/libwfb.so [ 201.353] (II) Module wfb: vendor="X.Org Foundation" [ 201.353] compiled for 1.19.5, module version = 1.0.0 [ 201.353] ABI class: X.Org ANSI C Emulation, version 0.4 [ 201.353] (II) Loading sub module "ramdac" [ 201.353] (II) LoadModule: "ramdac" [ 201.353] (II) Module "ramdac" already built-in [ 201.360] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the [ 201.360] (EE) NVIDIA: system's kernel log for additional error messages and [ 201.360] (EE) NVIDIA: consult the NVIDIA README for details. [ 201.360] (EE) No devices detected. [ 201.360] (EE) Fatal server error: [ 201.360] (EE) no screens found(EE) [ 201.360] (EE) Please consult the Fedora Project support at http://wiki.x.org for help. [ 201.360] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information. [ 201.360] (EE) [ 201.361] (EE) Server terminated with error (1). Closing log file. Wygląda na to ze sterowniki nie współpracują z najnowszą wersja kernela Czy spotkaliście się z czymś podobnym? czytałem ze najnowsze aktualizacje jajka i sterowniki Linuksa nie zawsze się lubią. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Styczeń 4, 2018 Zgłoszenie Share Napisano Styczeń 4, 2018 a jaką masz wersję kmod-nvidia? Sprawdzałeś czy moduł już jest w repozytorium Rpmfusion? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
alastis Napisano Styczeń 4, 2018 Autor Zgłoszenie Share Napisano Styczeń 4, 2018 50 minut temu, WalDo napisał: a jaką masz wersję kmod-nvidia? Sprawdzałeś czy moduł już jest w repozytorium Rpmfusion? Nie bardzo się orientuję niestety ponieważ sterowniki instalowałem ze strony nVidia wykorzystując ten poradnik: https://www.if-not-true-then-false.com/2015/fedora-nvidia-guide/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Mentat Napisano Styczeń 4, 2018 Zgłoszenie Share Napisano Styczeń 4, 2018 24 minuty temu, alastis napisał: Nie bardzo się orientuję niestety ponieważ sterowniki instalowałem ze strony nVidia wykorzystując ten poradnik: https://www.if-not-true-then-false.com/2015/fedora-nvidia-guide/ No to zapewne dla każdego jądra musisz instalować osobno. Ta metoda działa chyba tylko na aktualne jądro. Także punkt 2.8... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
alastis Napisano Styczeń 4, 2018 Autor Zgłoszenie Share Napisano Styczeń 4, 2018 16 minut temu, Mentat napisał: No to zapewne dla każdego jądra musisz instalować osobno. Ta metoda działa chyba tylko na aktualne jądro. Także punkt 2.8... Czyli najlepiej by wywalić sterowniki a zainstalować te z repo? Czy po prostu usunąć je i zainstalować tak jak zawsze... tylko hmmm bez sensu instalować co każde aktualizowanie jajka Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Mentat Napisano Styczeń 4, 2018 Zgłoszenie Share Napisano Styczeń 4, 2018 Godzinę temu, alastis napisał: Czyli najlepiej by wywalić sterowniki a zainstalować te z repo? Czy po prostu usunąć je i zainstalować tak jak zawsze... tylko hmmm bez sensu instalować co każde aktualizowanie jajka Kwestia preferencji. Z paczkowanymi raczej mniej zachodu ale czasami też są problemy jak brakuje pakietów dla danego jądra. Zawsze możesz sprawdzić i zobaczyć co Ci bardziej pasuje. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
alastis Napisano Styczeń 4, 2018 Autor Zgłoszenie Share Napisano Styczeń 4, 2018 1 minutę temu, Mentat napisał: Kwestia preferencji. Z paczkowanymi raczej mniej zachodu ale czasami też są problemy jak brakuje pakietów dla danego jądra. Zawsze możesz sprawdzić i zobaczyć co Ci bardziej pasuje. W sumie racja spróbuje, dzięki Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
alastis Napisano Styczeń 5, 2018 Autor Zgłoszenie Share Napisano Styczeń 5, 2018 Niestety poległem, instalacja sterowników ze strony nVidia wywala błąd (ale tylko na najnowszym jajku) a sterowniki z repo się instalują ale Xów nie uruchomię niestety nie sprawdziłem jaki błąd mi wypluwają ale sprawdzę to jutro teraz już trochę za późno. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Styczeń 6, 2018 Zgłoszenie Share Napisano Styczeń 6, 2018 On 4.01.2018 at 10:50 PM, Mentat said: [...] czasami też są problemy jak brakuje pakietów dla danego jądra. [...] Co też można rozwiązać przy pomocy pakietu akmod-nvidia Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
zibi743 Napisano Styczeń 6, 2018 Zgłoszenie Share Napisano Styczeń 6, 2018 12 hours ago, alastis said: Niestety poległem, instalacja sterowników ze strony nVidia wywala błąd (ale tylko na najnowszym jajku) a sterowniki z repo się instalują ale Xów nie uruchomię niestety nie sprawdziłem jaki błąd mi wypluwają ale sprawdzę to jutro teraz już trochę za późno. Może to Ci pomoże. Wybierz sobie przydatne informacje i dopasuj wersję do Twojej karty. pomoc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SeeM Napisano Styczeń 6, 2018 Zgłoszenie Share Napisano Styczeń 6, 2018 Na kernelu 4.14.11-300 już działa, podobnie jak inne zamknięte sterowniki typu wifi broadcoma. Mogę znowu pograć. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
alastis Napisano Styczeń 6, 2018 Autor Zgłoszenie Share Napisano Styczeń 6, 2018 6 godzin temu, zibi743 napisał: Może to Ci pomoże. Wybierz sobie przydatne informacje i dopasuj wersję do Twojej karty. pomoc Niestety strona nie jest dostępna dla mojego konta... 6 godzin temu, SeeM napisał: Na kernelu 4.14.11-300 już działa, podobnie jak inne zamknięte sterowniki typu wifi broadcoma. Mogę znowu pograć. Ciesze się niestety u mnie dalej trudności Tak czy inaczej próbowałem reinstalować sterowniki z strony i pomimo że na 4.14.8-300 wszystko ładnie działa to na 4.14.11-300 instalator wywala mi błędy: A tu zawartość pliku make.log: DKMS make.log for nvidia-384.98 for kernel 4.14.11-300.fc27.x86_64 (x86_64) sob, 6 sty 2018, 18:30:51 GMT make "CC=cc" KBUILD_OUTPUT=/lib/modules/4.14.11-300.fc27.x86_64/build KBUILD_VERBOSE= -C /lib/modules/4.14.11-300.fc27.x86_64/source M=/var/lib/dkms/nvidia/384.98/build ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.14.11-300.fc27.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/4.14.11-300.fc27.x86_64/build NV_KERNEL_MODULES="nvidia nvidia-uvm nvidia-modeset nvidia-drm" INSTALL_MOD_DIR=kernel/drivers/video modules make[1]: Wejście do katalogu '/usr/src/kernels/4.14.11-300.fc27.x86_64' make[2]: Wejście do katalogu '/usr/src/kernels/4.14.11-300.fc27.x86_64' SYMLINK /var/lib/dkms/nvidia/384.98/build/nvidia/nv-kernel.o SYMLINK /var/lib/dkms/nvidia/384.98/build/nvidia-modeset/nv-modeset-kernel.o CONFTEST: remap_pfn_range CONFTEST: INIT_WORK CONFTEST: hash__remap_4k_pfn CONFTEST: follow_pfn CONFTEST: vmap CONFTEST: set_pages_uc CONFTEST: set_memory_uc CONFTEST: set_memory_array_uc CONFTEST: change_page_attr CONFTEST: pci_get_class CONFTEST: pci_choose_state CONFTEST: vm_insert_page CONFTEST: acpi_device_id CONFTEST: acquire_console_sem CONFTEST: kmem_cache_create CONFTEST: console_lock CONFTEST: on_each_cpu CONFTEST: acpi_evaluate_integer CONFTEST: smp_call_function CONFTEST: ioremap_cache CONFTEST: ioremap_wc CONFTEST: acpi_walk_namespace CONFTEST: pci_domain_nr CONFTEST: pci_dma_mapping_error CONFTEST: sg_alloc_table CONFTEST: sg_init_table CONFTEST: pci_get_domain_bus_and_slot CONFTEST: get_num_physpages CONFTEST: efi_enabled CONFTEST: proc_create_data CONFTEST: pde_data CONFTEST: proc_remove CONFTEST: pm_vt_switch_required CONFTEST: xen_ioemu_inject_msi CONFTEST: phys_to_dma CONFTEST: get_dma_ops CONFTEST: write_cr4 CONFTEST: of_get_property CONFTEST: of_find_node_by_phandle CONFTEST: of_node_to_nid CONFTEST: pnv_pci_get_npu_dev CONFTEST: for_each_online_node CONFTEST: node_end_pfn CONFTEST: pci_bus_address CONFTEST: pci_stop_and_remove_bus_device CONFTEST: pci_remove_bus_device CONFTEST: request_threaded_irq CONFTEST: register_cpu_notifier CONFTEST: cpuhp_setup_state CONFTEST: remap_page_range CONFTEST: address_space_init_once CONFTEST: kbasename CONFTEST: fatal_signal_pending CONFTEST: list_cut_position CONFTEST: vzalloc CONFTEST: wait_on_bit_lock_argument_count CONFTEST: bitmap_clear CONFTEST: usleep_range CONFTEST: radix_tree_empty CONFTEST: drm_dev_unref CONFTEST: drm_reinit_primary_mode_group CONFTEST: drm_atomic_set_mode_for_crtc CONFTEST: drm_atomic_clean_old_fb CONFTEST: get_user_pages_remote CONFTEST: drm_gem_object_lookup CONFTEST: drm_atomic_state_free CONFTEST: drm_driver_has_gem_prime_res_obj CONFTEST: is_export_symbol_gpl_of_node_to_nid CONFTEST: i2c_adapter CONFTEST: pm_message_t CONFTEST: irq_handler_t CONFTEST: acpi_device_ops CONFTEST: acpi_op_remove CONFTEST: outer_flush_all CONFTEST: proc_dir_entry CONFTEST: scatterlist CONFTEST: sg_table CONFTEST: file_operations CONFTEST: vm_operations_struct CONFTEST: atomic_long_type CONFTEST: pci_save_state CONFTEST: file_inode CONFTEST: task_struct CONFTEST: kuid_t CONFTEST: dma_ops CONFTEST: dma_map_ops CONFTEST: noncoherent_swiotlb_dma_ops CONFTEST: vm_fault_present CONFTEST: vm_fault_has_address CONFTEST: kernel_write CONFTEST: strnstr CONFTEST: iterate_dir CONFTEST: kstrtoull CONFTEST: fault_flags CONFTEST: atomic64_type CONFTEST: address_space CONFTEST: backing_dev_info CONFTEST: mm_context_t CONFTEST: vm_ops_fault_removed_vma_arg CONFTEST: pnv_npu2_init_context CONFTEST: drm_bus_present CONFTEST: drm_bus_has_bus_type CONFTEST: drm_bus_has_get_irq CONFTEST: drm_bus_has_get_name CONFTEST: drm_driver_has_legacy_dev_list CONFTEST: drm_driver_has_set_busid CONFTEST: drm_crtc_state_has_connectors_changed CONFTEST: drm_init_function_args CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg CONFTEST: drm_helper_mode_fill_fb_struct CONFTEST: drm_master_drop_has_from_release_arg CONFTEST: drm_mode_config_funcs_has_atomic_state_alloc CONFTEST: drm_driver_unload_has_int_return_type CONFTEST: drm_crtc_helper_funcs_has_atomic_enable CONFTEST: dom0_kernel_present CONFTEST: nvidia_vgpu_kvm_build CONFTEST: nvidia_grid_build CONFTEST: drm_available CONFTEST: drm_atomic_available CONFTEST: drm_atomic_modeset_nonblocking_commit_available CONFTEST: is_export_symbol_gpl_refcount_inc CONFTEST: is_export_symbol_gpl_refcount_dec_and_test CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-frontend.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-instance.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gpu-numa.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv.o /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gpu-numa.c: In function ‘bad_idea_read_string_from_file’: /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gpu-numa.c:123:39: warning: passing argument 3 of ‘kernel_read’ makes integer from pointer without a cast [-Wint-conversion] read_count = kernel_read(filp, 0, read_buffer, read_buffer_size - 1); ^~~~~~~~~~~ In file included from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/huge_mm.h:7:0, from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/mm.h:453, from /var/lib/dkms/nvidia/384.98/build/common/inc/nv-pgprot.h:17, from /var/lib/dkms/nvidia/384.98/build/common/inc/nv-linux.h:20, from /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gpu-numa.c:24: /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/fs.h:2823:16: note: expected ‘size_t {aka long unsigned int}’ but argument is of type ‘char *’ extern ssize_t kernel_read(struct file *, void *, size_t, loff_t *); ^~~~~~~~~~~ /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gpu-numa.c:123:52: warning: passing argument 4 of ‘kernel_read’ makes pointer from integer without a cast [-Wint-conversion] read_count = kernel_read(filp, 0, read_buffer, read_buffer_size - 1); ^~~~~~~~~~~~~~~~ In file included from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/huge_mm.h:7:0, from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/mm.h:453, from /var/lib/dkms/nvidia/384.98/build/common/inc/nv-pgprot.h:17, from /var/lib/dkms/nvidia/384.98/build/common/inc/nv-linux.h:20, from /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gpu-numa.c:24: /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/fs.h:2823:16: note: expected ‘loff_t * {aka long long int *}’ but argument is of type ‘size_t {aka long unsigned int}’ extern ssize_t kernel_read(struct file *, void *, size_t, loff_t *); ^~~~~~~~~~~ CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-acpi.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-chrdev.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-cray.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-dma.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gvi.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-i2c.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-mempool.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-mmap.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-p2p.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-pat.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-procfs.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-usermap.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-vm.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-vtophys.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/os-interface.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/os-mlock.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/os-pci.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/os-registry.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/os-usermap.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-modeset-interface.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-pci-table.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-kthread-q.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-kthread-q-selftest.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-memdbg.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-report-err.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv_uvm_interface.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nvlink_linux.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_volta_host.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_volta.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_volta_fault_buffer.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_volta_access_counter_buffer.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_gpu_non_replayable_faults.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_gpu_access_counters.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm_utils.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm_common.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm_linux.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/nvstatus.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_tools.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_global.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_gpu.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_gpu_isr.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_procfs.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_va_space.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_gpu_semaphore.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_mem.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_rm_mem.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_channel.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_lock.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_hal.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_range_tree.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_range_allocator.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_va_range.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_va_block.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_range_group.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_gpu_replayable_faults.o In file included from /usr/src/kernels/4.14.11-300.fc27.x86_64/arch/x86/include/asm/cpufeature.h:5:0, from /usr/src/kernels/4.14.11-300.fc27.x86_64/arch/x86/include/asm/thread_info.h:53, from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/thread_info.h:38, from /usr/src/kernels/4.14.11-300.fc27.x86_64/arch/x86/include/asm/preempt.h:7, from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/preempt.h:81, from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/spinlock.h:51, from /var/lib/dkms/nvidia/384.98/build/common/inc/nv-lock.h:16, from /var/lib/dkms/nvidia/384.98/build/common/inc/nv-linux.h:19, from /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm_linux.h:39, from /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_va_block.c:24: /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_va_block.c: In function ‘block_cpu_fault_locked’: /usr/src/kernels/4.14.11-300.fc27.x86_64/arch/x86/include/asm/processor.h:826:39: error: implicit declaration of function ‘task_stack_page’; did you mean ‘task_stack_vm_area’? [-Werror=implicit-function-declaration] unsigned long __ptr = (unsigned long)task_stack_page(task); \ ^ /usr/src/kernels/4.14.11-300.fc27.x86_64/arch/x86/include/asm/processor.h:909:26: note: in expansion of macro ‘task_pt_regs’ #define KSTK_EIP(task) (task_pt_regs(task)->ip) ^~~~~~~~~~~~ /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_va_block.c:8771:41: note: in expansion of macro ‘KSTK_EIP’ KSTK_EIP(current)); ^~~~~~~~ CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_perf_events.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_perf_module.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_mmu.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_pte_batch.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_tlb_batch.o jeszcze plik nvidia-installer.log: nvidia-installer log file '/var/log/nvidia-installer.log' creation time: Sat Jan 6 00:05:59 2018 installer version: 384.98 PATH: /usr/local/sbin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin nvidia-installer command line: ./nvidia-installer Using: nvidia-installer ncurses v6 user interface -> Detected 4 CPUs online; setting concurrency level to 4. -> Tagging shared libraries with chcon -t textrel_shlib_t. -> License accepted. -> Installing NVIDIA driver version 384.98. -> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes) -> Installing both new and classic TLS OpenGL libraries. -> Installing both new and classic TLS 32bit OpenGL libraries. -> Install NVIDIA's 32-bit compatibility libraries? (Answer: Yes) -> Will install GLVND GLX client libraries. -> Will install GLVND EGL client libraries. -> Skipping GLX non-GLVND file: "libGL.so.384.98" -> Skipping GLX non-GLVND file: "libGL.so.1" -> Skipping GLX non-GLVND file: "libGL.so" -> Skipping EGL non-GLVND file: "libEGL.so.384.98" -> Skipping EGL non-GLVND file: "libEGL.so" -> Skipping EGL non-GLVND file: "libEGL.so.1" -> Skipping GLX non-GLVND file: "./32/libGL.so.384.98" -> Skipping GLX non-GLVND file: "libGL.so.1" -> Skipping GLX non-GLVND file: "libGL.so" -> Skipping EGL non-GLVND file: "./32/libEGL.so.384.98" -> Skipping EGL non-GLVND file: "libEGL.so" -> Skipping EGL non-GLVND file: "libEGL.so.1" Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh executing: '/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh'... Checking for libglvnd installation. Checking libGLdispatch... Checking libGLdispatch dispatch table Checking call through libGLdispatch All OK libGLdispatch is OK Checking for libGLX libGLX is OK Checking for libEGL libEGL is OK Checking entrypoint library libOpenGL.so.0 Checking call through libGLdispatch Checking call through library libOpenGL.so.0 All OK Entrypoint library libOpenGL.so.0 is OK Checking entrypoint library libGL.so.1 Checking call through libGLdispatch Checking call through library libGL.so.1 All OK Entrypoint library libGL.so.1 is OK libglvnd appears to be installed. Will not install libglvnd libraries. -> Skipping GLVND file: "libOpenGL.so.0" -> Skipping GLVND file: "libOpenGL.so" -> Skipping GLVND file: "libGLESv1_CM.so.1" -> Skipping GLVND file: "libGLESv1_CM.so" -> Skipping GLVND file: "libGLESv2.so.2" -> Skipping GLVND file: "libGLESv2.so" -> Skipping GLVND file: "libGLdispatch.so.0" -> Skipping GLVND file: "libGLX.so.0" -> Skipping GLVND file: "libGLX.so" -> Skipping GLVND file: "libGL.so.1.0.0" -> Skipping GLVND file: "libGL.so.1" -> Skipping GLVND file: "libGL.so" -> Skipping GLVND file: "libEGL.so.1" -> Skipping GLVND file: "libEGL.so" -> Skipping GLVND file: "./32/libOpenGL.so.0" -> Skipping GLVND file: "libOpenGL.so" -> Skipping GLVND file: "./32/libGLdispatch.so.0" -> Skipping GLVND file: "./32/libGLESv2.so.2" -> Skipping GLVND file: "libGLESv2.so" -> Skipping GLVND file: "./32/libGLESv1_CM.so.1" -> Skipping GLVND file: "libGLESv1_CM.so" -> Skipping GLVND file: "./32/libGL.so.1.0.0" -> Skipping GLVND file: "libGL.so.1" -> Skipping GLVND file: "libGL.so" -> Skipping GLVND file: "./32/libGLX.so.0" -> Skipping GLVND file: "libGLX.so" -> Skipping GLVND file: "./32/libEGL.so.1" -> Skipping GLVND file: "libEGL.so" Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d -> Searching for conflicting files: -> done. -> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (384.98): executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-glcore.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/extensions/libglx.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-tls.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/tls/libnvidia-tls.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLX_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/drivers/nvidia_drv.so'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/libnvidia-wfb.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-gtk2.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-gtk3.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-cfg.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ml.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/vdpau/libvdpau_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libcuda.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-opencl.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libOpenCL.so.1.0.0'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-fatbinaryloader.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ptxjitcompiler.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvcuvid.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-encode.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ifr.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-fbc.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-compiler.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-eglcore.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-glsi.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libEGL_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLESv2_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLESv1_CM_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-egl-wayland.so.1.0.1'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libcuda.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-fatbinaryloader.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ptxjitcompiler.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ml.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libOpenCL.so.1.0.0'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-compiler.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-opencl.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLX_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-glcore.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-tls.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/tls/libnvidia-tls.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/vdpau/libvdpau_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvcuvid.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-encode.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-eglcore.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-glsi.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libEGL_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLESv2_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLESv1_CM_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ifr.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-fbc.so.384.98'... executing: '/sbin/ldconfig'... -> done. -> Driver file installation is complete. -> Installing DKMS kernel module: ERROR: Failed to run `/sbin/dkms build -m nvidia -v 384.98 -k 4.14.11-300.fc27.x86_64`: Kernel preparation unnecessary for this kernel. Skipping... Building module: cleaning build area... 'make' -j4 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=4.14.11-300.fc27.x86_64 modules..........(bad exit status: 2) Error! Bad return status for module build on kernel: 4.14.11-300.fc27.x86_64 (x86_64) Consult /var/lib/dkms/nvidia/384.98/build/make.log for more information. -> error. ERROR: Failed to install the kernel module through DKMS. No kernel module was installed; please try installing again without DKMS, or check the DKMS logs for more information. ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com. Więc niestety poległem W repo posiadam tylko sterowniki w wersji 304xx oraz 340xx, które instalują sie bez problemowo jednak nie można uruchomić trybu graficznego podczas polecenia startx mam błąd dla sterowniki z repo 340xx: [ 77.815] X.Org X Server 1.19.5 Release Date: 2017-10-12 [ 77.816] X Protocol Version 11, Revision 0 [ 77.816] Build Operating System: 4.12.9-300.fc26.x86_64 [ 77.816] Current Operating System: Linux localhost.localdomain 4.14.11-300.fc27.x86_64 #1 SMP Wed Jan 3 13:52:28 UTC 2018 x86_64 [ 77.816] Kernel command line: BOOT_IMAGE=/vmlinuz-4.14.11-300.fc27.x86_64 root=/dev/mapper/fedora-root ro rd.lvm.lv=fedora/root rd.lvm.lv=fedora/swap rhgb quiet nouveau.modeset=0 rd.driver.blacklist=nouveau video=vesa:off [ 77.816] Build Date: 12 October 2017 07:35:27PM [ 77.816] Build ID: xorg-x11-server 1.19.5-1.fc27 [ 77.816] Current version of pixman: 0.34.0 [ 77.817] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 77.817] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 77.817] (==) Log file: "/var/log/Xorg.1.log", Time: Sat Jan 6 00:34:07 2018 [ 77.818] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 77.818] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 77.818] (==) No Layout section. Using the first Screen section. [ 77.818] (==) No screen section available. Using defaults. [ 77.818] (**) |-->Screen "Default Screen Section" (0) [ 77.818] (**) | |-->Monitor "<default monitor>" [ 77.818] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 77.818] (==) Automatically adding devices [ 77.818] (==) Automatically enabling devices [ 77.818] (==) Automatically adding GPU devices [ 77.818] (==) Automatically binding GPU devices [ 77.818] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 77.818] (==) FontPath set to: catalogue:/etc/X11/fontpath.d, built-ins [ 77.818] (**) ModulePath set to "/usr/lib64/nvidia-340xx/xorg,/usr/lib64/xorg/modules" [ 77.818] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 77.818] (II) Loader magic: 0x821e00 [ 77.818] (II) Module ABI versions: [ 77.818] X.Org ANSI C Emulation: 0.4 [ 77.818] X.Org Video Driver: 23.0 [ 77.818] X.Org XInput driver : 24.1 [ 77.818] X.Org Server Extension : 10.0 [ 77.820] (++) using VT number 2 [ 77.824] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_34 [ 77.826] (--) PCI:*(0:1:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xfd000000/16777216, 0xd0000000/268435456, 0xce000000/33554432, I/O @ 0x0000ac00/128, BIOS @ 0x????????/131072 [ 77.827] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere. [ 77.827] (II) "glx" will be loaded by default. [ 77.827] (II) LoadModule: "glx" [ 77.827] (II) Loading /usr/lib64/nvidia-340xx/xorg/libglx.so [ 77.841] (II) Module glx: vendor="NVIDIA Corporation" [ 77.841] compiled for 4.0.2, module version = 1.0.0 [ 77.841] Module class: X.Org Server Extension [ 77.841] (II) NVIDIA GLX Module 340.104 Thu Sep 14 16:40:42 PDT 2017 [ 77.966] (==) Matched nouveau as autoconfigured driver 0 [ 77.966] (==) Matched nv as autoconfigured driver 1 [ 77.966] (==) Matched modesetting as autoconfigured driver 2 [ 77.966] (==) Matched fbdev as autoconfigured driver 3 [ 77.966] (==) Matched vesa as autoconfigured driver 4 [ 77.966] (==) Assigned the driver to the xf86ConfigLayout [ 77.966] (II) LoadModule: "nouveau" [ 77.966] (WW) Warning, couldn't open module nouveau [ 77.966] (II) UnloadModule: "nouveau" [ 77.966] (II) Unloading nouveau [ 77.966] (EE) Failed to load module "nouveau" (module does not exist, 0) [ 77.966] (II) LoadModule: "nv" [ 77.966] (WW) Warning, couldn't open module nv [ 77.966] (II) UnloadModule: "nv" [ 77.966] (II) Unloading nv [ 77.966] (EE) Failed to load module "nv" (module does not exist, 0) [ 77.967] (II) LoadModule: "modesetting" [ 77.967] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so [ 77.967] (II) Module modesetting: vendor="X.Org Foundation" [ 77.967] compiled for 1.19.5, module version = 1.19.5 [ 77.967] Module class: X.Org Video Driver [ 77.967] ABI class: X.Org Video Driver, version 23.0 [ 77.967] (II) LoadModule: "fbdev" [ 77.967] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so [ 77.967] (II) Module fbdev: vendor="X.Org Foundation" [ 77.967] compiled for 1.19.3, module version = 0.4.3 [ 77.967] Module class: X.Org Video Driver [ 77.967] ABI class: X.Org Video Driver, version 23.0 [ 77.967] (II) LoadModule: "vesa" [ 77.968] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so [ 77.968] (II) Module vesa: vendor="X.Org Foundation" [ 77.968] compiled for 1.19.3, module version = 2.3.2 [ 77.968] Module class: X.Org Video Driver [ 77.968] ABI class: X.Org Video Driver, version 23.0 [ 77.968] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 77.968] (II) FBDEV: driver for framebuffer: fbdev [ 77.968] (II) VESA: driver for VESA chipsets: vesa [ 77.968] (EE) open /dev/dri/card0: No such file or directory [ 77.968] (WW) Falling back to old probe method for modesetting [ 77.968] (EE) open /dev/dri/card0: No such file or directory [ 77.968] (II) Loading sub module "fbdevhw" [ 77.968] (II) LoadModule: "fbdevhw" [ 77.968] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so [ 77.968] (II) Module fbdevhw: vendor="X.Org Foundation" [ 77.968] compiled for 1.19.5, module version = 0.0.2 [ 77.968] ABI class: X.Org Video Driver, version 23.0 [ 77.968] (EE) open /dev/fb0: No such file or directory [ 77.968] (WW) Falling back to old probe method for fbdev [ 77.968] (II) Loading sub module "fbdevhw" [ 77.968] (II) LoadModule: "fbdevhw" [ 77.968] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so [ 77.968] (II) Module fbdevhw: vendor="X.Org Foundation" [ 77.968] compiled for 1.19.5, module version = 0.0.2 [ 77.968] ABI class: X.Org Video Driver, version 23.0 [ 77.968] (EE) open /dev/fb0: No such file or directory [ 77.969] (EE) Screen 0 deleted because of no matching config section. [ 77.969] (II) UnloadModule: "modesetting" [ 77.969] (EE) Screen 0 deleted because of no matching config section. [ 77.969] (II) UnloadModule: "fbdev" [ 77.969] (II) UnloadSubModule: "fbdevhw" [ 77.969] (II) Loading sub module "vbe" [ 77.969] (II) LoadModule: "vbe" [ 77.969] (II) Loading /usr/lib64/xorg/modules/libvbe.so [ 77.969] (II) Module vbe: vendor="X.Org Foundation" [ 77.969] compiled for 1.19.5, module version = 1.1.0 [ 77.969] ABI class: X.Org Video Driver, version 23.0 [ 77.969] (II) Loading sub module "int10" [ 77.969] (II) LoadModule: "int10" [ 77.969] (II) Loading /usr/lib64/xorg/modules/libint10.so [ 77.969] (II) Module int10: vendor="X.Org Foundation" [ 77.969] compiled for 1.19.5, module version = 1.0.0 [ 77.969] ABI class: X.Org Video Driver, version 23.0 [ 77.969] (II) VESA(0): initializing int10 [ 77.971] (II) VESA(0): Primary V_BIOS segment is: 0xc000 [ 78.037] (II) VESA(0): VESA BIOS detected [ 78.037] (II) VESA(0): VESA VBE Version 3.0 [ 78.037] (II) VESA(0): VESA VBE Total Mem: 16384 kB [ 78.037] (II) VESA(0): VESA VBE OEM: NVIDIA [ 78.037] (II) VESA(0): VESA VBE OEM Software Rev: 132.4 [ 78.037] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation [ 78.037] (II) VESA(0): VESA VBE OEM Product: GM204 Board [ 78.037] (II) VESA(0): VESA VBE OEM Product Rev: Chip Rev [ 78.155] (II) VESA(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 78.155] (==) VESA(0): Depth 24, (--) framebuffer bpp 32 [ 78.155] (==) VESA(0): RGB weight 888 [ 78.155] (==) VESA(0): Default visual is TrueColor [ 78.155] (==) VESA(0): Using gamma correction (1.0, 1.0, 1.0) [ 78.156] (II) Loading sub module "ddc" [ 78.156] (II) LoadModule: "ddc" [ 78.156] (II) Module "ddc" already built-in [ 78.156] (II) VESA(0): VESA VBE DDC supported [ 78.156] (II) VESA(0): VESA VBE DDC Level 2 [ 78.156] (II) VESA(0): VESA VBE DDC transfer in appr. 1 sec. [ 78.177] (II) VESA(0): VESA VBE DDC read successfully [ 78.177] (II) VESA(0): Manufacturer: ACR Model: 3e3 Serial#: 1393576989 [ 78.177] (II) VESA(0): Year: 2015 Week: 31 [ 78.177] (II) VESA(0): EDID Version: 1.3 [ 78.177] (II) VESA(0): Digital Display Input [ 78.177] (II) VESA(0): Max Image Size [cm]: horiz.: 53 vert.: 30 [ 78.177] (II) VESA(0): Gamma: 2.20 [ 78.177] (II) VESA(0): DPMS capabilities: StandBy Suspend [ 78.177] (II) VESA(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 [ 78.177] (II) VESA(0): First detailed timing is preferred mode [ 78.177] (II) VESA(0): redX: 0.645 redY: 0.331 greenX: 0.314 greenY: 0.618 [ 78.177] (II) VESA(0): blueX: 0.150 blueY: 0.069 whiteX: 0.312 whiteY: 0.328 [ 78.177] (II) VESA(0): Supported established timings: [ 78.177] (II) VESA(0): 720x400@70Hz [ 78.177] (II) VESA(0): 640x480@60Hz [ 78.177] (II) VESA(0): 640x480@67Hz [ 78.177] (II) VESA(0): 640x480@72Hz [ 78.177] (II) VESA(0): 640x480@75Hz [ 78.177] (II) VESA(0): 800x600@56Hz [ 78.177] (II) VESA(0): 800x600@60Hz [ 78.177] (II) VESA(0): 800x600@72Hz [ 78.177] (II) VESA(0): 800x600@75Hz [ 78.177] (II) VESA(0): 832x624@75Hz [ 78.177] (II) VESA(0): 1024x768@60Hz [ 78.177] (II) VESA(0): 1024x768@70Hz [ 78.177] (II) VESA(0): 1024x768@75Hz [ 78.177] (II) VESA(0): 1280x1024@75Hz [ 78.177] (II) VESA(0): 1152x864@75Hz [ 78.177] (II) VESA(0): Manufacturer's mask: 0 [ 78.177] (II) VESA(0): Supported standard timings: [ 78.177] (II) VESA(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337 [ 78.177] (II) VESA(0): #1: hsize: 1280 vsize 960 refresh: 60 vid: 16513 [ 78.177] (II) VESA(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897 [ 78.177] (II) VESA(0): #3: hsize: 1280 vsize 720 refresh: 60 vid: 49281 [ 78.177] (II) VESA(0): #4: hsize: 1280 vsize 800 refresh: 60 vid: 129 [ 78.177] (II) VESA(0): #5: hsize: 1440 vsize 900 refresh: 60 vid: 149 [ 78.177] (II) VESA(0): #6: hsize: 1680 vsize 1050 refresh: 60 vid: 179 [ 78.177] (II) VESA(0): #7: hsize: 1920 vsize 1080 refresh: 60 vid: 49361 [ 78.177] (II) VESA(0): Supported detailed timing: [ 78.177] (II) VESA(0): clock: 148.5 MHz Image Size: 531 x 299 mm [ 78.177] (II) VESA(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 78.177] (II) VESA(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0 [ 78.177] (II) VESA(0): Ranges: V min: 55 V max: 76 Hz, H min: 30 H max: 80 kHz, PixClock max 175 MHz [ 78.177] (II) VESA(0): Monitor name: K242HL [ 78.177] (II) VESA(0): Serial No: T0FEE0058520 [ 78.177] (II) VESA(0): EDID (in hex): [ 78.177] (II) VESA(0): 00ffffffffffff000472e3031d4c1053 [ 78.177] (II) VESA(0): 1f19010380351e78ca39b0a554509e26 [ 78.177] (II) VESA(0): 115054bfef80714f8140818081c08100 [ 78.177] (II) VESA(0): 9500b300d1c0023a801871382d40582c [ 78.177] (II) VESA(0): 4500132b2100001e000000fd00374c1e [ 78.177] (II) VESA(0): 5011000a202020202020000000fc004b [ 78.177] (II) VESA(0): 323432484c0a202020202020000000ff [ 78.177] (II) VESA(0): 005430464545303035383532300a00a0 [ 78.177] (II) VESA(0): EDID vendor "ACR", prod id 995 [ 78.177] (II) VESA(0): Using EDID range info for horizontal sync [ 78.177] (II) VESA(0): Using EDID range info for vertical refresh [ 78.177] (II) VESA(0): Printing DDC gathered Modelines: [ 78.177] (II) VESA(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 78.177] (II) VESA(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 78.178] (II) VESA(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e) [ 78.178] (II) VESA(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e) [ 78.178] (II) VESA(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e) [ 78.178] (II) VESA(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e) [ 78.178] (II) VESA(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 78.178] (II) VESA(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e) [ 78.178] (II) VESA(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e) [ 78.178] (II) VESA(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e) [ 78.178] (II) VESA(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e) [ 78.178] (II) VESA(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 78.178] (II) VESA(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e) [ 78.178] (II) VESA(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e) [ 78.178] (II) VESA(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e) [ 78.178] (II) VESA(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e) [ 78.178] (II) VESA(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e) [ 78.178] (II) VESA(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e) [ 78.178] (II) VESA(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e) [ 78.178] (II) VESA(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e) [ 78.178] (II) VESA(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e) [ 78.178] (II) VESA(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e) [ 78.178] (II) VESA(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e) [ 78.178] (II) VESA(0): Searching for matching VESA mode(s): [ 78.179] Mode: 100 (640x400) [ 78.179] ModeAttributes: 0x3bf [ 78.179] WinAAttributes: 0x7 [ 78.179] WinBAttributes: 0x0 [ 78.179] WinGranularity: 64 [ 78.179] WinSize: 64 [ 78.179] WinASegment: 0xa000 [ 78.179] WinBSegment: 0x0 [ 78.179] WinFuncPtr: 0xc0007d60 [ 78.179] BytesPerScanline: 640 [ 78.179] XResolution: 640 [ 78.179] YResolution: 400 [ 78.179] XCharSize: 8 [ 78.179] YCharSize: 16 [ 78.179] NumberOfPlanes: 1 [ 78.179] BitsPerPixel: 8 [ 78.179] NumberOfBanks: 1 [ 78.179] MemoryModel: 4 [ 78.180] BankSize: 0 [ 78.180] NumberOfImages: 14 [ 78.180] RedMaskSize: 0 [ 78.180] RedFieldPosition: 0 [ 78.180] GreenMaskSize: 0 [ 78.180] GreenFieldPosition: 0 [ 78.180] BlueMaskSize: 0 [ 78.180] BlueFieldPosition: 0 [ 78.180] RsvdMaskSize: 0 [ 78.180] RsvdFieldPosition: 0 [ 78.180] DirectColorModeInfo: 0 [ 78.180] PhysBasePtr: 0xcf000000 [ 78.180] LinBytesPerScanLine: 640 [ 78.180] BnkNumberOfImagePages: 14 [ 78.180] LinNumberOfImagePages: 14 [ 78.180] LinRedMaskSize: 0 [ 78.180] LinRedFieldPosition: 0 [ 78.180] LinGreenMaskSize: 0 [ 78.180] LinGreenFieldPosition: 0 [ 78.180] LinBlueMaskSize: 0 [ 78.180] LinBlueFieldPosition: 0 [ 78.180] LinRsvdMaskSize: 0 [ 78.180] LinRsvdFieldPosition: 0 [ 78.180] MaxPixelClock: 229500000 [ 78.181] Mode: 101 (640x480) [ 78.181] ModeAttributes: 0x3bf [ 78.181] WinAAttributes: 0x7 [ 78.181] WinBAttributes: 0x0 [ 78.181] WinGranularity: 64 [ 78.181] WinSize: 64 [ 78.181] WinASegment: 0xa000 [ 78.181] WinBSegment: 0x0 [ 78.181] WinFuncPtr: 0xc0007d60 [ 78.181] BytesPerScanline: 640 [ 78.181] XResolution: 640 [ 78.181] YResolution: 480 [ 78.181] XCharSize: 8 [ 78.181] YCharSize: 16 [ 78.181] NumberOfPlanes: 1 [ 78.181] BitsPerPixel: 8 [ 78.181] NumberOfBanks: 1 [ 78.181] MemoryModel: 4 [ 78.181] BankSize: 0 [ 78.181] NumberOfImages: 10 [ 78.181] RedMaskSize: 0 [ 78.181] RedFieldPosition: 0 [ 78.181] GreenMaskSize: 0 [ 78.181] GreenFieldPosition: 0 [ 78.181] BlueMaskSize: 0 [ 78.181] BlueFieldPosition: 0 [ 78.181] RsvdMaskSize: 0 [ 78.182] RsvdFieldPosition: 0 [ 78.182] DirectColorModeInfo: 0 [ 78.182] PhysBasePtr: 0xcf000000 [ 78.182] LinBytesPerScanLine: 640 [ 78.182] BnkNumberOfImagePages: 10 [ 78.182] LinNumberOfImagePages: 10 [ 78.182] LinRedMaskSize: 0 [ 78.182] LinRedFieldPosition: 0 [ 78.182] LinGreenMaskSize: 0 [ 78.182] LinGreenFieldPosition: 0 [ 78.182] LinBlueMaskSize: 0 [ 78.182] LinBlueFieldPosition: 0 [ 78.182] LinRsvdMaskSize: 0 [ 78.182] LinRsvdFieldPosition: 0 [ 78.182] MaxPixelClock: 229500000 [ 78.183] Mode: 102 (800x600) [ 78.183] ModeAttributes: 0x33f [ 78.183] WinAAttributes: 0x7 [ 78.183] WinBAttributes: 0x0 [ 78.183] WinGranularity: 64 [ 78.183] WinSize: 64 [ 78.183] WinASegment: 0xa000 [ 78.183] WinBSegment: 0x0 [ 78.183] WinFuncPtr: 0xc0007d60 [ 78.183] BytesPerScanline: 100 [ 78.183] XResolution: 800 [ 78.183] YResolution: 600 [ 78.183] XCharSize: 8 [ 78.183] YCharSize: 16 [ 78.183] NumberOfPlanes: 4 [ 78.183] BitsPerPixel: 4 [ 78.183] NumberOfBanks: 1 [ 78.183] MemoryModel: 3 [ 78.183] BankSize: 0 [ 78.183] NumberOfImages: 2 [ 78.183] RedMaskSize: 0 [ 78.183] RedFieldPosition: 0 [ 78.183] GreenMaskSize: 0 [ 78.183] GreenFieldPosition: 0 [ 78.183] BlueMaskSize: 0 [ 78.183] BlueFieldPosition: 0 [ 78.183] RsvdMaskSize: 0 [ 78.183] RsvdFieldPosition: 0 [ 78.183] DirectColorModeInfo: 0 [ 78.183] PhysBasePtr: 0x0 [ 78.183] LinBytesPerScanLine: 100 [ 78.183] BnkNumberOfImagePages: 2 [ 78.183] LinNumberOfImagePages: 2 [ 78.183] LinRedMaskSize: 0 [ 78.183] LinRedFieldPosition: 0 [ 78.183] LinGreenMaskSize: 0 [ 78.183] LinGreenFieldPosition: 0 [ 78.183] LinBlueMaskSize: 0 [ 78.183] LinBlueFieldPosition: 0 [ 78.183] LinRsvdMaskSize: 0 [ 78.184] LinRsvdFieldPosition: 0 [ 78.184] MaxPixelClock: 108500000 [ 78.185] Mode: 103 (800x600) [ 78.185] ModeAttributes: 0x3bf [ 78.185] WinAAttributes: 0x7 [ 78.185] WinBAttributes: 0x0 [ 78.185] WinGranularity: 64 [ 78.185] WinSize: 64 [ 78.185] WinASegment: 0xa000 [ 78.185] WinBSegment: 0x0 [ 78.185] WinFuncPtr: 0xc0007d60 [ 78.185] BytesPerScanline: 800 [ 78.185] XResolution: 800 [ 78.185] YResolution: 600 [ 78.185] XCharSize: 8 [ 78.185] YCharSize: 16 [ 78.185] NumberOfPlanes: 1 [ 78.185] BitsPerPixel: 8 [ 78.185] NumberOfBanks: 1 [ 78.185] MemoryModel: 4 [ 78.185] BankSize: 0 [ 78.185] NumberOfImages: 6 [ 78.185] RedMaskSize: 0 [ 78.185] RedFieldPosition: 0 [ 78.185] GreenMaskSize: 0 [ 78.185] GreenFieldPosition: 0 [ 78.185] BlueMaskSize: 0 [ 78.185] BlueFieldPosition: 0 [ 78.185] RsvdMaskSize: 0 [ 78.185] RsvdFieldPosition: 0 [ 78.185] DirectColorModeInfo: 0 [ 78.185] PhysBasePtr: 0xcf000000 [ 78.185] LinBytesPerScanLine: 800 [ 78.185] BnkNumberOfImagePages: 6 [ 78.185] LinNumberOfImagePages: 6 [ 78.185] LinRedMaskSize: 0 [ 78.185] LinRedFieldPosition: 0 [ 78.185] LinGreenMaskSize: 0 [ 78.185] LinGreenFieldPosition: 0 [ 78.185] LinBlueMaskSize: 0 [ 78.185] LinBlueFieldPosition: 0 [ 78.185] LinRsvdMaskSize: 0 [ 78.185] LinRsvdFieldPosition: 0 [ 78.185] MaxPixelClock: 229500000 [ 78.187] Mode: 104 (1024x768) [ 78.187] ModeAttributes: 0x33f [ 78.187] WinAAttributes: 0x7 [ 78.187] WinBAttributes: 0x0 [ 78.187] WinGranularity: 64 [ 78.187] WinSize: 64 [ 78.187] WinASegment: 0xa000 [ 78.187] WinBSegment: 0x0 [ 78.187] WinFuncPtr: 0xc0007d60 [ 78.187] BytesPerScanline: 128 [ 78.187] XResolution: 1024 [ 78.187] YResolution: 768 [ 78.187] XCharSize: 8 [ 78.187] YCharSize: 16 [ 78.187] NumberOfPlanes: 4 [ 78.187] BitsPerPixel: 4 [ 78.187] NumberOfBanks: 1 [ 78.187] MemoryModel: 3 [ 78.187] BankSize: 0 [ 78.187] NumberOfImages: 1 [ 78.187] RedMaskSize: 0 [ 78.187] RedFieldPosition: 0 [ 78.187] GreenMaskSize: 0 [ 78.187] GreenFieldPosition: 0 [ 78.187] BlueMaskSize: 0 [ 78.187] BlueFieldPosition: 0 [ 78.187] RsvdMaskSize: 0 [ 78.187] RsvdFieldPosition: 0 [ 78.187] DirectColorModeInfo: 0 [ 78.187] PhysBasePtr: 0x0 [ 78.187] LinBytesPerScanLine: 128 [ 78.187] BnkNumberOfImagePages: 1 [ 78.187] LinNumberOfImagePages: 1 [ 78.187] LinRedMaskSize: 0 [ 78.187] LinRedFieldPosition: 0 [ 78.187] LinGreenMaskSize: 0 [ 78.187] LinGreenFieldPosition: 0 [ 78.187] LinBlueMaskSize: 0 [ 78.187] LinBlueFieldPosition: 0 [ 78.187] LinRsvdMaskSize: 0 [ 78.187] LinRsvdFieldPosition: 0 [ 78.187] MaxPixelClock: 108500000 [ 78.189] Mode: 105 (1024x768) [ 78.189] ModeAttributes: 0x3bf [ 78.189] WinAAttributes: 0x7 [ 78.189] WinBAttributes: 0x0 [ 78.189] WinGranularity: 64 [ 78.189] WinSize: 64 [ 78.189] WinASegment: 0xa000 [ 78.189] WinBSegment: 0x0 [ 78.189] WinFuncPtr: 0xc0007d60 [ 78.189] BytesPerScanline: 1024 [ 78.189] XResolution: 1024 [ 78.189] YResolution: 768 [ 78.189] XCharSize: 8 [ 78.189] YCharSize: 16 [ 78.189] NumberOfPlanes: 1 [ 78.189] BitsPerPixel: 8 [ 78.189] NumberOfBanks: 1 [ 78.189] MemoryModel: 4 [ 78.189] BankSize: 0 [ 78.189] NumberOfImages: 3 [ 78.189] RedMaskSize: 0 [ 78.189] RedFieldPosition: 0 [ 78.189] GreenMaskSize: 0 [ 78.189] GreenFieldPosition: 0 [ 78.189] BlueMaskSize: 0 [ 78.189] BlueFieldPosition: 0 [ 78.189] RsvdMaskSize: 0 [ 78.189] RsvdFieldPosition: 0 [ 78.189] DirectColorModeInfo: 0 [ 78.189] PhysBasePtr: 0xcf000000 [ 78.189] LinBytesPerScanLine: 1024 [ 78.189] BnkNumberOfImagePages: 3 [ 78.189] LinNumberOfImagePages: 3 [ 78.189] LinRedMaskSize: 0 [ 78.189] LinRedFieldPosition: 0 [ 78.189] LinGreenMaskSize: 0 [ 78.189] LinGreenFieldPosition: 0 [ 78.189] LinBlueMaskSize: 0 [ 78.189] LinBlueFieldPosition: 0 [ 78.189] LinRsvdMaskSize: 0 [ 78.189] LinRsvdFieldPosition: 0 [ 78.189] MaxPixelClock: 229500000 [ 78.191] Mode: 106 (1280x1024) [ 78.191] ModeAttributes: 0x33f [ 78.191] WinAAttributes: 0x7 [ 78.191] WinBAttributes: 0x0 [ 78.191] WinGranularity: 64 [ 78.191] WinSize: 64 [ 78.191] WinASegment: 0xa000 [ 78.191] WinBSegment: 0x0 [ 78.191] WinFuncPtr: 0xc0007d60 [ 78.191] BytesPerScanline: 160 [ 78.191] XResolution: 1280 [ 78.191] YResolution: 1024 [ 78.191] XCharSize: 8 [ 78.191] YCharSize: 16 [ 78.191] NumberOfPlanes: 4 [ 78.191] BitsPerPixel: 4 [ 78.191] NumberOfBanks: 1 [ 78.191] MemoryModel: 3 [ 78.191] BankSize: 0 [ 78.191] NumberOfImages: 1 [ 78.191] RedMaskSize: 0 [ 78.191] RedFieldPosition: 0 [ 78.191] GreenMaskSize: 0 [ 78.191] GreenFieldPosition: 0 [ 78.191] BlueMaskSize: 0 [ 78.191] BlueFieldPosition: 0 [ 78.191] RsvdMaskSize: 0 [ 78.191] RsvdFieldPosition: 0 [ 78.191] DirectColorModeInfo: 0 [ 78.191] PhysBasePtr: 0x0 [ 78.191] LinBytesPerScanLine: 160 [ 78.191] BnkNumberOfImagePages: 1 [ 78.191] LinNumberOfImagePages: 1 [ 78.191] LinRedMaskSize: 0 [ 78.191] LinRedFieldPosition: 0 [ 78.191] LinGreenMaskSize: 0 [ 78.191] LinGreenFieldPosition: 0 [ 78.191] LinBlueMaskSize: 0 [ 78.191] LinBlueFieldPosition: 0 [ 78.191] LinRsvdMaskSize: 0 [ 78.191] LinRsvdFieldPosition: 0 [ 78.191] MaxPixelClock: 108500000 [ 78.193] Mode: 107 (1280x1024) [ 78.193] ModeAttributes: 0x3bf [ 78.193] WinAAttributes: 0x7 [ 78.193] WinBAttributes: 0x0 [ 78.193] WinGranularity: 64 [ 78.193] WinSize: 64 [ 78.193] WinASegment: 0xa000 [ 78.193] WinBSegment: 0x0 [ 78.193] WinFuncPtr: 0xc0007d60 [ 78.193] BytesPerScanline: 1280 [ 78.193] XResolution: 1280 [ 78.193] YResolution: 1024 [ 78.193] XCharSize: 8 [ 78.193] YCharSize: 16 [ 78.193] NumberOfPlanes: 1 [ 78.193] BitsPerPixel: 8 [ 78.193] NumberOfBanks: 1 [ 78.193] MemoryModel: 4 [ 78.193] BankSize: 0 [ 78.193] NumberOfImages: 1 [ 78.193] RedMaskSize: 0 [ 78.193] RedFieldPosition: 0 [ 78.193] GreenMaskSize: 0 [ 78.193] GreenFieldPosition: 0 [ 78.193] BlueMaskSize: 0 [ 78.193] BlueFieldPosition: 0 [ 78.193] RsvdMaskSize: 0 [ 78.193] RsvdFieldPosition: 0 [ 78.193] DirectColorModeInfo: 0 [ 78.193] PhysBasePtr: 0xcf000000 [ 78.193] LinBytesPerScanLine: 1280 [ 78.193] BnkNumberOfImagePages: 1 [ 78.193] LinNumberOfImagePages: 1 [ 78.193] LinRedMaskSize: 0 [ 78.193] LinRedFieldPosition: 0 [ 78.193] LinGreenMaskSize: 0 [ 78.193] LinGreenFieldPosition: 0 [ 78.193] LinBlueMaskSize: 0 [ 78.193] LinBlueFieldPosition: 0 [ 78.193] LinRsvdMaskSize: 0 [ 78.193] LinRsvdFieldPosition: 0 [ 78.193] MaxPixelClock: 229500000 [ 78.195] Mode: 10e (320x200) [ 78.195] ModeAttributes: 0x3bf [ 78.195] WinAAttributes: 0x7 [ 78.195] WinBAttributes: 0x0 [ 78.195] WinGranularity: 64 [ 78.195] WinSize: 64 [ 78.195] WinASegment: 0xa000 [ 78.195] WinBSegment: 0x0 [ 78.195] WinFuncPtr: 0xc0007d60 [ 78.195] BytesPerScanline: 640 [ 78.195] XResolution: 320 [ 78.195] YResolution: 200 [ 78.195] XCharSize: 8 [ 78.195] YCharSize: 8 [ 78.195] NumberOfPlanes: 1 [ 78.195] BitsPerPixel: 16 [ 78.195] NumberOfBanks: 1 [ 78.195] MemoryModel: 6 [ 78.195] BankSize: 0 [ 78.195] NumberOfImages: 30 [ 78.195] RedMaskSize: 5 [ 78.195] RedFieldPosition: 11 [ 78.195] GreenMaskSize: 6 [ 78.195] GreenFieldPosition: 5 [ 78.195] BlueMaskSize: 5 [ 78.195] BlueFieldPosition: 0 [ 78.195] RsvdMaskSize: 0 [ 78.195] RsvdFieldPosition: 0 [ 78.195] DirectColorModeInfo: 0 [ 78.195] PhysBasePtr: 0xcf000000 [ 78.195] LinBytesPerScanLine: 640 [ 78.195] BnkNumberOfImagePages: 30 [ 78.195] LinNumberOfImagePages: 30 [ 78.195] LinRedMaskSize: 5 [ 78.195] LinRedFieldPosition: 11 [ 78.195] LinGreenMaskSize: 6 [ 78.195] LinGreenFieldPosition: 5 [ 78.195] LinBlueMaskSize: 5 [ 78.195] LinBlueFieldPosition: 0 [ 78.195] LinRsvdMaskSize: 0 [ 78.195] LinRsvdFieldPosition: 0 [ 78.195] MaxPixelClock: 229500000 [ 78.197] *Mode: 10f (320x200) [ 78.197] ModeAttributes: 0x3bf [ 78.197] WinAAttributes: 0x7 [ 78.197] WinBAttributes: 0x0 [ 78.197] WinGranularity: 64 [ 78.197] WinSize: 64 [ 78.197] WinASegment: 0xa000 [ 78.197] WinBSegment: 0x0 [ 78.197] WinFuncPtr: 0xc0007d60 [ 78.197] BytesPerScanline: 1280 [ 78.197] XResolution: 320 [ 78.197] YResolution: 200 [ 78.197] XCharSize: 8 [ 78.197] YCharSize: 8 [ 78.197] NumberOfPlanes: 1 [ 78.197] BitsPerPixel: 32 [ 78.197] NumberOfBanks: 1 [ 78.197] MemoryModel: 6 [ 78.197] BankSize: 0 [ 78.197] NumberOfImages: 14 [ 78.197] RedMaskSize: 8 [ 78.197] RedFieldPosition: 16 [ 78.197] GreenMaskSize: 8 [ 78.197] GreenFieldPosition: 8 [ 78.197] BlueMaskSize: 8 [ 78.197] BlueFieldPosition: 0 [ 78.197] RsvdMaskSize: 8 [ 78.197] RsvdFieldPosition: 24 [ 78.197] DirectColorModeInfo: 0 [ 78.197] PhysBasePtr: 0xcf000000 [ 78.197] LinBytesPerScanLine: 1280 [ 78.197] BnkNumberOfImagePages: 14 [ 78.197] LinNumberOfImagePages: 14 [ 78.197] LinRedMaskSize: 8 [ 78.197] LinRedFieldPosition: 16 [ 78.197] LinGreenMaskSize: 8 [ 78.197] LinGreenFieldPosition: 8 [ 78.197] LinBlueMaskSize: 8 [ 78.197] LinBlueFieldPosition: 0 [ 78.197] LinRsvdMaskSize: 8 [ 78.197] LinRsvdFieldPosition: 24 [ 78.197] MaxPixelClock: 229500000 [ 78.199] Mode: 111 (640x480) [ 78.199] ModeAttributes: 0x3bf [ 78.199] WinAAttributes: 0x7 [ 78.199] WinBAttributes: 0x0 [ 78.199] WinGranularity: 64 [ 78.199] WinSize: 64 [ 78.199] WinASegment: 0xa000 [ 78.199] WinBSegment: 0x0 [ 78.199] WinFuncPtr: 0xc0007d60 [ 78.199] BytesPerScanline: 1280 [ 78.199] XResolution: 640 [ 78.199] YResolution: 480 [ 78.199] XCharSize: 8 [ 78.199] YCharSize: 16 [ 78.199] NumberOfPlanes: 1 [ 78.199] BitsPerPixel: 16 [ 78.199] NumberOfBanks: 1 [ 78.199] MemoryModel: 6 [ 78.199] BankSize: 0 [ 78.199] NumberOfImages: 4 [ 78.199] RedMaskSize: 5 [ 78.199] RedFieldPosition: 11 [ 78.199] GreenMaskSize: 6 [ 78.199] GreenFieldPosition: 5 [ 78.199] BlueMaskSize: 5 [ 78.199] BlueFieldPosition: 0 [ 78.199] RsvdMaskSize: 0 [ 78.199] RsvdFieldPosition: 0 [ 78.199] DirectColorModeInfo: 0 [ 78.199] PhysBasePtr: 0xcf000000 [ 78.199] LinBytesPerScanLine: 1280 [ 78.199] BnkNumberOfImagePages: 4 [ 78.199] LinNumberOfImagePages: 4 [ 78.199] LinRedMaskSize: 5 [ 78.199] LinRedFieldPosition: 11 [ 78.199] LinGreenMaskSize: 6 [ 78.199] LinGreenFieldPosition: 5 [ 78.199] LinBlueMaskSize: 5 [ 78.199] LinBlueFieldPosition: 0 [ 78.199] LinRsvdMaskSize: 0 [ 78.199] LinRsvdFieldPosition: 0 [ 78.199] MaxPixelClock: 229500000 [ 78.201] *Mode: 112 (640x480) [ 78.201] ModeAttributes: 0x3bf [ 78.201] WinAAttributes: 0x7 [ 78.201] WinBAttributes: 0x0 [ 78.201] WinGranularity: 64 [ 78.201] WinSize: 64 [ 78.201] WinASegment: 0xa000 [ 78.201] WinBSegment: 0x0 [ 78.201] WinFuncPtr: 0xc0007d60 [ 78.201] BytesPerScanline: 2560 [ 78.201] XResolution: 640 [ 78.201] YResolution: 480 [ 78.201] XCharSize: 8 [ 78.201] YCharSize: 16 [ 78.201] NumberOfPlanes: 1 [ 78.201] BitsPerPixel: 32 [ 78.201] NumberOfBanks: 1 [ 78.201] MemoryModel: 6 [ 78.201] BankSize: 0 [ 78.201] NumberOfImages: 1 [ 78.201] RedMaskSize: 8 [ 78.201] RedFieldPosition: 16 [ 78.201] GreenMaskSize: 8 [ 78.201] GreenFieldPosition: 8 [ 78.201] BlueMaskSize: 8 [ 78.201] BlueFieldPosition: 0 [ 78.201] RsvdMaskSize: 8 [ 78.201] RsvdFieldPosition: 24 [ 78.201] DirectColorModeInfo: 0 [ 78.201] PhysBasePtr: 0xcf000000 [ 78.201] LinBytesPerScanLine: 2560 [ 78.201] BnkNumberOfImagePages: 1 [ 78.201] LinNumberOfImagePages: 1 [ 78.201] LinRedMaskSize: 8 [ 78.201] LinRedFieldPosition: 16 [ 78.201] LinGreenMaskSize: 8 [ 78.201] LinGreenFieldPosition: 8 [ 78.201] LinBlueMaskSize: 8 [ 78.201] LinBlueFieldPosition: 0 [ 78.201] LinRsvdMaskSize: 8 [ 78.201] LinRsvdFieldPosition: 24 [ 78.201] MaxPixelClock: 229500000 [ 78.203] Mode: 114 (800x600) [ 78.203] ModeAttributes: 0x3bf [ 78.203] WinAAttributes: 0x7 [ 78.203] WinBAttributes: 0x0 [ 78.203] WinGranularity: 64 [ 78.203] WinSize: 64 [ 78.203] WinASegment: 0xa000 [ 78.203] WinBSegment: 0x0 [ 78.203] WinFuncPtr: 0xc0007d60 [ 78.203] BytesPerScanline: 1600 [ 78.203] XResolution: 800 [ 78.203] YResolution: 600 [ 78.203] XCharSize: 8 [ 78.203] YCharSize: 16 [ 78.203] NumberOfPlanes: 1 [ 78.203] BitsPerPixel: 16 [ 78.203] NumberOfBanks: 1 [ 78.203] MemoryModel: 6 [ 78.203] BankSize: 0 [ 78.203] NumberOfImages: 2 [ 78.203] RedMaskSize: 5 [ 78.203] RedFieldPosition: 11 [ 78.203] GreenMaskSize: 6 [ 78.203] GreenFieldPosition: 5 [ 78.203] BlueMaskSize: 5 [ 78.203] BlueFieldPosition: 0 [ 78.203] RsvdMaskSize: 0 [ 78.203] RsvdFieldPosition: 0 [ 78.203] DirectColorModeInfo: 0 [ 78.203] PhysBasePtr: 0xcf000000 [ 78.203] LinBytesPerScanLine: 1600 [ 78.203] BnkNumberOfImagePages: 2 [ 78.203] LinNumberOfImagePages: 2 [ 78.203] LinRedMaskSize: 5 [ 78.203] LinRedFieldPosition: 11 [ 78.203] LinGreenMaskSize: 6 [ 78.203] LinGreenFieldPosition: 5 [ 78.203] LinBlueMaskSize: 5 [ 78.203] LinBlueFieldPosition: 0 [ 78.203] LinRsvdMaskSize: 0 [ 78.203] LinRsvdFieldPosition: 0 [ 78.203] MaxPixelClock: 229500000 [ 78.204] *Mode: 115 (800x600) [ 78.204] ModeAttributes: 0x3bf [ 78.204] WinAAttributes: 0x7 [ 78.204] WinBAttributes: 0x0 [ 78.204] WinGranularity: 64 [ 78.204] WinSize: 64 [ 78.204] WinASegment: 0xa000 [ 78.205] WinBSegment: 0x0 [ 78.205] WinFuncPtr: 0xc0007d60 [ 78.205] BytesPerScanline: 3200 [ 78.205] XResolution: 800 [ 78.205] YResolution: 600 [ 78.205] XCharSize: 8 [ 78.205] YCharSize: 16 [ 78.205] NumberOfPlanes: 1 [ 78.205] BitsPerPixel: 32 [ 78.205] NumberOfBanks: 1 [ 78.205] MemoryModel: 6 [ 78.205] BankSize: 0 [ 78.205] NumberOfImages: 1 [ 78.205] RedMaskSize: 8 [ 78.205] RedFieldPosition: 16 [ 78.205] GreenMaskSize: 8 [ 78.205] GreenFieldPosition: 8 [ 78.205] BlueMaskSize: 8 [ 78.205] BlueFieldPosition: 0 [ 78.205] RsvdMaskSize: 8 [ 78.205] RsvdFieldPosition: 24 [ 78.205] DirectColorModeInfo: 0 [ 78.205] PhysBasePtr: 0xcf000000 [ 78.205] LinBytesPerScanLine: 3200 [ 78.205] BnkNumberOfImagePages: 1 [ 78.205] LinNumberOfImagePages: 1 [ 78.205] LinRedMaskSize: 8 [ 78.205] LinRedFieldPosition: 16 [ 78.205] LinGreenMaskSize: 8 [ 78.205] LinGreenFieldPosition: 8 [ 78.205] LinBlueMaskSize: 8 [ 78.205] LinBlueFieldPosition: 0 [ 78.205] LinRsvdMaskSize: 8 [ 78.205] LinRsvdFieldPosition: 24 [ 78.205] MaxPixelClock: 229500000 [ 78.206] Mode: 117 (1024x768) [ 78.206] ModeAttributes: 0x3bf [ 78.206] WinAAttributes: 0x7 [ 78.206] WinBAttributes: 0x0 [ 78.206] WinGranularity: 64 [ 78.206] WinSize: 64 [ 78.206] WinASegment: 0xa000 [ 78.206] WinBSegment: 0x0 [ 78.206] WinFuncPtr: 0xc0007d60 [ 78.206] BytesPerScanline: 2048 [ 78.206] XResolution: 1024 [ 78.206] YResolution: 768 [ 78.206] XCharSize: 8 [ 78.206] YCharSize: 16 [ 78.207] NumberOfPlanes: 1 [ 78.207] BitsPerPixel: 16 [ 78.207] NumberOfBanks: 1 [ 78.207] MemoryModel: 6 [ 78.207] BankSize: 0 [ 78.207] NumberOfImages: 1 [ 78.207] RedMaskSize: 5 [ 78.207] RedFieldPosition: 11 [ 78.207] GreenMaskSize: 6 [ 78.207] GreenFieldPosition: 5 [ 78.207] BlueMaskSize: 5 [ 78.207] BlueFieldPosition: 0 [ 78.207] RsvdMaskSize: 0 [ 78.207] RsvdFieldPosition: 0 [ 78.207] DirectColorModeInfo: 0 [ 78.207] PhysBasePtr: 0xcf000000 [ 78.207] LinBytesPerScanLine: 2048 [ 78.207] BnkNumberOfImagePages: 1 [ 78.207] LinNumberOfImagePages: 1 [ 78.207] LinRedMaskSize: 5 [ 78.207] LinRedFieldPosition: 11 [ 78.207] LinGreenMaskSize: 6 [ 78.207] LinGreenFieldPosition: 5 [ 78.207] LinBlueMaskSize: 5 [ 78.207] LinBlueFieldPosition: 0 [ 78.207] LinRsvdMaskSize: 0 [ 78.207] LinRsvdFieldPosition: 0 [ 78.207] MaxPixelClock: 229500000 [ 78.208] *Mode: 118 (1024x768) [ 78.208] ModeAttributes: 0x3bf [ 78.208] WinAAttributes: 0x7 [ 78.208] WinBAttributes: 0x0 [ 78.208] WinGranularity: 64 [ 78.208] WinSize: 64 [ 78.208] WinASegment: 0xa000 [ 78.208] WinBSegment: 0x0 [ 78.208] WinFuncPtr: 0xc0007d60 [ 78.208] BytesPerScanline: 4096 [ 78.208] XResolution: 1024 [ 78.208] YResolution: 768 [ 78.208] XCharSize: 8 [ 78.208] YCharSize: 16 [ 78.208] NumberOfPlanes: 1 [ 78.208] BitsPerPixel: 32 [ 78.208] NumberOfBanks: 1 [ 78.208] MemoryModel: 6 [ 78.208] BankSize: 0 [ 78.208] NumberOfImages: 1 [ 78.208] RedMaskSize: 8 [ 78.208] RedFieldPosition: 16 [ 78.208] GreenMaskSize: 8 [ 78.208] GreenFieldPosition: 8 [ 78.208] BlueMaskSize: 8 [ 78.208] BlueFieldPosition: 0 [ 78.208] RsvdMaskSize: 8 [ 78.209] RsvdFieldPosition: 24 [ 78.209] DirectColorModeInfo: 0 [ 78.209] PhysBasePtr: 0xcf000000 [ 78.209] LinBytesPerScanLine: 4096 [ 78.209] BnkNumberOfImagePages: 1 [ 78.209] LinNumberOfImagePages: 1 [ 78.209] LinRedMaskSize: 8 [ 78.209] LinRedFieldPosition: 16 [ 78.209] LinGreenMaskSize: 8 [ 78.209] LinGreenFieldPosition: 8 [ 78.209] LinBlueMaskSize: 8 [ 78.209] LinBlueFieldPosition: 0 [ 78.209] LinRsvdMaskSize: 8 [ 78.209] LinRsvdFieldPosition: 24 [ 78.209] MaxPixelClock: 229500000 [ 78.210] Mode: 11a (1280x1024) [ 78.210] ModeAttributes: 0x3bf [ 78.210] WinAAttributes: 0x7 [ 78.210] WinBAttributes: 0x0 [ 78.210] WinGranularity: 64 [ 78.210] WinSize: 64 [ 78.210] WinASegment: 0xa000 [ 78.210] WinBSegment: 0x0 [ 78.210] WinFuncPtr: 0xc0007d60 [ 78.210] BytesPerScanline: 2560 [ 78.210] XResolution: 1280 [ 78.210] YResolution: 1024 [ 78.210] XCharSize: 8 [ 78.210] YCharSize: 16 [ 78.210] NumberOfPlanes: 1 [ 78.210] BitsPerPixel: 16 [ 78.210] NumberOfBanks: 1 [ 78.210] MemoryModel: 6 [ 78.210] BankSize: 0 [ 78.210] NumberOfImages: 1 [ 78.210] RedMaskSize: 5 [ 78.210] RedFieldPosition: 11 [ 78.210] GreenMaskSize: 6 [ 78.210] GreenFieldPosition: 5 [ 78.210] BlueMaskSize: 5 [ 78.210] BlueFieldPosition: 0 [ 78.210] RsvdMaskSize: 0 [ 78.210] RsvdFieldPosition: 0 [ 78.210] DirectColorModeInfo: 0 [ 78.210] PhysBasePtr: 0xcf000000 [ 78.210] LinBytesPerScanLine: 2560 [ 78.210] BnkNumberOfImagePages: 1 [ 78.210] LinNumberOfImagePages: 1 [ 78.210] LinRedMaskSize: 5 [ 78.210] LinRedFieldPosition: 11 [ 78.210] LinGreenMaskSize: 6 [ 78.210] LinGreenFieldPosition: 5 [ 78.210] LinBlueMaskSize: 5 [ 78.211] LinBlueFieldPosition: 0 [ 78.211] LinRsvdMaskSize: 0 [ 78.211] LinRsvdFieldPosition: 0 [ 78.211] MaxPixelClock: 229500000 [ 78.212] *Mode: 11b (1280x1024) [ 78.212] ModeAttributes: 0x3bf [ 78.212] WinAAttributes: 0x7 [ 78.212] WinBAttributes: 0x0 [ 78.212] WinGranularity: 64 [ 78.212] WinSize: 64 [ 78.212] WinASegment: 0xa000 [ 78.212] WinBSegment: 0x0 [ 78.212] WinFuncPtr: 0xc0007d60 [ 78.212] BytesPerScanline: 5120 [ 78.212] XResolution: 1280 [ 78.212] YResolution: 1024 [ 78.212] XCharSize: 8 [ 78.212] YCharSize: 16 [ 78.212] NumberOfPlanes: 1 [ 78.212] BitsPerPixel: 32 [ 78.212] NumberOfBanks: 1 [ 78.212] MemoryModel: 6 [ 78.212] BankSize: 0 [ 78.212] NumberOfImages: 1 [ 78.212] RedMaskSize: 8 [ 78.212] RedFieldPosition: 16 [ 78.212] GreenMaskSize: 8 [ 78.212] GreenFieldPosition: 8 [ 78.212] BlueMaskSize: 8 [ 78.212] BlueFieldPosition: 0 [ 78.212] RsvdMaskSize: 8 [ 78.212] RsvdFieldPosition: 24 [ 78.212] DirectColorModeInfo: 0 [ 78.212] PhysBasePtr: 0xcf000000 [ 78.212] LinBytesPerScanLine: 5120 [ 78.212] BnkNumberOfImagePages: 1 [ 78.212] LinNumberOfImagePages: 1 [ 78.212] LinRedMaskSize: 8 [ 78.212] LinRedFieldPosition: 16 [ 78.212] LinGreenMaskSize: 8 [ 78.212] LinGreenFieldPosition: 8 [ 78.212] LinBlueMaskSize: 8 [ 78.212] LinBlueFieldPosition: 0 [ 78.212] LinRsvdMaskSize: 8 [ 78.212] LinRsvdFieldPosition: 24 [ 78.212] MaxPixelClock: 229500000 [ 78.214] Mode: 130 (320x200) [ 78.214] ModeAttributes: 0x3bf [ 78.214] WinAAttributes: 0x7 [ 78.214] WinBAttributes: 0x0 [ 78.214] WinGranularity: 64 [ 78.214] WinSize: 64 [ 78.214] WinASegment: 0xa000 [ 78.214] WinBSegment: 0x0 [ 78.214] WinFuncPtr: 0xc0007d60 [ 78.214] BytesPerScanline: 320 [ 78.214] XResolution: 320 [ 78.214] YResolution: 200 [ 78.214] XCharSize: 8 [ 78.214] YCharSize: 8 [ 78.214] NumberOfPlanes: 1 [ 78.214] BitsPerPixel: 8 [ 78.214] NumberOfBanks: 1 [ 78.214] MemoryModel: 4 [ 78.214] BankSize: 0 [ 78.214] NumberOfImages: 62 [ 78.214] RedMaskSize: 0 [ 78.214] RedFieldPosition: 0 [ 78.214] GreenMaskSize: 0 [ 78.214] GreenFieldPosition: 0 [ 78.214] BlueMaskSize: 0 [ 78.214] BlueFieldPosition: 0 [ 78.214] RsvdMaskSize: 0 [ 78.214] RsvdFieldPosition: 0 [ 78.214] DirectColorModeInfo: 0 [ 78.214] PhysBasePtr: 0xcf000000 [ 78.214] LinBytesPerScanLine: 320 [ 78.214] BnkNumberOfImagePages: 62 [ 78.214] LinNumberOfImagePages: 62 [ 78.214] LinRedMaskSize: 0 [ 78.214] LinRedFieldPosition: 0 [ 78.214] LinGreenMaskSize: 0 [ 78.214] LinGreenFieldPosition: 0 [ 78.214] LinBlueMaskSize: 0 [ 78.214] LinBlueFieldPosition: 0 [ 78.214] LinRsvdMaskSize: 0 [ 78.214] LinRsvdFieldPosition: 0 [ 78.214] MaxPixelClock: 229500000 [ 78.216] Mode: 131 (320x400) [ 78.216] ModeAttributes: 0x3bf [ 78.216] WinAAttributes: 0x7 [ 78.216] WinBAttributes: 0x0 [ 78.216] WinGranularity: 64 [ 78.216] WinSize: 64 [ 78.216] WinASegment: 0xa000 [ 78.216] WinBSegment: 0x0 [ 78.216] WinFuncPtr: 0xc0007d60 [ 78.216] BytesPerScanline: 320 [ 78.216] XResolution: 320 [ 78.216] YResolution: 400 [ 78.216] XCharSize: 8 [ 78.216] YCharSize: 16 [ 78.216] NumberOfPlanes: 1 [ 78.216] BitsPerPixel: 8 [ 78.216] NumberOfBanks: 1 [ 78.216] MemoryModel: 4 [ 78.216] BankSize: 0 [ 78.216] NumberOfImages: 30 [ 78.216] RedMaskSize: 0 [ 78.216] RedFieldPosition: 0 [ 78.216] GreenMaskSize: 0 [ 78.216] GreenFieldPosition: 0 [ 78.216] BlueMaskSize: 0 [ 78.216] BlueFieldPosition: 0 [ 78.216] RsvdMaskSize: 0 [ 78.216] RsvdFieldPosition: 0 [ 78.216] DirectColorModeInfo: 0 [ 78.216] PhysBasePtr: 0xcf000000 [ 78.216] LinBytesPerScanLine: 320 [ 78.216] BnkNumberOfImagePages: 30 [ 78.216] LinNumberOfImagePages: 30 [ 78.216] LinRedMaskSize: 0 [ 78.216] LinRedFieldPosition: 0 [ 78.216] LinGreenMaskSize: 0 [ 78.216] LinGreenFieldPosition: 0 [ 78.216] LinBlueMaskSize: 0 [ 78.216] LinBlueFieldPosition: 0 [ 78.216] LinRsvdMaskSize: 0 [ 78.216] LinRsvdFieldPosition: 0 [ 78.216] MaxPixelClock: 229500000 [ 78.218] Mode: 132 (320x400) [ 78.218] ModeAttributes: 0x3bf [ 78.218] WinAAttributes: 0x7 [ 78.218] WinBAttributes: 0x0 [ 78.218] WinGranularity: 64 [ 78.218] WinSize: 64 [ 78.218] WinASegment: 0xa000 [ 78.218] WinBSegment: 0x0 [ 78.218] WinFuncPtr: 0xc0007d60 [ 78.218] BytesPerScanline: 640 [ 78.218] XResolution: 320 [ 78.218] YResolution: 400 [ 78.218] XCharSize: 8 [ 78.218] YCharSize: 16 [ 78.218] NumberOfPlanes: 1 [ 78.218] BitsPerPixel: 16 [ 78.218] NumberOfBanks: 1 [ 78.218] MemoryModel: 6 [ 78.218] BankSize: 0 [ 78.218] NumberOfImages: 14 [ 78.218] RedMaskSize: 5 [ 78.218] RedFieldPosition: 11 [ 78.218] GreenMaskSize: 6 [ 78.218] GreenFieldPosition: 5 [ 78.218] BlueMaskSize: 5 [ 78.218] BlueFieldPosition: 0 [ 78.218] RsvdMaskSize: 0 [ 78.218] RsvdFieldPosition: 0 [ 78.218] DirectColorModeInfo: 0 [ 78.218] PhysBasePtr: 0xcf000000 [ 78.218] LinBytesPerScanLine: 640 [ 78.218] BnkNumberOfImagePages: 14 [ 78.218] LinNumberOfImagePages: 14 [ 78.218] LinRedMaskSize: 5 [ 78.218] LinRedFieldPosition: 11 [ 78.218] LinGreenMaskSize: 6 [ 78.218] LinGreenFieldPosition: 5 [ 78.218] LinBlueMaskSize: 5 [ 78.218] LinBlueFieldPosition: 0 [ 78.218] LinRsvdMaskSize: 0 [ 78.218] LinRsvdFieldPosition: 0 [ 78.218] MaxPixelClock: 229500000 [ 78.220] *Mode: 133 (320x400) [ 78.220] ModeAttributes: 0x3bf [ 78.220] WinAAttributes: 0x7 [ 78.220] WinBAttributes: 0x0 [ 78.220] WinGranularity: 64 [ 78.220] WinSize: 64 [ 78.220] WinASegment: 0xa000 [ 78.220] WinBSegment: 0x0 [ 78.220] WinFuncPtr: 0xc0007d60 [ 78.220] BytesPerScanline: 1280 [ 78.220] XResolution: 320 [ 78.220] YResolution: 400 [ 78.220] XCharSize: 8 [ 78.220] YCharSize: 16 [ 78.220] NumberOfPlanes: 1 [ 78.220] BitsPerPixel: 32 [ 78.220] NumberOfBanks: 1 [ 78.220] MemoryModel: 6 [ 78.220] BankSize: 0 [ 78.220] NumberOfImages: 6 [ 78.220] RedMaskSize: 8 [ 78.220] RedFieldPosition: 16 [ 78.220] GreenMaskSize: 8 [ 78.220] GreenFieldPosition: 8 [ 78.220] BlueMaskSize: 8 [ 78.220] BlueFieldPosition: 0 [ 78.220] RsvdMaskSize: 8 [ 78.220] RsvdFieldPosition: 24 [ 78.220] DirectColorModeInfo: 0 [ 78.220] PhysBasePtr: 0xcf000000 [ 78.220] LinBytesPerScanLine: 1280 [ 78.220] BnkNumberOfImagePages: 6 [ 78.220] LinNumberOfImagePages: 6 [ 78.220] LinRedMaskSize: 8 [ 78.220] LinRedFieldPosition: 16 [ 78.220] LinGreenMaskSize: 8 [ 78.220] LinGreenFieldPosition: 8 [ 78.220] LinBlueMaskSize: 8 [ 78.220] LinBlueFieldPosition: 0 [ 78.220] LinRsvdMaskSize: 8 [ 78.220] LinRsvdFieldPosition: 24 [ 78.220] MaxPixelClock: 229500000 [ 78.222] Mode: 134 (320x240) [ 78.222] ModeAttributes: 0x3bf [ 78.222] WinAAttributes: 0x7 [ 78.222] WinBAttributes: 0x0 [ 78.222] WinGranularity: 64 [ 78.222] WinSize: 64 [ 78.222] WinASegment: 0xa000 [ 78.222] WinBSegment: 0x0 [ 78.222] WinFuncPtr: 0xc0007d60 [ 78.222] BytesPerScanline: 320 [ 78.222] XResolution: 320 [ 78.222] YResolution: 240 [ 78.222] XCharSize: 8 [ 78.222] YCharSize: 8 [ 78.222] NumberOfPlanes: 1 [ 78.222] BitsPerPixel: 8 [ 78.222] NumberOfBanks: 1 [ 78.222] MemoryModel: 4 [ 78.222] BankSize: 0 [ 78.222] NumberOfImages: 30 [ 78.222] RedMaskSize: 0 [ 78.222] RedFieldPosition: 0 [ 78.222] GreenMaskSize: 0 [ 78.222] GreenFieldPosition: 0 [ 78.222] BlueMaskSize: 0 [ 78.222] BlueFieldPosition: 0 [ 78.222] RsvdMaskSize: 0 [ 78.222] RsvdFieldPosition: 0 [ 78.222] DirectColorModeInfo: 0 [ 78.222] PhysBasePtr: 0xcf000000 [ 78.222] LinBytesPerScanLine: 320 [ 78.222] BnkNumberOfImagePages: 30 [ 78.222] LinNumberOfImagePages: 30 [ 78.222] LinRedMaskSize: 0 [ 78.222] LinRedFieldPosition: 0 [ 78.222] LinGreenMaskSize: 0 [ 78.222] LinGreenFieldPosition: 0 [ 78.222] LinBlueMaskSize: 0 [ 78.222] LinBlueFieldPosition: 0 [ 78.222] LinRsvdMaskSize: 0 [ 78.222] LinRsvdFieldPosition: 0 [ 78.222] MaxPixelClock: 229500000 [ 78.224] Mode: 135 (320x240) [ 78.224] ModeAttributes: 0x3bf [ 78.224] WinAAttributes: 0x7 [ 78.224] WinBAttributes: 0x0 [ 78.224] WinGranularity: 64 [ 78.224] WinSize: 64 [ 78.224] WinASegment: 0xa000 [ 78.224] WinBSegment: 0x0 [ 78.224] WinFuncPtr: 0xc0007d60 [ 78.224] BytesPerScanline: 640 [ 78.224] XResolution: 320 [ 78.224] YResolution: 240 [ 78.224] XCharSize: 8 [ 78.224] YCharSize: 8 [ 78.224] NumberOfPlanes: 1 [ 78.224] BitsPerPixel: 16 [ 78.224] NumberOfBanks: 1 [ 78.224] MemoryModel: 6 [ 78.224] BankSize: 0 [ 78.224] NumberOfImages: 19 [ 78.224] RedMaskSize: 5 [ 78.224] RedFieldPosition: 11 [ 78.224] GreenMaskSize: 6 [ 78.224] GreenFieldPosition: 5 [ 78.224] BlueMaskSize: 5 [ 78.224] BlueFieldPosition: 0 [ 78.224] RsvdMaskSize: 0 [ 78.224] RsvdFieldPosition: 0 [ 78.224] DirectColorModeInfo: 0 [ 78.224] PhysBasePtr: 0xcf000000 [ 78.224] LinBytesPerScanLine: 640 [ 78.224] BnkNumberOfImagePages: 19 [ 78.224] LinNumberOfImagePages: 19 [ 78.224] LinRedMaskSize: 5 [ 78.224] LinRedFieldPosition: 11 [ 78.224] LinGreenMaskSize: 6 [ 78.224] LinGreenFieldPosition: 5 [ 78.224] LinBlueMaskSize: 5 [ 78.224] LinBlueFieldPosition: 0 [ 78.224] LinRsvdMaskSize: 0 [ 78.224] LinRsvdFieldPosition: 0 [ 78.224] MaxPixelClock: 229500000 [ 78.226] *Mode: 136 (320x240) [ 78.226] ModeAttributes: 0x3bf [ 78.226] WinAAttributes: 0x7 [ 78.226] WinBAttributes: 0x0 [ 78.226] WinGranularity: 64 [ 78.226] WinSize: 64 [ 78.226] WinASegment: 0xa000 [ 78.226] WinBSegment: 0x0 [ 78.226] WinFuncPtr: 0xc0007d60 [ 78.226] BytesPerScanline: 1280 [ 78.226] XResolution: 320 [ 78.226] YResolution: 240 [ 78.226] XCharSize: 8 [ 78.226] YCharSize: 8 [ 78.226] NumberOfPlanes: 1 [ 78.226] BitsPerPixel: 32 [ 78.226] NumberOfBanks: 1 [ 78.226] MemoryModel: 6 [ 78.226] BankSize: 0 [ 78.226] NumberOfImages: 10 [ 78.226] RedMaskSize: 8 [ 78.226] RedFieldPosition: 16 [ 78.226] GreenMaskSize: 8 [ 78.226] GreenFieldPosition: 8 [ 78.226] BlueMaskSize: 8 [ 78.226] BlueFieldPosition: 0 [ 78.226] RsvdMaskSize: 8 [ 78.226] RsvdFieldPosition: 24 [ 78.226] DirectColorModeInfo: 0 [ 78.226] PhysBasePtr: 0xcf000000 [ 78.226] LinBytesPerScanLine: 1280 [ 78.226] BnkNumberOfImagePages: 10 [ 78.226] LinNumberOfImagePages: 10 [ 78.226] LinRedMaskSize: 8 [ 78.226] LinRedFieldPosition: 16 [ 78.226] LinGreenMaskSize: 8 [ 78.226] LinGreenFieldPosition: 8 [ 78.226] LinBlueMaskSize: 8 [ 78.226] LinBlueFieldPosition: 0 [ 78.226] LinRsvdMaskSize: 8 [ 78.226] LinRsvdFieldPosition: 24 [ 78.226] MaxPixelClock: 229500000 [ 78.228] Mode: 13d (640x400) [ 78.228] ModeAttributes: 0x3bf [ 78.228] WinAAttributes: 0x7 [ 78.228] WinBAttributes: 0x0 [ 78.228] WinGranularity: 64 [ 78.228] WinSize: 64 [ 78.228] WinASegment: 0xa000 [ 78.228] WinBSegment: 0x0 [ 78.228] WinFuncPtr: 0xc0007d60 [ 78.228] BytesPerScanline: 1280 [ 78.228] XResolution: 640 [ 78.228] YResolution: 400 [ 78.228] XCharSize: 8 [ 78.228] YCharSize: 16 [ 78.228] NumberOfPlanes: 1 [ 78.228] BitsPerPixel: 16 [ 78.228] NumberOfBanks: 1 [ 78.228] MemoryModel: 6 [ 78.228] BankSize: 0 [ 78.228] NumberOfImages: 6 [ 78.228] RedMaskSize: 5 [ 78.228] RedFieldPosition: 11 [ 78.228] GreenMaskSize: 6 [ 78.228] GreenFieldPosition: 5 [ 78.228] BlueMaskSize: 5 [ 78.228] BlueFieldPosition: 0 [ 78.228] RsvdMaskSize: 0 [ 78.228] RsvdFieldPosition: 0 [ 78.228] DirectColorModeInfo: 0 [ 78.228] PhysBasePtr: 0xcf000000 [ 78.228] LinBytesPerScanLine: 1280 [ 78.228] BnkNumberOfImagePages: 6 [ 78.228] LinNumberOfImagePages: 6 [ 78.228] LinRedMaskSize: 5 [ 78.228] LinRedFieldPosition: 11 [ 78.228] LinGreenMaskSize: 6 [ 78.228] LinGreenFieldPosition: 5 [ 78.228] LinBlueMaskSize: 5 [ 78.228] LinBlueFieldPosition: 0 [ 78.228] LinRsvdMaskSize: 0 [ 78.228] LinRsvdFieldPosition: 0 [ 78.228] MaxPixelClock: 229500000 [ 78.229] *Mode: 13e (640x400) [ 78.229] ModeAttributes: 0x3bf [ 78.229] WinAAttributes: 0x7 [ 78.229] WinBAttributes: 0x0 [ 78.229] WinGranularity: 64 [ 78.229] WinSize: 64 [ 78.229] WinASegment: 0xa000 [ 78.229] WinBSegment: 0x0 [ 78.229] WinFuncPtr: 0xc0007d60 [ 78.229] BytesPerScanline: 2560 [ 78.229] XResolution: 640 [ 78.230] YResolution: 400 [ 78.230] XCharSize: 8 [ 78.230] YCharSize: 16 [ 78.230] NumberOfPlanes: 1 [ 78.230] BitsPerPixel: 32 [ 78.230] NumberOfBanks: 1 [ 78.230] MemoryModel: 6 [ 78.230] BankSize: 0 [ 78.230] NumberOfImages: 2 [ 78.230] RedMaskSize: 8 [ 78.230] RedFieldPosition: 16 [ 78.230] GreenMaskSize: 8 [ 78.230] GreenFieldPosition: 8 [ 78.230] BlueMaskSize: 8 [ 78.230] BlueFieldPosition: 0 [ 78.230] RsvdMaskSize: 8 [ 78.230] RsvdFieldPosition: 24 [ 78.230] DirectColorModeInfo: 0 [ 78.230] PhysBasePtr: 0xcf000000 [ 78.230] LinBytesPerScanLine: 2560 [ 78.230] BnkNumberOfImagePages: 2 [ 78.230] LinNumberOfImagePages: 2 [ 78.230] LinRedMaskSize: 8 [ 78.230] LinRedFieldPosition: 16 [ 78.230] LinGreenMaskSize: 8 [ 78.230] LinGreenFieldPosition: 8 [ 78.230] LinBlueMaskSize: 8 [ 78.230] LinBlueFieldPosition: 0 [ 78.230] LinRsvdMaskSize: 8 [ 78.230] LinRsvdFieldPosition: 24 [ 78.230] MaxPixelClock: 229500000 [ 78.231] Mode: 14b (1920x1080) [ 78.231] ModeAttributes: 0x3bf [ 78.231] WinAAttributes: 0x7 [ 78.231] WinBAttributes: 0x0 [ 78.231] WinGranularity: 64 [ 78.231] WinSize: 64 [ 78.231] WinASegment: 0xa000 [ 78.231] WinBSegment: 0x0 [ 78.231] WinFuncPtr: 0xc0007d60 [ 78.231] BytesPerScanline: 1920 [ 78.231] XResolution: 1920 [ 78.231] YResolution: 1080 [ 78.231] XCharSize: 8 [ 78.231] YCharSize: 16 [ 78.231] NumberOfPlanes: 1 [ 78.231] BitsPerPixel: 8 [ 78.231] NumberOfBanks: 1 [ 78.231] MemoryModel: 4 [ 78.231] BankSize: 0 [ 78.231] NumberOfImages: 1 [ 78.231] RedMaskSize: 0 [ 78.231] RedFieldPosition: 0 [ 78.232] GreenMaskSize: 0 [ 78.232] GreenFieldPosition: 0 [ 78.232] BlueMaskSize: 0 [ 78.232] BlueFieldPosition: 0 [ 78.232] RsvdMaskSize: 0 [ 78.232] RsvdFieldPosition: 0 [ 78.232] DirectColorModeInfo: 0 [ 78.232] PhysBasePtr: 0xcf000000 [ 78.232] LinBytesPerScanLine: 1920 [ 78.232] BnkNumberOfImagePages: 1 [ 78.232] LinNumberOfImagePages: 1 [ 78.232] LinRedMaskSize: 0 [ 78.232] LinRedFieldPosition: 0 [ 78.232] LinGreenMaskSize: 0 [ 78.232] LinGreenFieldPosition: 0 [ 78.232] LinBlueMaskSize: 0 [ 78.232] LinBlueFieldPosition: 0 [ 78.232] LinRsvdMaskSize: 0 [ 78.232] LinRsvdFieldPosition: 0 [ 78.232] MaxPixelClock: 229500000 [ 78.233] Mode: 14c (1920x1080) [ 78.233] ModeAttributes: 0x3bf [ 78.233] WinAAttributes: 0x7 [ 78.233] WinBAttributes: 0x0 [ 78.233] WinGranularity: 64 [ 78.233] WinSize: 64 [ 78.233] WinASegment: 0xa000 [ 78.233] WinBSegment: 0x0 [ 78.233] WinFuncPtr: 0xc0007d60 [ 78.233] BytesPerScanline: 3840 [ 78.233] XResolution: 1920 [ 78.233] YResolution: 1080 [ 78.233] XCharSize: 8 [ 78.233] YCharSize: 16 [ 78.233] NumberOfPlanes: 1 [ 78.233] BitsPerPixel: 16 [ 78.233] NumberOfBanks: 1 [ 78.233] MemoryModel: 6 [ 78.233] BankSize: 0 [ 78.233] NumberOfImages: 1 [ 78.233] RedMaskSize: 5 [ 78.233] RedFieldPosition: 11 [ 78.233] GreenMaskSize: 6 [ 78.233] GreenFieldPosition: 5 [ 78.233] BlueMaskSize: 5 [ 78.233] BlueFieldPosition: 0 [ 78.233] RsvdMaskSize: 0 [ 78.233] RsvdFieldPosition: 0 [ 78.233] DirectColorModeInfo: 0 [ 78.233] PhysBasePtr: 0xcf000000 [ 78.233] LinBytesPerScanLine: 3840 [ 78.233] BnkNumberOfImagePages: 1 [ 78.233] LinNumberOfImagePages: 1 [ 78.234] LinRedMaskSize: 5 [ 78.234] LinRedFieldPosition: 11 [ 78.234] LinGreenMaskSize: 6 [ 78.234] LinGreenFieldPosition: 5 [ 78.234] LinBlueMaskSize: 5 [ 78.234] LinBlueFieldPosition: 0 [ 78.234] LinRsvdMaskSize: 0 [ 78.234] LinRsvdFieldPosition: 0 [ 78.234] MaxPixelClock: 229500000 [ 78.235] *Mode: 14d (1920x1080) [ 78.235] ModeAttributes: 0x3bf [ 78.235] WinAAttributes: 0x7 [ 78.235] WinBAttributes: 0x0 [ 78.235] WinGranularity: 64 [ 78.235] WinSize: 64 [ 78.235] WinASegment: 0xa000 [ 78.235] WinBSegment: 0x0 [ 78.235] WinFuncPtr: 0xc0007d60 [ 78.235] BytesPerScanline: 7680 [ 78.235] XResolution: 1920 [ 78.235] YResolution: 1080 [ 78.235] XCharSize: 8 [ 78.235] YCharSize: 16 [ 78.235] NumberOfPlanes: 1 [ 78.235] BitsPerPixel: 32 [ 78.235] NumberOfBanks: 1 [ 78.235] MemoryModel: 6 [ 78.235] BankSize: 0 [ 78.235] NumberOfImages: 1 [ 78.235] RedMaskSize: 8 [ 78.235] RedFieldPosition: 16 [ 78.235] GreenMaskSize: 8 [ 78.235] GreenFieldPosition: 8 [ 78.235] BlueMaskSize: 8 [ 78.235] BlueFieldPosition: 0 [ 78.235] RsvdMaskSize: 8 [ 78.235] RsvdFieldPosition: 24 [ 78.235] DirectColorModeInfo: 0 [ 78.235] PhysBasePtr: 0xcf000000 [ 78.235] LinBytesPerScanLine: 7680 [ 78.235] BnkNumberOfImagePages: 1 [ 78.235] LinNumberOfImagePages: 1 [ 78.235] LinRedMaskSize: 8 [ 78.235] LinRedFieldPosition: 16 [ 78.235] LinGreenMaskSize: 8 [ 78.235] LinGreenFieldPosition: 8 [ 78.235] LinBlueMaskSize: 8 [ 78.235] LinBlueFieldPosition: 0 [ 78.235] LinRsvdMaskSize: 8 [ 78.235] LinRsvdFieldPosition: 24 [ 78.235] MaxPixelClock: 229500000 [ 78.237] Mode: 160 (1280x800) [ 78.237] ModeAttributes: 0x3bf [ 78.237] WinAAttributes: 0x7 [ 78.237] WinBAttributes: 0x0 [ 78.237] WinGranularity: 64 [ 78.237] WinSize: 64 [ 78.237] WinASegment: 0xa000 [ 78.237] WinBSegment: 0x0 [ 78.237] WinFuncPtr: 0xc0007d60 [ 78.237] BytesPerScanline: 1280 [ 78.237] XResolution: 1280 [ 78.237] YResolution: 800 [ 78.237] XCharSize: 8 [ 78.237] YCharSize: 16 [ 78.237] NumberOfPlanes: 1 [ 78.237] BitsPerPixel: 8 [ 78.237] NumberOfBanks: 1 [ 78.237] MemoryModel: 4 [ 78.237] BankSize: 0 [ 78.237] NumberOfImages: 2 [ 78.237] RedMaskSize: 0 [ 78.237] RedFieldPosition: 0 [ 78.237] GreenMaskSize: 0 [ 78.237] GreenFieldPosition: 0 [ 78.237] BlueMaskSize: 0 [ 78.237] BlueFieldPosition: 0 [ 78.237] RsvdMaskSize: 0 [ 78.237] RsvdFieldPosition: 0 [ 78.237] DirectColorModeInfo: 0 [ 78.237] PhysBasePtr: 0xcf000000 [ 78.237] LinBytesPerScanLine: 1280 [ 78.237] BnkNumberOfImagePages: 2 [ 78.237] LinNumberOfImagePages: 2 [ 78.237] LinRedMaskSize: 0 [ 78.237] LinRedFieldPosition: 0 [ 78.237] LinGreenMaskSize: 0 [ 78.237] LinGreenFieldPosition: 0 [ 78.237] LinBlueMaskSize: 0 [ 78.237] LinBlueFieldPosition: 0 [ 78.237] LinRsvdMaskSize: 0 [ 78.237] LinRsvdFieldPosition: 0 [ 78.237] MaxPixelClock: 229500000 [ 78.239] *Mode: 161 (1280x800) [ 78.239] ModeAttributes: 0x3bf [ 78.239] WinAAttributes: 0x7 [ 78.239] WinBAttributes: 0x0 [ 78.239] WinGranularity: 64 [ 78.239] WinSize: 64 [ 78.239] WinASegment: 0xa000 [ 78.239] WinBSegment: 0x0 [ 78.239] WinFuncPtr: 0xc0007d60 [ 78.239] BytesPerScanline: 5120 [ 78.239] XResolution: 1280 [ 78.239] YResolution: 800 [ 78.239] XCharSize: 8 [ 78.239] YCharSize: 16 [ 78.239] NumberOfPlanes: 1 [ 78.239] BitsPerPixel: 32 [ 78.239] NumberOfBanks: 1 [ 78.239] MemoryModel: 6 [ 78.239] BankSize: 0 [ 78.239] NumberOfImages: 1 [ 78.239] RedMaskSize: 8 [ 78.239] RedFieldPosition: 16 [ 78.239] GreenMaskSize: 8 [ 78.239] GreenFieldPosition: 8 [ 78.239] BlueMaskSize: 8 [ 78.239] BlueFieldPosition: 0 [ 78.239] RsvdMaskSize: 8 [ 78.239] RsvdFieldPosition: 24 [ 78.239] DirectColorModeInfo: 0 [ 78.239] PhysBasePtr: 0xcf000000 [ 78.239] LinBytesPerScanLine: 5120 [ 78.239] BnkNumberOfImagePages: 1 [ 78.239] LinNumberOfImagePages: 1 [ 78.239] LinRedMaskSize: 8 [ 78.239] LinRedFieldPosition: 16 [ 78.239] LinGreenMaskSize: 8 [ 78.239] LinGreenFieldPosition: 8 [ 78.239] LinBlueMaskSize: 8 [ 78.239] LinBlueFieldPosition: 0 [ 78.239] LinRsvdMaskSize: 8 [ 78.239] LinRsvdFieldPosition: 24 [ 78.239] MaxPixelClock: 229500000 [ 78.239] [ 78.239] (II) VESA(0): Total Memory: 256 64KB banks (16384kB) [ 78.239] (II) VESA(0): <default monitor>: Using hsync range of 30.00-80.00 kHz [ 78.239] (II) VESA(0): <default monitor>: Using vrefresh range of 55.00-76.00 Hz [ 78.239] (II) VESA(0): <default monitor>: Using maximum pixel clock of 175.00 MHz [ 78.239] (WW) VESA(0): Unable to estimate virtual size [ 78.243] (II) VESA(0): Not using built-in mode "640x400" (no mode of this name) [ 78.243] (II) VESA(0): Not using built-in mode "320x400" (no mode of this name) [ 78.243] (II) VESA(0): Not using built-in mode "320x240" (no mode of this name) [ 78.243] (II) VESA(0): Not using built-in mode "320x200" (no mode of this name) [ 78.243] (--) VESA(0): Virtual size is 1920x1080 (pitch 1920) [ 78.243] (**) VESA(0): *Built-in mode "1920x1080" [ 78.243] (**) VESA(0): *Built-in mode "1280x1024" [ 78.243] (**) VESA(0): *Built-in mode "1280x800" [ 78.243] (**) VESA(0): *Built-in mode "1024x768" [ 78.243] (**) VESA(0): *Built-in mode "800x600" [ 78.243] (**) VESA(0): *Built-in mode "640x480" [ 78.243] (**) VESA(0): Display dimensions: (530, 300) mm [ 78.243] (**) VESA(0): DPI set to (92, 91) [ 78.243] (**) VESA(0): Using "Shadow Framebuffer" [ 78.243] (II) Loading sub module "shadow" [ 78.243] (II) LoadModule: "shadow" [ 78.243] (II) Loading /usr/lib64/xorg/modules/libshadow.so [ 78.243] (II) Module shadow: vendor="X.Org Foundation" [ 78.243] compiled for 1.19.5, module version = 1.1.0 [ 78.243] ABI class: X.Org ANSI C Emulation, version 0.4 [ 78.243] (II) Loading sub module "fb" [ 78.243] (II) LoadModule: "fb" [ 78.243] (II) Loading /usr/lib64/xorg/modules/libfb.so [ 78.244] (II) Module fb: vendor="X.Org Foundation" [ 78.244] compiled for 1.19.5, module version = 1.0.0 [ 78.244] ABI class: X.Org ANSI C Emulation, version 0.4 [ 78.244] (==) Depth 24 pixmap format is 32 bpp [ 78.244] (II) Loading sub module "int10" [ 78.244] (II) LoadModule: "int10" [ 78.244] (II) Loading /usr/lib64/xorg/modules/libint10.so [ 78.244] (II) Module int10: vendor="X.Org Foundation" [ 78.244] compiled for 1.19.5, module version = 1.0.0 [ 78.244] ABI class: X.Org Video Driver, version 23.0 [ 78.244] (II) VESA(0): initializing int10 [ 78.244] (II) VESA(0): Primary V_BIOS segment is: 0xc000 [ 78.310] (II) VESA(0): VESA BIOS detected [ 78.310] (II) VESA(0): VESA VBE Version 3.0 [ 78.310] (II) VESA(0): VESA VBE Total Mem: 16384 kB [ 78.310] (II) VESA(0): VESA VBE OEM: NVIDIA [ 78.310] (II) VESA(0): VESA VBE OEM Software Rev: 132.4 [ 78.310] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation [ 78.310] (II) VESA(0): VESA VBE OEM Product: GM204 Board [ 78.310] (II) VESA(0): VESA VBE OEM Product Rev: Chip Rev [ 78.310] (II) VESA(0): virtual address = 0x7f5ac8adc000, physical address = 0xcf000000, size = 16777216 [ 78.333] (II) VESA(0): Setting up VESA Mode 0x14D (1920x1080) [ 78.412] (==) VESA(0): Default visual is TrueColor [ 78.412] (==) VESA(0): Backing store enabled [ 78.412] (==) VESA(0): DPMS enabled [ 78.412] (==) RandR enabled [ 78.415] (II) SELinux: Disabled by boolean [ 78.416] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found) [ 78.466] (II) config/udev: Adding input device Power Button (/dev/input/event1) [ 78.466] (**) Power Button: Applying InputClass "evdev keyboard catchall" [ 78.466] (**) Power Button: Applying InputClass "libinput keyboard catchall" [ 78.467] (**) Power Button: Applying InputClass "system-keyboard" [ 78.467] (II) LoadModule: "libinput" [ 78.467] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so [ 78.473] (II) Module libinput: vendor="X.Org Foundation" [ 78.473] compiled for 1.19.3, module version = 0.26.0 [ 78.473] Module class: X.Org XInput Driver [ 78.473] ABI class: X.Org XInput driver, version 24.1 [ 78.473] (II) Using input driver 'libinput' for 'Power Button' [ 78.474] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 20 paused 0 [ 78.474] (**) Power Button: always reports core events [ 78.474] (**) Option "Device" "/dev/input/event1" [ 78.474] (**) Option "_source" "server/udev" [ 78.475] (II) event1 - (II) Power Button: (II) is tagged by udev as: Keyboard [ 78.475] (II) event1 - (II) Power Button: (II) device is a keyboard [ 78.475] (II) event1 - (II) Power Button: (II) device removed [ 78.475] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1" [ 78.475] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6) [ 78.475] (**) Option "xkb_layout" "gb,pl" [ 78.475] (**) Option "xkb_variant" "," [ 78.496] (II) event1 - (II) Power Button: (II) is tagged by udev as: Keyboard [ 78.496] (II) event1 - (II) Power Button: (II) device is a keyboard [ 78.497] (II) config/udev: Adding input device Power Button (/dev/input/event0) [ 78.497] (**) Power Button: Applying InputClass "evdev keyboard catchall" [ 78.497] (**) Power Button: Applying InputClass "libinput keyboard catchall" [ 78.497] (**) Power Button: Applying InputClass "system-keyboard" [ 78.497] (II) Using input driver 'libinput' for 'Power Button' [ 78.498] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 23 paused 0 [ 78.498] (**) Power Button: always reports core events [ 78.498] (**) Option "Device" "/dev/input/event0" [ 78.498] (**) Option "_source" "server/udev" [ 78.499] (II) event0 - (II) Power Button: (II) is tagged by udev as: Keyboard [ 78.499] (II) event0 - (II) Power Button: (II) device is a keyboard [ 78.499] (II) event0 - (II) Power Button: (II) device removed [ 78.499] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0" [ 78.499] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7) [ 78.499] (**) Option "xkb_layout" "gb,pl" [ 78.499] (**) Option "xkb_variant" "," [ 78.500] (II) event0 - (II) Power Button: (II) is tagged by udev as: Keyboard [ 78.500] (II) event0 - (II) Power Button: (II) device is a keyboard [ 78.500] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event4) [ 78.500] (II) No input driver specified, ignoring this device. [ 78.500] (II) This device may have been added with another device file. [ 78.501] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event5) [ 78.501] (II) No input driver specified, ignoring this device. [ 78.501] (II) This device may have been added with another device file. [ 78.502] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event6) [ 78.502] (II) No input driver specified, ignoring this device. [ 78.502] (II) This device may have been added with another device file. [ 78.502] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event7) [ 78.502] (II) No input driver specified, ignoring this device. [ 78.502] (II) This device may have been added with another device file. [ 78.503] (II) config/udev: Adding input device HDA Creative Line (/dev/input/event9) [ 78.503] (II) No input driver specified, ignoring this device. [ 78.503] (II) This device may have been added with another device file. [ 78.504] (II) config/udev: Adding input device HDA Creative Line Out Front (/dev/input/event10) [ 78.504] (II) No input driver specified, ignoring this device. [ 78.504] (II) This device may have been added with another device file. [ 78.504] (II) config/udev: Adding input device HDA Creative Line Out Surround (/dev/input/event11) [ 78.504] (II) No input driver specified, ignoring this device. [ 78.504] (II) This device may have been added with another device file. [ 78.505] (II) config/udev: Adding input device HDA Creative Line Out CLFE (/dev/input/event12) [ 78.505] (II) No input driver specified, ignoring this device. [ 78.505] (II) This device may have been added with another device file. [ 78.506] (II) config/udev: Adding input device HDA Creative Line Out Side (/dev/input/event13) [ 78.506] (II) No input driver specified, ignoring this device. [ 78.506] (II) This device may have been added with another device file. [ 78.506] (II) config/udev: Adding input device HDA Creative Front Headphone (/dev/input/event14) [ 78.506] (II) No input driver specified, ignoring this device. [ 78.506] (II) This device may have been added with another device file. [ 78.507] (II) config/udev: Adding input device HDA Creative Mic (/dev/input/event8) [ 78.507] (II) No input driver specified, ignoring this device. [ 78.507] (II) This device may have been added with another device file. [ 78.508] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event2) [ 78.508] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall" [ 78.508] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall" [ 78.508] (**) Logitech USB Receiver: Applying InputClass "system-keyboard" [ 78.508] (II) Using input driver 'libinput' for 'Logitech USB Receiver' [ 78.509] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 24 paused 0 [ 78.509] (**) Logitech USB Receiver: always reports core events [ 78.509] (**) Option "Device" "/dev/input/event2" [ 78.509] (**) Option "_source" "server/udev" [ 78.510] (II) event2 - (II) Logitech USB Receiver: (II) is tagged by udev as: Keyboard [ 78.510] (II) event2 - (II) Logitech USB Receiver: (II) device is a keyboard [ 78.510] (II) event2 - (II) Logitech USB Receiver: (II) device removed [ 78.510] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.1/usb7/7-1/7-1:1.0/0003:046D:C534.0001/input/input3/event2" [ 78.510] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 8) [ 78.510] (**) Option "xkb_layout" "gb,pl" [ 78.510] (**) Option "xkb_variant" "," [ 78.511] (II) event2 - (II) Logitech USB Receiver: (II) is tagged by udev as: Keyboard [ 78.511] (II) event2 - (II) Logitech USB Receiver: (II) device is a keyboard [ 78.512] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event3) [ 78.512] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall" [ 78.512] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall" [ 78.512] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall" [ 78.512] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall" [ 78.512] (**) Logitech USB Receiver: Applying InputClass "system-keyboard" [ 78.512] (II) Using input driver 'libinput' for 'Logitech USB Receiver' [ 78.513] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 25 paused 0 [ 78.513] (**) Logitech USB Receiver: always reports core events [ 78.513] (**) Option "Device" "/dev/input/event3" [ 78.513] (**) Option "_source" "server/udev" [ 78.514] (II) event3 - (II) Logitech USB Receiver: (II) is tagged by udev as: Keyboard Mouse [ 78.514] (II) event3 - (II) Logitech USB Receiver: (II) device is a pointer [ 78.514] (II) event3 - (II) Logitech USB Receiver: (II) device is a keyboard [ 78.514] (II) event3 - (II) Logitech USB Receiver: (II) device removed [ 78.514] (II) libinput: Logitech USB Receiver: needs a virtual subdevice [ 78.514] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.1/usb7/7-1/7-1:1.1/0003:046D:C534.0002/input/input4/event3" [ 78.514] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 9) [ 78.514] (**) Option "AccelerationScheme" "none" [ 78.514] (**) Logitech USB Receiver: (accel) selected scheme none/0 [ 78.514] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000 [ 78.514] (**) Logitech USB Receiver: (accel) acceleration threshold: 4 [ 78.515] (II) event3 - (II) Logitech USB Receiver: (II) is tagged by udev as: Keyboard Mouse [ 78.515] (II) event3 - (II) Logitech USB Receiver: (II) device is a pointer [ 78.515] (II) event3 - (II) Logitech USB Receiver: (II) device is a keyboard [ 78.516] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0) [ 78.516] (**) Logitech USB Receiver: Applying InputClass "system-keyboard" [ 78.516] (II) No input driver specified, ignoring this device. [ 78.516] (II) This device may have been added with another device file. [ 78.517] (II) config/udev: Adding input device FULL HD 1080P Webcam: FULL HD 1 (/dev/input/event15) [ 78.517] (**) FULL HD 1080P Webcam: FULL HD 1: Applying InputClass "evdev keyboard catchall" [ 78.517] (**) FULL HD 1080P Webcam: FULL HD 1: Applying InputClass "libinput keyboard catchall" [ 78.517] (**) FULL HD 1080P Webcam: FULL HD 1: Applying InputClass "system-keyboard" [ 78.517] (II) Using input driver 'libinput' for 'FULL HD 1080P Webcam: FULL HD 1' [ 78.518] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 26 paused 0 [ 78.518] (**) FULL HD 1080P Webcam: FULL HD 1: always reports core events [ 78.518] (**) Option "Device" "/dev/input/event15" [ 78.518] (**) Option "_source" "server/udev" [ 78.519] (II) event15 - (II) FULL HD 1080P Webcam: FULL HD 1: (II) is tagged by udev as: Keyboard [ 78.519] (II) event15 - (II) FULL HD 1080P Webcam: FULL HD 1: (II) device is a keyboard [ 78.519] (II) event15 - (II) FULL HD 1080P Webcam: FULL HD 1: (II) device removed [ 78.519] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.7/usb2/2-5/2-5:1.0/input/input16/event15" [ 78.519] (II) XINPUT: Adding extended input device "FULL HD 1080P Webcam: FULL HD 1" (type: KEYBOARD, id 10) [ 78.519] (**) Option "xkb_layout" "gb,pl" [ 78.519] (**) Option "xkb_variant" "," [ 78.520] (II) event15 - (II) FULL HD 1080P Webcam: FULL HD 1: (II) is tagged by udev as: Keyboard [ 78.520] (II) event15 - (II) FULL HD 1080P Webcam: FULL HD 1: (II) device is a keyboard [ 78.532] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall" [ 78.532] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall" [ 78.532] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall" [ 78.532] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall" [ 78.532] (**) Logitech USB Receiver: Applying InputClass "system-keyboard" [ 78.532] (II) Using input driver 'libinput' for 'Logitech USB Receiver' [ 78.532] (II) systemd-logind: returning pre-existing fd for /dev/input/event3 13:67 [ 78.532] (**) Logitech USB Receiver: always reports core events [ 78.532] (**) Option "Device" "/dev/input/event3" [ 78.532] (**) Option "_source" "_driver/libinput" [ 78.532] (II) libinput: Logitech USB Receiver: is a virtual subdevice [ 78.532] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.1/usb7/7-1/7-1:1.1/0003:046D:C534.0002/input/input4/event3" [ 78.532] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 11) [ 78.532] (**) Option "xkb_layout" "gb,pl" [ 78.532] (**) Option "xkb_variant" "," [ 79.277] (**) Option "fd" "20" [ 79.277] (II) event1 - (II) Power Button: (II) device removed [ 79.277] (**) Option "fd" "23" [ 79.277] (II) event0 - (II) Power Button: (II) device removed [ 79.277] (**) Option "fd" "24" [ 79.277] (II) event2 - (II) Logitech USB Receiver: (II) device removed [ 79.278] (**) Option "fd" "25" [ 79.278] (**) Option "fd" "26" [ 79.278] (II) event15 - (II) FULL HD 1080P Webcam: FULL HD 1: (II) device removed [ 79.278] (**) Option "fd" "25" [ 79.278] (II) event3 - (II) Logitech USB Receiver: (II) device removed [ 79.279] (II) UnloadModule: "libinput" [ 79.279] (II) systemd-logind: not releasing fd for 13:67, still in use [ 79.279] (II) UnloadModule: "libinput" [ 79.279] (II) systemd-logind: releasing fd for 13:79 [ 79.287] (II) UnloadModule: "libinput" [ 79.287] (II) systemd-logind: releasing fd for 13:67 [ 79.297] (II) UnloadModule: "libinput" [ 79.297] (II) systemd-logind: releasing fd for 13:66 [ 79.301] (II) UnloadModule: "libinput" [ 79.301] (II) systemd-logind: releasing fd for 13:64 [ 79.306] (II) UnloadModule: "libinput" [ 79.306] (II) systemd-logind: releasing fd for 13:65 [ 79.496] (II) Server terminated successfully (0). Closing log file. a to dla sterownika 384 ze strony nVidia: [ 201.335] (--) Log file renamed from "/var/log/Xorg.pid-16564.log" to "/var/log/Xorg.0.log" [ 201.336] X.Org X Server 1.19.5 Release Date: 2017-10-12 [ 201.336] X Protocol Version 11, Revision 0 [ 201.336] Build Operating System: 4.12.9-300.fc26.x86_64 [ 201.336] Current Operating System: Linux localhost.localdomain 4.14.11-300.fc27.x86_64 #1 SMP Wed Jan 3 13:52:28 UTC 2018 x86_64 [ 201.336] Kernel command line: BOOT_IMAGE=/vmlinuz-4.14.11-300.fc27.x86_64 root=/dev/mapper/fedora-root ro rd.lvm.lv=fedora/root rd.lvm.lv=fedora/swap rhgb quiet LANG=pl_PL.UTF-8 [ 201.336] Build Date: 12 October 2017 07:35:27PM [ 201.336] Build ID: xorg-x11-server 1.19.5-1.fc27 [ 201.336] Current version of pixman: 0.34.0 [ 201.336] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 201.336] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 201.336] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 4 13:00:40 2018 [ 201.337] (==) Using config file: "/etc/X11/xorg.conf" [ 201.337] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 201.337] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 201.337] (==) ServerLayout "Layout0" [ 201.337] (**) |-->Screen "Screen0" (0) [ 201.337] (**) | |-->Monitor "Monitor0" [ 201.337] (**) | |-->Device "Device0" [ 201.337] (**) |-->Input Device "Keyboard0" [ 201.337] (**) |-->Input Device "Mouse0" [ 201.337] (==) Automatically adding devices [ 201.337] (==) Automatically enabling devices [ 201.337] (==) Automatically adding GPU devices [ 201.337] (==) Automatically binding GPU devices [ 201.337] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 201.337] (==) FontPath set to: catalogue:/etc/X11/fontpath.d, built-ins [ 201.337] (==) ModulePath set to "/usr/lib64/xorg/modules" [ 201.337] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled. [ 201.337] (WW) Disabling Keyboard0 [ 201.337] (WW) Disabling Mouse0 [ 201.337] (II) Loader magic: 0x821e00 [ 201.337] (II) Module ABI versions: [ 201.337] X.Org ANSI C Emulation: 0.4 [ 201.337] X.Org Video Driver: 23.0 [ 201.337] X.Org XInput driver : 24.1 [ 201.337] X.Org Server Extension : 10.0 [ 201.339] (++) using VT number 1 [ 201.342] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c503 [ 201.344] (--) PCI:*(0:1:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xfd000000/16777216, 0xd0000000/268435456, 0xce000000/33554432, I/O @ 0x0000ac00/128, BIOS @ 0x????????/131072 [ 201.344] (II) LoadModule: "glx" [ 201.345] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so [ 201.351] (II) Module glx: vendor="NVIDIA Corporation" [ 201.351] compiled for 4.0.2, module version = 1.0.0 [ 201.351] Module class: X.Org Server Extension [ 201.351] (II) NVIDIA GLX Module 384.98 Thu Oct 26 14:35:55 PDT 2017 [ 201.351] (II) LoadModule: "nvidia" [ 201.351] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so [ 201.352] (II) Module nvidia: vendor="NVIDIA Corporation" [ 201.352] compiled for 4.0.2, module version = 1.0.0 [ 201.352] Module class: X.Org Video Driver [ 201.352] (II) NVIDIA dlloader X Driver 384.98 Thu Oct 26 14:06:45 PDT 2017 [ 201.352] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs [ 201.352] (II) Loading sub module "fb" [ 201.352] (II) LoadModule: "fb" [ 201.352] (II) Loading /usr/lib64/xorg/modules/libfb.so [ 201.352] (II) Module fb: vendor="X.Org Foundation" [ 201.352] compiled for 1.19.5, module version = 1.0.0 [ 201.353] ABI class: X.Org ANSI C Emulation, version 0.4 [ 201.353] (II) Loading sub module "wfb" [ 201.353] (II) LoadModule: "wfb" [ 201.353] (II) Loading /usr/lib64/xorg/modules/libwfb.so [ 201.353] (II) Module wfb: vendor="X.Org Foundation" [ 201.353] compiled for 1.19.5, module version = 1.0.0 [ 201.353] ABI class: X.Org ANSI C Emulation, version 0.4 [ 201.353] (II) Loading sub module "ramdac" [ 201.353] (II) LoadModule: "ramdac" [ 201.353] (II) Module "ramdac" already built-in [ 201.360] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the [ 201.360] (EE) NVIDIA: system's kernel log for additional error messages and [ 201.360] (EE) NVIDIA: consult the NVIDIA README for details. [ 201.360] (EE) No devices detected. [ 201.360] (EE) Fatal server error: [ 201.360] (EE) no screens found(EE) [ 201.360] (EE) Please consult the Fedora Project support at http://wiki.x.org for help. [ 201.360] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information. [ 201.360] (EE) [ 201.361] (EE) Server terminated with error (1). Closing log file. Nie próbowałem instalacji sterowników z repo na jajku 4.14.8-300 ale wydaje mi się że pewnie by działały. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Styczeń 6, 2018 Zgłoszenie Share Napisano Styczeń 6, 2018 Wkleiłeś kupę śmiecia a co tam słychać dalej? [ 201.360] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the [ 201.360] (EE) NVIDIA: system's kernel log for additional error messages and [ 201.360] (EE) NVIDIA: consult the NVIDIA README for details. [ 201.360] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
zibi743 Napisano Styczeń 7, 2018 Zgłoszenie Share Napisano Styczeń 7, 2018 20 hours ago, alastis said: Niestety strona nie jest dostępna dla mojego konta... Ciesze się niestety u mnie dalej trudności Tak czy inaczej próbowałem reinstalować sterowniki z strony i pomimo że na 4.14.8-300 wszystko ładnie działa to na 4.14.11-300 instalator wywala mi błędy: A tu zawartość pliku make.log: DKMS make.log for nvidia-384.98 for kernel 4.14.11-300.fc27.x86_64 (x86_64) sob, 6 sty 2018, 18:30:51 GMT make "CC=cc" KBUILD_OUTPUT=/lib/modules/4.14.11-300.fc27.x86_64/build KBUILD_VERBOSE= -C /lib/modules/4.14.11-300.fc27.x86_64/source M=/var/lib/dkms/nvidia/384.98/build ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.14.11-300.fc27.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/4.14.11-300.fc27.x86_64/build NV_KERNEL_MODULES="nvidia nvidia-uvm nvidia-modeset nvidia-drm" INSTALL_MOD_DIR=kernel/drivers/video modules make[1]: Wejście do katalogu '/usr/src/kernels/4.14.11-300.fc27.x86_64' make[2]: Wejście do katalogu '/usr/src/kernels/4.14.11-300.fc27.x86_64' SYMLINK /var/lib/dkms/nvidia/384.98/build/nvidia/nv-kernel.o SYMLINK /var/lib/dkms/nvidia/384.98/build/nvidia-modeset/nv-modeset-kernel.o CONFTEST: remap_pfn_range CONFTEST: INIT_WORK CONFTEST: hash__remap_4k_pfn CONFTEST: follow_pfn CONFTEST: vmap CONFTEST: set_pages_uc CONFTEST: set_memory_uc CONFTEST: set_memory_array_uc CONFTEST: change_page_attr CONFTEST: pci_get_class CONFTEST: pci_choose_state CONFTEST: vm_insert_page CONFTEST: acpi_device_id CONFTEST: acquire_console_sem CONFTEST: kmem_cache_create CONFTEST: console_lock CONFTEST: on_each_cpu CONFTEST: acpi_evaluate_integer CONFTEST: smp_call_function CONFTEST: ioremap_cache CONFTEST: ioremap_wc CONFTEST: acpi_walk_namespace CONFTEST: pci_domain_nr CONFTEST: pci_dma_mapping_error CONFTEST: sg_alloc_table CONFTEST: sg_init_table CONFTEST: pci_get_domain_bus_and_slot CONFTEST: get_num_physpages CONFTEST: efi_enabled CONFTEST: proc_create_data CONFTEST: pde_data CONFTEST: proc_remove CONFTEST: pm_vt_switch_required CONFTEST: xen_ioemu_inject_msi CONFTEST: phys_to_dma CONFTEST: get_dma_ops CONFTEST: write_cr4 CONFTEST: of_get_property CONFTEST: of_find_node_by_phandle CONFTEST: of_node_to_nid CONFTEST: pnv_pci_get_npu_dev CONFTEST: for_each_online_node CONFTEST: node_end_pfn CONFTEST: pci_bus_address CONFTEST: pci_stop_and_remove_bus_device CONFTEST: pci_remove_bus_device CONFTEST: request_threaded_irq CONFTEST: register_cpu_notifier CONFTEST: cpuhp_setup_state CONFTEST: remap_page_range CONFTEST: address_space_init_once CONFTEST: kbasename CONFTEST: fatal_signal_pending CONFTEST: list_cut_position CONFTEST: vzalloc CONFTEST: wait_on_bit_lock_argument_count CONFTEST: bitmap_clear CONFTEST: usleep_range CONFTEST: radix_tree_empty CONFTEST: drm_dev_unref CONFTEST: drm_reinit_primary_mode_group CONFTEST: drm_atomic_set_mode_for_crtc CONFTEST: drm_atomic_clean_old_fb CONFTEST: get_user_pages_remote CONFTEST: drm_gem_object_lookup CONFTEST: drm_atomic_state_free CONFTEST: drm_driver_has_gem_prime_res_obj CONFTEST: is_export_symbol_gpl_of_node_to_nid CONFTEST: i2c_adapter CONFTEST: pm_message_t CONFTEST: irq_handler_t CONFTEST: acpi_device_ops CONFTEST: acpi_op_remove CONFTEST: outer_flush_all CONFTEST: proc_dir_entry CONFTEST: scatterlist CONFTEST: sg_table CONFTEST: file_operations CONFTEST: vm_operations_struct CONFTEST: atomic_long_type CONFTEST: pci_save_state CONFTEST: file_inode CONFTEST: task_struct CONFTEST: kuid_t CONFTEST: dma_ops CONFTEST: dma_map_ops CONFTEST: noncoherent_swiotlb_dma_ops CONFTEST: vm_fault_present CONFTEST: vm_fault_has_address CONFTEST: kernel_write CONFTEST: strnstr CONFTEST: iterate_dir CONFTEST: kstrtoull CONFTEST: fault_flags CONFTEST: atomic64_type CONFTEST: address_space CONFTEST: backing_dev_info CONFTEST: mm_context_t CONFTEST: vm_ops_fault_removed_vma_arg CONFTEST: pnv_npu2_init_context CONFTEST: drm_bus_present CONFTEST: drm_bus_has_bus_type CONFTEST: drm_bus_has_get_irq CONFTEST: drm_bus_has_get_name CONFTEST: drm_driver_has_legacy_dev_list CONFTEST: drm_driver_has_set_busid CONFTEST: drm_crtc_state_has_connectors_changed CONFTEST: drm_init_function_args CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg CONFTEST: drm_helper_mode_fill_fb_struct CONFTEST: drm_master_drop_has_from_release_arg CONFTEST: drm_mode_config_funcs_has_atomic_state_alloc CONFTEST: drm_driver_unload_has_int_return_type CONFTEST: drm_crtc_helper_funcs_has_atomic_enable CONFTEST: dom0_kernel_present CONFTEST: nvidia_vgpu_kvm_build CONFTEST: nvidia_grid_build CONFTEST: drm_available CONFTEST: drm_atomic_available CONFTEST: drm_atomic_modeset_nonblocking_commit_available CONFTEST: is_export_symbol_gpl_refcount_inc CONFTEST: is_export_symbol_gpl_refcount_dec_and_test CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-frontend.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-instance.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gpu-numa.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv.o /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gpu-numa.c: In function ‘bad_idea_read_string_from_file’: /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gpu-numa.c:123:39: warning: passing argument 3 of ‘kernel_read’ makes integer from pointer without a cast [-Wint-conversion] read_count = kernel_read(filp, 0, read_buffer, read_buffer_size - 1); ^~~~~~~~~~~ In file included from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/huge_mm.h:7:0, from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/mm.h:453, from /var/lib/dkms/nvidia/384.98/build/common/inc/nv-pgprot.h:17, from /var/lib/dkms/nvidia/384.98/build/common/inc/nv-linux.h:20, from /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gpu-numa.c:24: /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/fs.h:2823:16: note: expected ‘size_t {aka long unsigned int}’ but argument is of type ‘char *’ extern ssize_t kernel_read(struct file *, void *, size_t, loff_t *); ^~~~~~~~~~~ /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gpu-numa.c:123:52: warning: passing argument 4 of ‘kernel_read’ makes pointer from integer without a cast [-Wint-conversion] read_count = kernel_read(filp, 0, read_buffer, read_buffer_size - 1); ^~~~~~~~~~~~~~~~ In file included from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/huge_mm.h:7:0, from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/mm.h:453, from /var/lib/dkms/nvidia/384.98/build/common/inc/nv-pgprot.h:17, from /var/lib/dkms/nvidia/384.98/build/common/inc/nv-linux.h:20, from /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gpu-numa.c:24: /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/fs.h:2823:16: note: expected ‘loff_t * {aka long long int *}’ but argument is of type ‘size_t {aka long unsigned int}’ extern ssize_t kernel_read(struct file *, void *, size_t, loff_t *); ^~~~~~~~~~~ CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-acpi.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-chrdev.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-cray.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-dma.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-gvi.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-i2c.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-mempool.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-mmap.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-p2p.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-pat.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-procfs.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-usermap.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-vm.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-vtophys.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/os-interface.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/os-mlock.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/os-pci.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/os-registry.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/os-usermap.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-modeset-interface.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-pci-table.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-kthread-q.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-kthread-q-selftest.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-memdbg.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv-report-err.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nv_uvm_interface.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia/nvlink_linux.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_volta_host.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_volta.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_volta_fault_buffer.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_volta_access_counter_buffer.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_gpu_non_replayable_faults.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_gpu_access_counters.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm_utils.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm_common.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm_linux.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/nvstatus.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_tools.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_global.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_gpu.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_gpu_isr.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_procfs.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_va_space.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_gpu_semaphore.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_mem.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_rm_mem.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_channel.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_lock.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_hal.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_range_tree.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_range_allocator.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_va_range.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_va_block.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_range_group.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_gpu_replayable_faults.o In file included from /usr/src/kernels/4.14.11-300.fc27.x86_64/arch/x86/include/asm/cpufeature.h:5:0, from /usr/src/kernels/4.14.11-300.fc27.x86_64/arch/x86/include/asm/thread_info.h:53, from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/thread_info.h:38, from /usr/src/kernels/4.14.11-300.fc27.x86_64/arch/x86/include/asm/preempt.h:7, from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/preempt.h:81, from /usr/src/kernels/4.14.11-300.fc27.x86_64/include/linux/spinlock.h:51, from /var/lib/dkms/nvidia/384.98/build/common/inc/nv-lock.h:16, from /var/lib/dkms/nvidia/384.98/build/common/inc/nv-linux.h:19, from /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm_linux.h:39, from /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_va_block.c:24: /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_va_block.c: In function ‘block_cpu_fault_locked’: /usr/src/kernels/4.14.11-300.fc27.x86_64/arch/x86/include/asm/processor.h:826:39: error: implicit declaration of function ‘task_stack_page’; did you mean ‘task_stack_vm_area’? [-Werror=implicit-function-declaration] unsigned long __ptr = (unsigned long)task_stack_page(task); \ ^ /usr/src/kernels/4.14.11-300.fc27.x86_64/arch/x86/include/asm/processor.h:909:26: note: in expansion of macro ‘task_pt_regs’ #define KSTK_EIP(task) (task_pt_regs(task)->ip) ^~~~~~~~~~~~ /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_va_block.c:8771:41: note: in expansion of macro ‘KSTK_EIP’ KSTK_EIP(current)); ^~~~~~~~ CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_perf_events.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_perf_module.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_mmu.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_pte_batch.o CC [M] /var/lib/dkms/nvidia/384.98/build/nvidia-uvm/uvm8_tlb_batch.o jeszcze plik nvidia-installer.log: nvidia-installer log file '/var/log/nvidia-installer.log' creation time: Sat Jan 6 00:05:59 2018 installer version: 384.98 PATH: /usr/local/sbin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin nvidia-installer command line: ./nvidia-installer Using: nvidia-installer ncurses v6 user interface -> Detected 4 CPUs online; setting concurrency level to 4. -> Tagging shared libraries with chcon -t textrel_shlib_t. -> License accepted. -> Installing NVIDIA driver version 384.98. -> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes) -> Installing both new and classic TLS OpenGL libraries. -> Installing both new and classic TLS 32bit OpenGL libraries. -> Install NVIDIA's 32-bit compatibility libraries? (Answer: Yes) -> Will install GLVND GLX client libraries. -> Will install GLVND EGL client libraries. -> Skipping GLX non-GLVND file: "libGL.so.384.98" -> Skipping GLX non-GLVND file: "libGL.so.1" -> Skipping GLX non-GLVND file: "libGL.so" -> Skipping EGL non-GLVND file: "libEGL.so.384.98" -> Skipping EGL non-GLVND file: "libEGL.so" -> Skipping EGL non-GLVND file: "libEGL.so.1" -> Skipping GLX non-GLVND file: "./32/libGL.so.384.98" -> Skipping GLX non-GLVND file: "libGL.so.1" -> Skipping GLX non-GLVND file: "libGL.so" -> Skipping EGL non-GLVND file: "./32/libEGL.so.384.98" -> Skipping EGL non-GLVND file: "libEGL.so" -> Skipping EGL non-GLVND file: "libEGL.so.1" Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh executing: '/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh'... Checking for libglvnd installation. Checking libGLdispatch... Checking libGLdispatch dispatch table Checking call through libGLdispatch All OK libGLdispatch is OK Checking for libGLX libGLX is OK Checking for libEGL libEGL is OK Checking entrypoint library libOpenGL.so.0 Checking call through libGLdispatch Checking call through library libOpenGL.so.0 All OK Entrypoint library libOpenGL.so.0 is OK Checking entrypoint library libGL.so.1 Checking call through libGLdispatch Checking call through library libGL.so.1 All OK Entrypoint library libGL.so.1 is OK libglvnd appears to be installed. Will not install libglvnd libraries. -> Skipping GLVND file: "libOpenGL.so.0" -> Skipping GLVND file: "libOpenGL.so" -> Skipping GLVND file: "libGLESv1_CM.so.1" -> Skipping GLVND file: "libGLESv1_CM.so" -> Skipping GLVND file: "libGLESv2.so.2" -> Skipping GLVND file: "libGLESv2.so" -> Skipping GLVND file: "libGLdispatch.so.0" -> Skipping GLVND file: "libGLX.so.0" -> Skipping GLVND file: "libGLX.so" -> Skipping GLVND file: "libGL.so.1.0.0" -> Skipping GLVND file: "libGL.so.1" -> Skipping GLVND file: "libGL.so" -> Skipping GLVND file: "libEGL.so.1" -> Skipping GLVND file: "libEGL.so" -> Skipping GLVND file: "./32/libOpenGL.so.0" -> Skipping GLVND file: "libOpenGL.so" -> Skipping GLVND file: "./32/libGLdispatch.so.0" -> Skipping GLVND file: "./32/libGLESv2.so.2" -> Skipping GLVND file: "libGLESv2.so" -> Skipping GLVND file: "./32/libGLESv1_CM.so.1" -> Skipping GLVND file: "libGLESv1_CM.so" -> Skipping GLVND file: "./32/libGL.so.1.0.0" -> Skipping GLVND file: "libGL.so.1" -> Skipping GLVND file: "libGL.so" -> Skipping GLVND file: "./32/libGLX.so.0" -> Skipping GLVND file: "libGLX.so" -> Skipping GLVND file: "./32/libEGL.so.1" -> Skipping GLVND file: "libEGL.so" Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d -> Searching for conflicting files: -> done. -> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (384.98): executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-glcore.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/extensions/libglx.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-tls.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/tls/libnvidia-tls.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLX_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/drivers/nvidia_drv.so'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/libnvidia-wfb.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-gtk2.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-gtk3.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-cfg.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ml.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/vdpau/libvdpau_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libcuda.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-opencl.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libOpenCL.so.1.0.0'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-fatbinaryloader.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ptxjitcompiler.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvcuvid.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-encode.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ifr.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-fbc.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-compiler.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-eglcore.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-glsi.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libEGL_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLESv2_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLESv1_CM_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-egl-wayland.so.1.0.1'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libcuda.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-fatbinaryloader.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ptxjitcompiler.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ml.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libOpenCL.so.1.0.0'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-compiler.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-opencl.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLX_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-glcore.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-tls.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/tls/libnvidia-tls.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/vdpau/libvdpau_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvcuvid.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-encode.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-eglcore.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-glsi.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libEGL_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLESv2_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLESv1_CM_nvidia.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ifr.so.384.98'... executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-fbc.so.384.98'... executing: '/sbin/ldconfig'... -> done. -> Driver file installation is complete. -> Installing DKMS kernel module: ERROR: Failed to run `/sbin/dkms build -m nvidia -v 384.98 -k 4.14.11-300.fc27.x86_64`: Kernel preparation unnecessary for this kernel. Skipping... Building module: cleaning build area... 'make' -j4 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=4.14.11-300.fc27.x86_64 modules..........(bad exit status: 2) Error! Bad return status for module build on kernel: 4.14.11-300.fc27.x86_64 (x86_64) Consult /var/lib/dkms/nvidia/384.98/build/make.log for more information. -> error. ERROR: Failed to install the kernel module through DKMS. No kernel module was installed; please try installing again without DKMS, or check the DKMS logs for more information. ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com. Więc niestety poległem W repo posiadam tylko sterowniki w wersji 304xx oraz 340xx, które instalują sie bez problemowo jednak nie można uruchomić trybu graficznego podczas polecenia startx mam błąd dla sterowniki z repo 340xx: [ 77.815] X.Org X Server 1.19.5 Release Date: 2017-10-12 [ 77.816] X Protocol Version 11, Revision 0 [ 77.816] Build Operating System: 4.12.9-300.fc26.x86_64 [ 77.816] Current Operating System: Linux localhost.localdomain 4.14.11-300.fc27.x86_64 #1 SMP Wed Jan 3 13:52:28 UTC 2018 x86_64 [ 77.816] Kernel command line: BOOT_IMAGE=/vmlinuz-4.14.11-300.fc27.x86_64 root=/dev/mapper/fedora-root ro rd.lvm.lv=fedora/root rd.lvm.lv=fedora/swap rhgb quiet nouveau.modeset=0 rd.driver.blacklist=nouveau video=vesa:off [ 77.816] Build Date: 12 October 2017 07:35:27PM [ 77.816] Build ID: xorg-x11-server 1.19.5-1.fc27 [ 77.816] Current version of pixman: 0.34.0 [ 77.817] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 77.817] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 77.817] (==) Log file: "/var/log/Xorg.1.log", Time: Sat Jan 6 00:34:07 2018 [ 77.818] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 77.818] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 77.818] (==) No Layout section. Using the first Screen section. [ 77.818] (==) No screen section available. Using defaults. [ 77.818] (**) |-->Screen "Default Screen Section" (0) [ 77.818] (**) | |-->Monitor "<default monitor>" [ 77.818] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 77.818] (==) Automatically adding devices [ 77.818] (==) Automatically enabling devices [ 77.818] (==) Automatically adding GPU devices [ 77.818] (==) Automatically binding GPU devices [ 77.818] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 77.818] (==) FontPath set to: catalogue:/etc/X11/fontpath.d, built-ins [ 77.818] (**) ModulePath set to "/usr/lib64/nvidia-340xx/xorg,/usr/lib64/xorg/modules" [ 77.818] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 77.818] (II) Loader magic: 0x821e00 [ 77.818] (II) Module ABI versions: [ 77.818] X.Org ANSI C Emulation: 0.4 [ 77.818] X.Org Video Driver: 23.0 [ 77.818] X.Org XInput driver : 24.1 [ 77.818] X.Org Server Extension : 10.0 [ 77.820] (++) using VT number 2 [ 77.824] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_34 [ 77.826] (--) PCI:*(0:1:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xfd000000/16777216, 0xd0000000/268435456, 0xce000000/33554432, I/O @ 0x0000ac00/128, BIOS @ 0x????????/131072 [ 77.827] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere. [ 77.827] (II) "glx" will be loaded by default. [ 77.827] (II) LoadModule: "glx" [ 77.827] (II) Loading /usr/lib64/nvidia-340xx/xorg/libglx.so [ 77.841] (II) Module glx: vendor="NVIDIA Corporation" [ 77.841] compiled for 4.0.2, module version = 1.0.0 [ 77.841] Module class: X.Org Server Extension [ 77.841] (II) NVIDIA GLX Module 340.104 Thu Sep 14 16:40:42 PDT 2017 [ 77.966] (==) Matched nouveau as autoconfigured driver 0 [ 77.966] (==) Matched nv as autoconfigured driver 1 [ 77.966] (==) Matched modesetting as autoconfigured driver 2 [ 77.966] (==) Matched fbdev as autoconfigured driver 3 [ 77.966] (==) Matched vesa as autoconfigured driver 4 [ 77.966] (==) Assigned the driver to the xf86ConfigLayout [ 77.966] (II) LoadModule: "nouveau" [ 77.966] (WW) Warning, couldn't open module nouveau [ 77.966] (II) UnloadModule: "nouveau" [ 77.966] (II) Unloading nouveau [ 77.966] (EE) Failed to load module "nouveau" (module does not exist, 0) [ 77.966] (II) LoadModule: "nv" [ 77.966] (WW) Warning, couldn't open module nv [ 77.966] (II) UnloadModule: "nv" [ 77.966] (II) Unloading nv [ 77.966] (EE) Failed to load module "nv" (module does not exist, 0) [ 77.967] (II) LoadModule: "modesetting" [ 77.967] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so [ 77.967] (II) Module modesetting: vendor="X.Org Foundation" [ 77.967] compiled for 1.19.5, module version = 1.19.5 [ 77.967] Module class: X.Org Video Driver [ 77.967] ABI class: X.Org Video Driver, version 23.0 [ 77.967] (II) LoadModule: "fbdev" [ 77.967] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so [ 77.967] (II) Module fbdev: vendor="X.Org Foundation" [ 77.967] compiled for 1.19.3, module version = 0.4.3 [ 77.967] Module class: X.Org Video Driver [ 77.967] ABI class: X.Org Video Driver, version 23.0 [ 77.967] (II) LoadModule: "vesa" [ 77.968] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so [ 77.968] (II) Module vesa: vendor="X.Org Foundation" [ 77.968] compiled for 1.19.3, module version = 2.3.2 [ 77.968] Module class: X.Org Video Driver [ 77.968] ABI class: X.Org Video Driver, version 23.0 [ 77.968] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 77.968] (II) FBDEV: driver for framebuffer: fbdev [ 77.968] (II) VESA: driver for VESA chipsets: vesa [ 77.968] (EE) open /dev/dri/card0: No such file or directory [ 77.968] (WW) Falling back to old probe method for modesetting [ 77.968] (EE) open /dev/dri/card0: No such file or directory [ 77.968] (II) Loading sub module "fbdevhw" [ 77.968] (II) LoadModule: "fbdevhw" [ 77.968] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so [ 77.968] (II) Module fbdevhw: vendor="X.Org Foundation" [ 77.968] compiled for 1.19.5, module version = 0.0.2 [ 77.968] ABI class: X.Org Video Driver, version 23.0 [ 77.968] (EE) open /dev/fb0: No such file or directory [ 77.968] (WW) Falling back to old probe method for fbdev [ 77.968] (II) Loading sub module "fbdevhw" [ 77.968] (II) LoadModule: "fbdevhw" [ 77.968] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so [ 77.968] (II) Module fbdevhw: vendor="X.Org Foundation" [ 77.968] compiled for 1.19.5, module version = 0.0.2 [ 77.968] ABI class: X.Org Video Driver, version 23.0 [ 77.968] (EE) open /dev/fb0: No such file or directory [ 77.969] (EE) Screen 0 deleted because of no matching config section. [ 77.969] (II) UnloadModule: "modesetting" [ 77.969] (EE) Screen 0 deleted because of no matching config section. [ 77.969] (II) UnloadModule: "fbdev" [ 77.969] (II) UnloadSubModule: "fbdevhw" [ 77.969] (II) Loading sub module "vbe" [ 77.969] (II) LoadModule: "vbe" [ 77.969] (II) Loading /usr/lib64/xorg/modules/libvbe.so [ 77.969] (II) Module vbe: vendor="X.Org Foundation" [ 77.969] compiled for 1.19.5, module version = 1.1.0 [ 77.969] ABI class: X.Org Video Driver, version 23.0 [ 77.969] (II) Loading sub module "int10" [ 77.969] (II) LoadModule: "int10" [ 77.969] (II) Loading /usr/lib64/xorg/modules/libint10.so [ 77.969] (II) Module int10: vendor="X.Org Foundation" [ 77.969] compiled for 1.19.5, module version = 1.0.0 [ 77.969] ABI class: X.Org Video Driver, version 23.0 [ 77.969] (II) VESA(0): initializing int10 [ 77.971] (II) VESA(0): Primary V_BIOS segment is: 0xc000 [ 78.037] (II) VESA(0): VESA BIOS detected [ 78.037] (II) VESA(0): VESA VBE Version 3.0 [ 78.037] (II) VESA(0): VESA VBE Total Mem: 16384 kB [ 78.037] (II) VESA(0): VESA VBE OEM: NVIDIA [ 78.037] (II) VESA(0): VESA VBE OEM Software Rev: 132.4 [ 78.037] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation [ 78.037] (II) VESA(0): VESA VBE OEM Product: GM204 Board [ 78.037] (II) VESA(0): VESA VBE OEM Product Rev: Chip Rev [ 78.155] (II) VESA(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 78.155] (==) VESA(0): Depth 24, (--) framebuffer bpp 32 [ 78.155] (==) VESA(0): RGB weight 888 [ 78.155] (==) VESA(0): Default visual is TrueColor [ 78.155] (==) VESA(0): Using gamma correction (1.0, 1.0, 1.0) [ 78.156] (II) Loading sub module "ddc" [ 78.156] (II) LoadModule: "ddc" [ 78.156] (II) Module "ddc" already built-in [ 78.156] (II) VESA(0): VESA VBE DDC supported [ 78.156] (II) VESA(0): VESA VBE DDC Level 2 [ 78.156] (II) VESA(0): VESA VBE DDC transfer in appr. 1 sec. [ 78.177] (II) VESA(0): VESA VBE DDC read successfully [ 78.177] (II) VESA(0): Manufacturer: ACR Model: 3e3 Serial#: 1393576989 [ 78.177] (II) VESA(0): Year: 2015 Week: 31 [ 78.177] (II) VESA(0): EDID Version: 1.3 [ 78.177] (II) VESA(0): Digital Display Input [ 78.177] (II) VESA(0): Max Image Size [cm]: horiz.: 53 vert.: 30 [ 78.177] (II) VESA(0): Gamma: 2.20 [ 78.177] (II) VESA(0): DPMS capabilities: StandBy Suspend [ 78.177] (II) VESA(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 [ 78.177] (II) VESA(0): First detailed timing is preferred mode [ 78.177] (II) VESA(0): redX: 0.645 redY: 0.331 greenX: 0.314 greenY: 0.618 [ 78.177] (II) VESA(0): blueX: 0.150 blueY: 0.069 whiteX: 0.312 whiteY: 0.328 [ 78.177] (II) VESA(0): Supported established timings: [ 78.177] (II) VESA(0): 720x400@70Hz [ 78.177] (II) VESA(0): 640x480@60Hz [ 78.177] (II) VESA(0): 640x480@67Hz [ 78.177] (II) VESA(0): 640x480@72Hz [ 78.177] (II) VESA(0): 640x480@75Hz [ 78.177] (II) VESA(0): 800x600@56Hz [ 78.177] (II) VESA(0): 800x600@60Hz [ 78.177] (II) VESA(0): 800x600@72Hz [ 78.177] (II) VESA(0): 800x600@75Hz [ 78.177] (II) VESA(0): 832x624@75Hz [ 78.177] (II) VESA(0): 1024x768@60Hz [ 78.177] (II) VESA(0): 1024x768@70Hz [ 78.177] (II) VESA(0): 1024x768@75Hz [ 78.177] (II) VESA(0): 1280x1024@75Hz [ 78.177] (II) VESA(0): 1152x864@75Hz [ 78.177] (II) VESA(0): Manufacturer's mask: 0 [ 78.177] (II) VESA(0): Supported standard timings: [ 78.177] (II) VESA(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337 [ 78.177] (II) VESA(0): #1: hsize: 1280 vsize 960 refresh: 60 vid: 16513 [ 78.177] (II) VESA(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897 [ 78.177] (II) VESA(0): #3: hsize: 1280 vsize 720 refresh: 60 vid: 49281 [ 78.177] (II) VESA(0): #4: hsize: 1280 vsize 800 refresh: 60 vid: 129 [ 78.177] (II) VESA(0): #5: hsize: 1440 vsize 900 refresh: 60 vid: 149 [ 78.177] (II) VESA(0): #6: hsize: 1680 vsize 1050 refresh: 60 vid: 179 [ 78.177] (II) VESA(0): #7: hsize: 1920 vsize 1080 refresh: 60 vid: 49361 [ 78.177] (II) VESA(0): Supported detailed timing: [ 78.177] (II) VESA(0): clock: 148.5 MHz Image Size: 531 x 299 mm [ 78.177] (II) VESA(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 78.177] (II) VESA(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0 [ 78.177] (II) VESA(0): Ranges: V min: 55 V max: 76 Hz, H min: 30 H max: 80 kHz, PixClock max 175 MHz [ 78.177] (II) VESA(0): Monitor name: K242HL [ 78.177] (II) VESA(0): Serial No: T0FEE0058520 [ 78.177] (II) VESA(0): EDID (in hex): [ 78.177] (II) VESA(0): 00ffffffffffff000472e3031d4c1053 [ 78.177] (II) VESA(0): 1f19010380351e78ca39b0a554509e26 [ 78.177] (II) VESA(0): 115054bfef80714f8140818081c08100 [ 78.177] (II) VESA(0): 9500b300d1c0023a801871382d40582c [ 78.177] (II) VESA(0): 4500132b2100001e000000fd00374c1e [ 78.177] (II) VESA(0): 5011000a202020202020000000fc004b [ 78.177] (II) VESA(0): 323432484c0a202020202020000000ff [ 78.177] (II) VESA(0): 005430464545303035383532300a00a0 [ 78.177] (II) VESA(0): EDID vendor "ACR", prod id 995 [ 78.177] (II) VESA(0): Using EDID range info for horizontal sync [ 78.177] (II) VESA(0): Using EDID range info for vertical refresh [ 78.177] (II) VESA(0): Printing DDC gathered Modelines: [ 78.177] (II) VESA(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 78.177] (II) VESA(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 78.178] (II) VESA(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e) [ 78.178] (II) VESA(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e) [ 78.178] (II) VESA(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e) [ 78.178] (II) VESA(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e) [ 78.178] (II) VESA(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 78.178] (II) VESA(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e) [ 78.178] (II) VESA(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e) [ 78.178] (II) VESA(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e) [ 78.178] (II) VESA(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e) [ 78.178] (II) VESA(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 78.178] (II) VESA(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e) [ 78.178] (II) VESA(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e) [ 78.178] (II) VESA(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e) [ 78.178] (II) VESA(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e) [ 78.178] (II) VESA(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e) [ 78.178] (II) VESA(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e) [ 78.178] (II) VESA(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e) [ 78.178] (II) VESA(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e) [ 78.178] (II) VESA(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e) [ 78.178] (II) VESA(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e) [ 78.178] (II) VESA(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e) [ 78.178] (II) VESA(0): Searching for matching VESA mode(s): [ 78.179] Mode: 100 (640x400) [ 78.179] ModeAttributes: 0x3bf [ 78.179] WinAAttributes: 0x7 [ 78.179] WinBAttributes: 0x0 [ 78.179] WinGranularity: 64 [ 78.179] WinSize: 64 [ 78.179] WinASegment: 0xa000 [ 78.179] WinBSegment: 0x0 [ 78.179] WinFuncPtr: 0xc0007d60 [ 78.179] BytesPerScanline: 640 [ 78.179] XResolution: 640 [ 78.179] YResolution: 400 [ 78.179] XCharSize: 8 [ 78.179] YCharSize: 16 [ 78.179] NumberOfPlanes: 1 [ 78.179] BitsPerPixel: 8 [ 78.179] NumberOfBanks: 1 [ 78.179] MemoryModel: 4 [ 78.180] BankSize: 0 [ 78.180] NumberOfImages: 14 [ 78.180] RedMaskSize: 0 [ 78.180] RedFieldPosition: 0 [ 78.180] GreenMaskSize: 0 [ 78.180] GreenFieldPosition: 0 [ 78.180] BlueMaskSize: 0 [ 78.180] BlueFieldPosition: 0 [ 78.180] RsvdMaskSize: 0 [ 78.180] RsvdFieldPosition: 0 [ 78.180] DirectColorModeInfo: 0 [ 78.180] PhysBasePtr: 0xcf000000 [ 78.180] LinBytesPerScanLine: 640 [ 78.180] BnkNumberOfImagePages: 14 [ 78.180] LinNumberOfImagePages: 14 [ 78.180] LinRedMaskSize: 0 [ 78.180] LinRedFieldPosition: 0 [ 78.180] LinGreenMaskSize: 0 [ 78.180] LinGreenFieldPosition: 0 [ 78.180] LinBlueMaskSize: 0 [ 78.180] LinBlueFieldPosition: 0 [ 78.180] LinRsvdMaskSize: 0 [ 78.180] LinRsvdFieldPosition: 0 [ 78.180] MaxPixelClock: 229500000 [ 78.181] Mode: 101 (640x480) [ 78.181] ModeAttributes: 0x3bf [ 78.181] WinAAttributes: 0x7 [ 78.181] WinBAttributes: 0x0 [ 78.181] WinGranularity: 64 [ 78.181] WinSize: 64 [ 78.181] WinASegment: 0xa000 [ 78.181] WinBSegment: 0x0 [ 78.181] WinFuncPtr: 0xc0007d60 [ 78.181] BytesPerScanline: 640 [ 78.181] XResolution: 640 [ 78.181] YResolution: 480 [ 78.181] XCharSize: 8 [ 78.181] YCharSize: 16 [ 78.181] NumberOfPlanes: 1 [ 78.181] BitsPerPixel: 8 [ 78.181] NumberOfBanks: 1 [ 78.181] MemoryModel: 4 [ 78.181] BankSize: 0 [ 78.181] NumberOfImages: 10 [ 78.181] RedMaskSize: 0 [ 78.181] RedFieldPosition: 0 [ 78.181] GreenMaskSize: 0 [ 78.181] GreenFieldPosition: 0 [ 78.181] BlueMaskSize: 0 [ 78.181] BlueFieldPosition: 0 [ 78.181] RsvdMaskSize: 0 [ 78.182] RsvdFieldPosition: 0 [ 78.182] DirectColorModeInfo: 0 [ 78.182] PhysBasePtr: 0xcf000000 [ 78.182] LinBytesPerScanLine: 640 [ 78.182] BnkNumberOfImagePages: 10 [ 78.182] LinNumberOfImagePages: 10 [ 78.182] LinRedMaskSize: 0 [ 78.182] LinRedFieldPosition: 0 [ 78.182] LinGreenMaskSize: 0 [ 78.182] LinGreenFieldPosition: 0 [ 78.182] LinBlueMaskSize: 0 [ 78.182] LinBlueFieldPosition: 0 [ 78.182] LinRsvdMaskSize: 0 [ 78.182] LinRsvdFieldPosition: 0 [ 78.182] MaxPixelClock: 229500000 [ 78.183] Mode: 102 (800x600) [ 78.183] ModeAttributes: 0x33f [ 78.183] WinAAttributes: 0x7 [ 78.183] WinBAttributes: 0x0 [ 78.183] WinGranularity: 64 [ 78.183] WinSize: 64 [ 78.183] WinASegment: 0xa000 [ 78.183] WinBSegment: 0x0 [ 78.183] WinFuncPtr: 0xc0007d60 [ 78.183] BytesPerScanline: 100 [ 78.183] XResolution: 800 [ 78.183] YResolution: 600 [ 78.183] XCharSize: 8 [ 78.183] YCharSize: 16 [ 78.183] NumberOfPlanes: 4 [ 78.183] BitsPerPixel: 4 [ 78.183] NumberOfBanks: 1 [ 78.183] MemoryModel: 3 [ 78.183] BankSize: 0 [ 78.183] NumberOfImages: 2 [ 78.183] RedMaskSize: 0 [ 78.183] RedFieldPosition: 0 [ 78.183] GreenMaskSize: 0 [ 78.183] GreenFieldPosition: 0 [ 78.183] BlueMaskSize: 0 [ 78.183] BlueFieldPosition: 0 [ 78.183] RsvdMaskSize: 0 [ 78.183] RsvdFieldPosition: 0 [ 78.183] DirectColorModeInfo: 0 [ 78.183] PhysBasePtr: 0x0 [ 78.183] LinBytesPerScanLine: 100 [ 78.183] BnkNumberOfImagePages: 2 [ 78.183] LinNumberOfImagePages: 2 [ 78.183] LinRedMaskSize: 0 [ 78.183] LinRedFieldPosition: 0 [ 78.183] LinGreenMaskSize: 0 [ 78.183] LinGreenFieldPosition: 0 [ 78.183] LinBlueMaskSize: 0 [ 78.183] LinBlueFieldPosition: 0 [ 78.183] LinRsvdMaskSize: 0 [ 78.184] LinRsvdFieldPosition: 0 [ 78.184] MaxPixelClock: 108500000 [ 78.185] Mode: 103 (800x600) [ 78.185] ModeAttributes: 0x3bf [ 78.185] WinAAttributes: 0x7 [ 78.185] WinBAttributes: 0x0 [ 78.185] WinGranularity: 64 [ 78.185] WinSize: 64 [ 78.185] WinASegment: 0xa000 [ 78.185] WinBSegment: 0x0 [ 78.185] WinFuncPtr: 0xc0007d60 [ 78.185] BytesPerScanline: 800 [ 78.185] XResolution: 800 [ 78.185] YResolution: 600 [ 78.185] XCharSize: 8 [ 78.185] YCharSize: 16 [ 78.185] NumberOfPlanes: 1 [ 78.185] BitsPerPixel: 8 [ 78.185] NumberOfBanks: 1 [ 78.185] MemoryModel: 4 [ 78.185] BankSize: 0 [ 78.185] NumberOfImages: 6 [ 78.185] RedMaskSize: 0 [ 78.185] RedFieldPosition: 0 [ 78.185] GreenMaskSize: 0 [ 78.185] GreenFieldPosition: 0 [ 78.185] BlueMaskSize: 0 [ 78.185] BlueFieldPosition: 0 [ 78.185] RsvdMaskSize: 0 [ 78.185] RsvdFieldPosition: 0 [ 78.185] DirectColorModeInfo: 0 [ 78.185] PhysBasePtr: 0xcf000000 [ 78.185] LinBytesPerScanLine: 800 [ 78.185] BnkNumberOfImagePages: 6 [ 78.185] LinNumberOfImagePages: 6 [ 78.185] LinRedMaskSize: 0 [ 78.185] LinRedFieldPosition: 0 [ 78.185] LinGreenMaskSize: 0 [ 78.185] LinGreenFieldPosition: 0 [ 78.185] LinBlueMaskSize: 0 [ 78.185] LinBlueFieldPosition: 0 [ 78.185] LinRsvdMaskSize: 0 [ 78.185] LinRsvdFieldPosition: 0 [ 78.185] MaxPixelClock: 229500000 [ 78.187] Mode: 104 (1024x768) [ 78.187] ModeAttributes: 0x33f [ 78.187] WinAAttributes: 0x7 [ 78.187] WinBAttributes: 0x0 [ 78.187] WinGranularity: 64 [ 78.187] WinSize: 64 [ 78.187] WinASegment: 0xa000 [ 78.187] WinBSegment: 0x0 [ 78.187] WinFuncPtr: 0xc0007d60 [ 78.187] BytesPerScanline: 128 [ 78.187] XResolution: 1024 [ 78.187] YResolution: 768 [ 78.187] XCharSize: 8 [ 78.187] YCharSize: 16 [ 78.187] NumberOfPlanes: 4 [ 78.187] BitsPerPixel: 4 [ 78.187] NumberOfBanks: 1 [ 78.187] MemoryModel: 3 [ 78.187] BankSize: 0 [ 78.187] NumberOfImages: 1 [ 78.187] RedMaskSize: 0 [ 78.187] RedFieldPosition: 0 [ 78.187] GreenMaskSize: 0 [ 78.187] GreenFieldPosition: 0 [ 78.187] BlueMaskSize: 0 [ 78.187] BlueFieldPosition: 0 [ 78.187] RsvdMaskSize: 0 [ 78.187] RsvdFieldPosition: 0 [ 78.187] DirectColorModeInfo: 0 [ 78.187] PhysBasePtr: 0x0 [ 78.187] LinBytesPerScanLine: 128 [ 78.187] BnkNumberOfImagePages: 1 [ 78.187] LinNumberOfImagePages: 1 [ 78.187] LinRedMaskSize: 0 [ 78.187] LinRedFieldPosition: 0 [ 78.187] LinGreenMaskSize: 0 [ 78.187] LinGreenFieldPosition: 0 [ 78.187] LinBlueMaskSize: 0 [ 78.187] LinBlueFieldPosition: 0 [ 78.187] LinRsvdMaskSize: 0 [ 78.187] LinRsvdFieldPosition: 0 [ 78.187] MaxPixelClock: 108500000 [ 78.189] Mode: 105 (1024x768) [ 78.189] ModeAttributes: 0x3bf [ 78.189] WinAAttributes: 0x7 [ 78.189] WinBAttributes: 0x0 [ 78.189] WinGranularity: 64 [ 78.189] WinSize: 64 [ 78.189] WinASegment: 0xa000 [ 78.189] WinBSegment: 0x0 [ 78.189] WinFuncPtr: 0xc0007d60 [ 78.189] BytesPerScanline: 1024 [ 78.189] XResolution: 1024 [ 78.189] YResolution: 768 [ 78.189] XCharSize: 8 [ 78.189] YCharSize: 16 [ 78.189] NumberOfPlanes: 1 [ 78.189] BitsPerPixel: 8 [ 78.189] NumberOfBanks: 1 [ 78.189] MemoryModel: 4 [ 78.189] BankSize: 0 [ 78.189] NumberOfImages: 3 [ 78.189] RedMaskSize: 0 [ 78.189] RedFieldPosition: 0 [ 78.189] GreenMaskSize: 0 [ 78.189] GreenFieldPosition: 0 [ 78.189] BlueMaskSize: 0 [ 78.189] BlueFieldPosition: 0 [ 78.189] RsvdMaskSize: 0 [ 78.189] RsvdFieldPosition: 0 [ 78.189] DirectColorModeInfo: 0 [ 78.189] PhysBasePtr: 0xcf000000 [ 78.189] LinBytesPerScanLine: 1024 [ 78.189] BnkNumberOfImagePages: 3 [ 78.189] LinNumberOfImagePages: 3 [ 78.189] LinRedMaskSize: 0 [ 78.189] LinRedFieldPosition: 0 [ 78.189] LinGreenMaskSize: 0 [ 78.189] LinGreenFieldPosition: 0 [ 78.189] LinBlueMaskSize: 0 [ 78.189] LinBlueFieldPosition: 0 [ 78.189] LinRsvdMaskSize: 0 [ 78.189] LinRsvdFieldPosition: 0 [ 78.189] MaxPixelClock: 229500000 [ 78.191] Mode: 106 (1280x1024) [ 78.191] ModeAttributes: 0x33f [ 78.191] WinAAttributes: 0x7 [ 78.191] WinBAttributes: 0x0 [ 78.191] WinGranularity: 64 [ 78.191] WinSize: 64 [ 78.191] WinASegment: 0xa000 [ 78.191] WinBSegment: 0x0 [ 78.191] WinFuncPtr: 0xc0007d60 [ 78.191] BytesPerScanline: 160 [ 78.191] XResolution: 1280 [ 78.191] YResolution: 1024 [ 78.191] XCharSize: 8 [ 78.191] YCharSize: 16 [ 78.191] NumberOfPlanes: 4 [ 78.191] BitsPerPixel: 4 [ 78.191] NumberOfBanks: 1 [ 78.191] MemoryModel: 3 [ 78.191] BankSize: 0 [ 78.191] NumberOfImages: 1 [ 78.191] RedMaskSize: 0 [ 78.191] RedFieldPosition: 0 [ 78.191] GreenMaskSize: 0 [ 78.191] GreenFieldPosition: 0 [ 78.191] BlueMaskSize: 0 [ 78.191] BlueFieldPosition: 0 [ 78.191] RsvdMaskSize: 0 [ 78.191] RsvdFieldPosition: 0 [ 78.191] DirectColorModeInfo: 0 [ 78.191] PhysBasePtr: 0x0 [ 78.191] LinBytesPerScanLine: 160 [ 78.191] BnkNumberOfImagePages: 1 [ 78.191] LinNumberOfImagePages: 1 [ 78.191] LinRedMaskSize: 0 [ 78.191] LinRedFieldPosition: 0 [ 78.191] LinGreenMaskSize: 0 [ 78.191] LinGreenFieldPosition: 0 [ 78.191] LinBlueMaskSize: 0 [ 78.191] LinBlueFieldPosition: 0 [ 78.191] LinRsvdMaskSize: 0 [ 78.191] LinRsvdFieldPosition: 0 [ 78.191] MaxPixelClock: 108500000 [ 78.193] Mode: 107 (1280x1024) [ 78.193] ModeAttributes: 0x3bf [ 78.193] WinAAttributes: 0x7 [ 78.193] WinBAttributes: 0x0 [ 78.193] WinGranularity: 64 [ 78.193] WinSize: 64 [ 78.193] WinASegment: 0xa000 [ 78.193] WinBSegment: 0x0 [ 78.193] WinFuncPtr: 0xc0007d60 [ 78.193] BytesPerScanline: 1280 [ 78.193] XResolution: 1280 [ 78.193] YResolution: 1024 [ 78.193] XCharSize: 8 [ 78.193] YCharSize: 16 [ 78.193] NumberOfPlanes: 1 [ 78.193] BitsPerPixel: 8 [ 78.193] NumberOfBanks: 1 [ 78.193] MemoryModel: 4 [ 78.193] BankSize: 0 [ 78.193] NumberOfImages: 1 [ 78.193] RedMaskSize: 0 [ 78.193] RedFieldPosition: 0 [ 78.193] GreenMaskSize: 0 [ 78.193] GreenFieldPosition: 0 [ 78.193] BlueMaskSize: 0 [ 78.193] BlueFieldPosition: 0 [ 78.193] RsvdMaskSize: 0 [ 78.193] RsvdFieldPosition: 0 [ 78.193] DirectColorModeInfo: 0 [ 78.193] PhysBasePtr: 0xcf000000 [ 78.193] LinBytesPerScanLine: 1280 [ 78.193] BnkNumberOfImagePages: 1 [ 78.193] LinNumberOfImagePages: 1 [ 78.193] LinRedMaskSize: 0 [ 78.193] LinRedFieldPosition: 0 [ 78.193] LinGreenMaskSize: 0 [ 78.193] LinGreenFieldPosition: 0 [ 78.193] LinBlueMaskSize: 0 [ 78.193] LinBlueFieldPosition: 0 [ 78.193] LinRsvdMaskSize: 0 [ 78.193] LinRsvdFieldPosition: 0 [ 78.193] MaxPixelClock: 229500000 [ 78.195] Mode: 10e (320x200) [ 78.195] ModeAttributes: 0x3bf [ 78.195] WinAAttributes: 0x7 [ 78.195] WinBAttributes: 0x0 [ 78.195] WinGranularity: 64 [ 78.195] WinSize: 64 [ 78.195] WinASegment: 0xa000 [ 78.195] WinBSegment: 0x0 [ 78.195] WinFuncPtr: 0xc0007d60 [ 78.195] BytesPerScanline: 640 [ 78.195] XResolution: 320 [ 78.195] YResolution: 200 [ 78.195] XCharSize: 8 [ 78.195] YCharSize: 8 [ 78.195] NumberOfPlanes: 1 [ 78.195] BitsPerPixel: 16 [ 78.195] NumberOfBanks: 1 [ 78.195] MemoryModel: 6 [ 78.195] BankSize: 0 [ 78.195] NumberOfImages: 30 [ 78.195] RedMaskSize: 5 [ 78.195] RedFieldPosition: 11 [ 78.195] GreenMaskSize: 6 [ 78.195] GreenFieldPosition: 5 [ 78.195] BlueMaskSize: 5 [ 78.195] BlueFieldPosition: 0 [ 78.195] RsvdMaskSize: 0 [ 78.195] RsvdFieldPosition: 0 [ 78.195] DirectColorModeInfo: 0 [ 78.195] PhysBasePtr: 0xcf000000 [ 78.195] LinBytesPerScanLine: 640 [ 78.195] BnkNumberOfImagePages: 30 [ 78.195] LinNumberOfImagePages: 30 [ 78.195] LinRedMaskSize: 5 [ 78.195] LinRedFieldPosition: 11 [ 78.195] LinGreenMaskSize: 6 [ 78.195] LinGreenFieldPosition: 5 [ 78.195] LinBlueMaskSize: 5 [ 78.195] LinBlueFieldPosition: 0 [ 78.195] LinRsvdMaskSize: 0 [ 78.195] LinRsvdFieldPosition: 0 [ 78.195] MaxPixelClock: 229500000 [ 78.197] *Mode: 10f (320x200) [ 78.197] ModeAttributes: 0x3bf [ 78.197] WinAAttributes: 0x7 [ 78.197] WinBAttributes: 0x0 [ 78.197] WinGranularity: 64 [ 78.197] WinSize: 64 [ 78.197] WinASegment: 0xa000 [ 78.197] WinBSegment: 0x0 [ 78.197] WinFuncPtr: 0xc0007d60 [ 78.197] BytesPerScanline: 1280 [ 78.197] XResolution: 320 [ 78.197] YResolution: 200 [ 78.197] XCharSize: 8 [ 78.197] YCharSize: 8 [ 78.197] NumberOfPlanes: 1 [ 78.197] BitsPerPixel: 32 [ 78.197] NumberOfBanks: 1 [ 78.197] MemoryModel: 6 [ 78.197] BankSize: 0 [ 78.197] NumberOfImages: 14 [ 78.197] RedMaskSize: 8 [ 78.197] RedFieldPosition: 16 [ 78.197] GreenMaskSize: 8 [ 78.197] GreenFieldPosition: 8 [ 78.197] BlueMaskSize: 8 [ 78.197] BlueFieldPosition: 0 [ 78.197] RsvdMaskSize: 8 [ 78.197] RsvdFieldPosition: 24 [ 78.197] DirectColorModeInfo: 0 [ 78.197] PhysBasePtr: 0xcf000000 [ 78.197] LinBytesPerScanLine: 1280 [ 78.197] BnkNumberOfImagePages: 14 [ 78.197] LinNumberOfImagePages: 14 [ 78.197] LinRedMaskSize: 8 [ 78.197] LinRedFieldPosition: 16 [ 78.197] LinGreenMaskSize: 8 [ 78.197] LinGreenFieldPosition: 8 [ 78.197] LinBlueMaskSize: 8 [ 78.197] LinBlueFieldPosition: 0 [ 78.197] LinRsvdMaskSize: 8 [ 78.197] LinRsvdFieldPosition: 24 [ 78.197] MaxPixelClock: 229500000 [ 78.199] Mode: 111 (640x480) [ 78.199] ModeAttributes: 0x3bf [ 78.199] WinAAttributes: 0x7 [ 78.199] WinBAttributes: 0x0 [ 78.199] WinGranularity: 64 [ 78.199] WinSize: 64 [ 78.199] WinASegment: 0xa000 [ 78.199] WinBSegment: 0x0 [ 78.199] WinFuncPtr: 0xc0007d60 [ 78.199] BytesPerScanline: 1280 [ 78.199] XResolution: 640 [ 78.199] YResolution: 480 [ 78.199] XCharSize: 8 [ 78.199] YCharSize: 16 [ 78.199] NumberOfPlanes: 1 [ 78.199] BitsPerPixel: 16 [ 78.199] NumberOfBanks: 1 [ 78.199] MemoryModel: 6 [ 78.199] BankSize: 0 [ 78.199] NumberOfImages: 4 [ 78.199] RedMaskSize: 5 [ 78.199] RedFieldPosition: 11 [ 78.199] GreenMaskSize: 6 [ 78.199] GreenFieldPosition: 5 [ 78.199] BlueMaskSize: 5 [ 78.199] BlueFieldPosition: 0 [ 78.199] RsvdMaskSize: 0 [ 78.199] RsvdFieldPosition: 0 [ 78.199] DirectColorModeInfo: 0 [ 78.199] PhysBasePtr: 0xcf000000 [ 78.199] LinBytesPerScanLine: 1280 [ 78.199] BnkNumberOfImagePages: 4 [ 78.199] LinNumberOfImagePages: 4 [ 78.199] LinRedMaskSize: 5 [ 78.199] LinRedFieldPosition: 11 [ 78.199] LinGreenMaskSize: 6 [ 78.199] LinGreenFieldPosition: 5 [ 78.199] LinBlueMaskSize: 5 [ 78.199] LinBlueFieldPosition: 0 [ 78.199] LinRsvdMaskSize: 0 [ 78.199] LinRsvdFieldPosition: 0 [ 78.199] MaxPixelClock: 229500000 [ 78.201] *Mode: 112 (640x480) [ 78.201] ModeAttributes: 0x3bf [ 78.201] WinAAttributes: 0x7 [ 78.201] WinBAttributes: 0x0 [ 78.201] WinGranularity: 64 [ 78.201] WinSize: 64 [ 78.201] WinASegment: 0xa000 [ 78.201] WinBSegment: 0x0 [ 78.201] WinFuncPtr: 0xc0007d60 [ 78.201] BytesPerScanline: 2560 [ 78.201] XResolution: 640 [ 78.201] YResolution: 480 [ 78.201] XCharSize: 8 [ 78.201] YCharSize: 16 [ 78.201] NumberOfPlanes: 1 [ 78.201] BitsPerPixel: 32 [ 78.201] NumberOfBanks: 1 [ 78.201] MemoryModel: 6 [ 78.201] BankSize: 0 [ 78.201] NumberOfImages: 1 [ 78.201] RedMaskSize: 8 [ 78.201] RedFieldPosition: 16 [ 78.201] GreenMaskSize: 8 [ 78.201] GreenFieldPosition: 8 [ 78.201] BlueMaskSize: 8 [ 78.201] BlueFieldPosition: 0 [ 78.201] RsvdMaskSize: 8 [ 78.201] RsvdFieldPosition: 24 [ 78.201] DirectColorModeInfo: 0 [ 78.201] PhysBasePtr: 0xcf000000 [ 78.201] LinBytesPerScanLine: 2560 [ 78.201] BnkNumberOfImagePages: 1 [ 78.201] LinNumberOfImagePages: 1 [ 78.201] LinRedMaskSize: 8 [ 78.201] LinRedFieldPosition: 16 [ 78.201] LinGreenMaskSize: 8 [ 78.201] LinGreenFieldPosition: 8 [ 78.201] LinBlueMaskSize: 8 [ 78.201] LinBlueFieldPosition: 0 [ 78.201] LinRsvdMaskSize: 8 [ 78.201] LinRsvdFieldPosition: 24 [ 78.201] MaxPixelClock: 229500000 [ 78.203] Mode: 114 (800x600) [ 78.203] ModeAttributes: 0x3bf [ 78.203] WinAAttributes: 0x7 [ 78.203] WinBAttributes: 0x0 [ 78.203] WinGranularity: 64 [ 78.203] WinSize: 64 [ 78.203] WinASegment: 0xa000 [ 78.203] WinBSegment: 0x0 [ 78.203] WinFuncPtr: 0xc0007d60 [ 78.203] BytesPerScanline: 1600 [ 78.203] XResolution: 800 [ 78.203] YResolution: 600 [ 78.203] XCharSize: 8 [ 78.203] YCharSize: 16 [ 78.203] NumberOfPlanes: 1 [ 78.203] BitsPerPixel: 16 [ 78.203] NumberOfBanks: 1 [ 78.203] MemoryModel: 6 [ 78.203] BankSize: 0 [ 78.203] NumberOfImages: 2 [ 78.203] RedMaskSize: 5 [ 78.203] RedFieldPosition: 11 [ 78.203] GreenMaskSize: 6 [ 78.203] GreenFieldPosition: 5 [ 78.203] BlueMaskSize: 5 [ 78.203] BlueFieldPosition: 0 [ 78.203] RsvdMaskSize: 0 [ 78.203] RsvdFieldPosition: 0 [ 78.203] DirectColorModeInfo: 0 [ 78.203] PhysBasePtr: 0xcf000000 [ 78.203] LinBytesPerScanLine: 1600 [ 78.203] BnkNumberOfImagePages: 2 [ 78.203] LinNumberOfImagePages: 2 [ 78.203] LinRedMaskSize: 5 [ 78.203] LinRedFieldPosition: 11 [ 78.203] LinGreenMaskSize: 6 [ 78.203] LinGreenFieldPosition: 5 [ 78.203] LinBlueMaskSize: 5 [ 78.203] LinBlueFieldPosition: 0 [ 78.203] LinRsvdMaskSize: 0 [ 78.203] LinRsvdFieldPosition: 0 [ 78.203] MaxPixelClock: 229500000 [ 78.204] *Mode: 115 (800x600) [ 78.204] ModeAttributes: 0x3bf [ 78.204] WinAAttributes: 0x7 [ 78.204] WinBAttributes: 0x0 [ 78.204] WinGranularity: 64 [ 78.204] WinSize: 64 [ 78.204] WinASegment: 0xa000 [ 78.205] WinBSegment: 0x0 [ 78.205] WinFuncPtr: 0xc0007d60 [ 78.205] BytesPerScanline: 3200 [ 78.205] XResolution: 800 [ 78.205] YResolution: 600 [ 78.205] XCharSize: 8 [ 78.205] YCharSize: 16 [ 78.205] NumberOfPlanes: 1 [ 78.205] BitsPerPixel: 32 [ 78.205] NumberOfBanks: 1 [ 78.205] MemoryModel: 6 [ 78.205] BankSize: 0 [ 78.205] NumberOfImages: 1 [ 78.205] RedMaskSize: 8 [ 78.205] RedFieldPosition: 16 [ 78.205] GreenMaskSize: 8 [ 78.205] GreenFieldPosition: 8 [ 78.205] BlueMaskSize: 8 [ 78.205] BlueFieldPosition: 0 [ 78.205] RsvdMaskSize: 8 [ 78.205] RsvdFieldPosition: 24 [ 78.205] DirectColorModeInfo: 0 [ 78.205] PhysBasePtr: 0xcf000000 [ 78.205] LinBytesPerScanLine: 3200 [ 78.205] BnkNumberOfImagePages: 1 [ 78.205] LinNumberOfImagePages: 1 [ 78.205] LinRedMaskSize: 8 [ 78.205] LinRedFieldPosition: 16 [ 78.205] LinGreenMaskSize: 8 [ 78.205] LinGreenFieldPosition: 8 [ 78.205] LinBlueMaskSize: 8 [ 78.205] LinBlueFieldPosition: 0 [ 78.205] LinRsvdMaskSize: 8 [ 78.205] LinRsvdFieldPosition: 24 [ 78.205] MaxPixelClock: 229500000 [ 78.206] Mode: 117 (1024x768) [ 78.206] ModeAttributes: 0x3bf [ 78.206] WinAAttributes: 0x7 [ 78.206] WinBAttributes: 0x0 [ 78.206] WinGranularity: 64 [ 78.206] WinSize: 64 [ 78.206] WinASegment: 0xa000 [ 78.206] WinBSegment: 0x0 [ 78.206] WinFuncPtr: 0xc0007d60 [ 78.206] BytesPerScanline: 2048 [ 78.206] XResolution: 1024 [ 78.206] YResolution: 768 [ 78.206] XCharSize: 8 [ 78.206] YCharSize: 16 [ 78.207] NumberOfPlanes: 1 [ 78.207] BitsPerPixel: 16 [ 78.207] NumberOfBanks: 1 [ 78.207] MemoryModel: 6 [ 78.207] BankSize: 0 [ 78.207] NumberOfImages: 1 [ 78.207] RedMaskSize: 5 [ 78.207] RedFieldPosition: 11 [ 78.207] GreenMaskSize: 6 [ 78.207] GreenFieldPosition: 5 [ 78.207] BlueMaskSize: 5 [ 78.207] BlueFieldPosition: 0 [ 78.207] RsvdMaskSize: 0 [ 78.207] RsvdFieldPosition: 0 [ 78.207] DirectColorModeInfo: 0 [ 78.207] PhysBasePtr: 0xcf000000 [ 78.207] LinBytesPerScanLine: 2048 [ 78.207] BnkNumberOfImagePages: 1 [ 78.207] LinNumberOfImagePages: 1 [ 78.207] LinRedMaskSize: 5 [ 78.207] LinRedFieldPosition: 11 [ 78.207] LinGreenMaskSize: 6 [ 78.207] LinGreenFieldPosition: 5 [ 78.207] LinBlueMaskSize: 5 [ 78.207] LinBlueFieldPosition: 0 [ 78.207] LinRsvdMaskSize: 0 [ 78.207] LinRsvdFieldPosition: 0 [ 78.207] MaxPixelClock: 229500000 [ 78.208] *Mode: 118 (1024x768) [ 78.208] ModeAttributes: 0x3bf [ 78.208] WinAAttributes: 0x7 [ 78.208] WinBAttributes: 0x0 [ 78.208] WinGranularity: 64 [ 78.208] WinSize: 64 [ 78.208] WinASegment: 0xa000 [ 78.208] WinBSegment: 0x0 [ 78.208] WinFuncPtr: 0xc0007d60 [ 78.208] BytesPerScanline: 4096 [ 78.208] XResolution: 1024 [ 78.208] YResolution: 768 [ 78.208] XCharSize: 8 [ 78.208] YCharSize: 16 [ 78.208] NumberOfPlanes: 1 [ 78.208] BitsPerPixel: 32 [ 78.208] NumberOfBanks: 1 [ 78.208] MemoryModel: 6 [ 78.208] BankSize: 0 [ 78.208] NumberOfImages: 1 [ 78.208] RedMaskSize: 8 [ 78.208] RedFieldPosition: 16 [ 78.208] GreenMaskSize: 8 [ 78.208] GreenFieldPosition: 8 [ 78.208] BlueMaskSize: 8 [ 78.208] BlueFieldPosition: 0 [ 78.208] RsvdMaskSize: 8 [ 78.209] RsvdFieldPosition: 24 [ 78.209] DirectColorModeInfo: 0 [ 78.209] PhysBasePtr: 0xcf000000 [ 78.209] LinBytesPerScanLine: 4096 [ 78.209] BnkNumberOfImagePages: 1 [ 78.209] LinNumberOfImagePages: 1 [ 78.209] LinRedMaskSize: 8 [ 78.209] LinRedFieldPosition: 16 [ 78.209] LinGreenMaskSize: 8 [ 78.209] LinGreenFieldPosition: 8 [ 78.209] LinBlueMaskSize: 8 [ 78.209] LinBlueFieldPosition: 0 [ 78.209] LinRsvdMaskSize: 8 [ 78.209] LinRsvdFieldPosition: 24 [ 78.209] MaxPixelClock: 229500000 [ 78.210] Mode: 11a (1280x1024) [ 78.210] ModeAttributes: 0x3bf [ 78.210] WinAAttributes: 0x7 [ 78.210] WinBAttributes: 0x0 [ 78.210] WinGranularity: 64 [ 78.210] WinSize: 64 [ 78.210] WinASegment: 0xa000 [ 78.210] WinBSegment: 0x0 [ 78.210] WinFuncPtr: 0xc0007d60 [ 78.210] BytesPerScanline: 2560 [ 78.210] XResolution: 1280 [ 78.210] YResolution: 1024 [ 78.210] XCharSize: 8 [ 78.210] YCharSize: 16 [ 78.210] NumberOfPlanes: 1 [ 78.210] BitsPerPixel: 16 [ 78.210] NumberOfBanks: 1 [ 78.210] MemoryModel: 6 [ 78.210] BankSize: 0 [ 78.210] NumberOfImages: 1 [ 78.210] RedMaskSize: 5 [ 78.210] RedFieldPosition: 11 [ 78.210] GreenMaskSize: 6 [ 78.210] GreenFieldPosition: 5 [ 78.210] BlueMaskSize: 5 [ 78.210] BlueFieldPosition: 0 [ 78.210] RsvdMaskSize: 0 [ 78.210] RsvdFieldPosition: 0 [ 78.210] DirectColorModeInfo: 0 [ 78.210] PhysBasePtr: 0xcf000000 [ 78.210] LinBytesPerScanLine: 2560 [ 78.210] BnkNumberOfImagePages: 1 [ 78.210] LinNumberOfImagePages: 1 [ 78.210] LinRedMaskSize: 5 [ 78.210] LinRedFieldPosition: 11 [ 78.210] LinGreenMaskSize: 6 [ 78.210] LinGreenFieldPosition: 5 [ 78.210] LinBlueMaskSize: 5 [ 78.211] LinBlueFieldPosition: 0 [ 78.211] LinRsvdMaskSize: 0 [ 78.211] LinRsvdFieldPosition: 0 [ 78.211] MaxPixelClock: 229500000 [ 78.212] *Mode: 11b (1280x1024) [ 78.212] ModeAttributes: 0x3bf [ 78.212] WinAAttributes: 0x7 [ 78.212] WinBAttributes: 0x0 [ 78.212] WinGranularity: 64 [ 78.212] WinSize: 64 [ 78.212] WinASegment: 0xa000 [ 78.212] WinBSegment: 0x0 [ 78.212] WinFuncPtr: 0xc0007d60 [ 78.212] BytesPerScanline: 5120 [ 78.212] XResolution: 1280 [ 78.212] YResolution: 1024 [ 78.212] XCharSize: 8 [ 78.212] YCharSize: 16 [ 78.212] NumberOfPlanes: 1 [ 78.212] BitsPerPixel: 32 [ 78.212] NumberOfBanks: 1 [ 78.212] MemoryModel: 6 [ 78.212] BankSize: 0 [ 78.212] NumberOfImages: 1 [ 78.212] RedMaskSize: 8 [ 78.212] RedFieldPosition: 16 [ 78.212] GreenMaskSize: 8 [ 78.212] GreenFieldPosition: 8 [ 78.212] BlueMaskSize: 8 [ 78.212] BlueFieldPosition: 0 [ 78.212] RsvdMaskSize: 8 [ 78.212] RsvdFieldPosition: 24 [ 78.212] DirectColorModeInfo: 0 [ 78.212] PhysBasePtr: 0xcf000000 [ 78.212] LinBytesPerScanLine: 5120 [ 78.212] BnkNumberOfImagePages: 1 [ 78.212] LinNumberOfImagePages: 1 [ 78.212] LinRedMaskSize: 8 [ 78.212] LinRedFieldPosition: 16 [ 78.212] LinGreenMaskSize: 8 [ 78.212] LinGreenFieldPosition: 8 [ 78.212] LinBlueMaskSize: 8 [ 78.212] LinBlueFieldPosition: 0 [ 78.212] LinRsvdMaskSize: 8 [ 78.212] LinRsvdFieldPosition: 24 [ 78.212] MaxPixelClock: 229500000 [ 78.214] Mode: 130 (320x200) [ 78.214] ModeAttributes: 0x3bf [ 78.214] WinAAttributes: 0x7 [ 78.214] WinBAttributes: 0x0 [ 78.214] WinGranularity: 64 [ 78.214] WinSize: 64 [ 78.214] WinASegment: 0xa000 [ 78.214] WinBSegment: 0x0 [ 78.214] WinFuncPtr: 0xc0007d60 [ 78.214] BytesPerScanline: 320 [ 78.214] XResolution: 320 [ 78.214] YResolution: 200 [ 78.214] XCharSize: 8 [ 78.214] YCharSize: 8 [ 78.214] NumberOfPlanes: 1 [ 78.214] BitsPerPixel: 8 [ 78.214] NumberOfBanks: 1 [ 78.214] MemoryModel: 4 [ 78.214] BankSize: 0 [ 78.214] NumberOfImages: 62 [ 78.214] RedMaskSize: 0 [ 78.214] RedFieldPosition: 0 [ 78.214] GreenMaskSize: 0 [ 78.214] GreenFieldPosition: 0 [ 78.214] BlueMaskSize: 0 [ 78.214] BlueFieldPosition: 0 [ 78.214] RsvdMaskSize: 0 [ 78.214] RsvdFieldPosition: 0 [ 78.214] DirectColorModeInfo: 0 [ 78.214] PhysBasePtr: 0xcf000000 [ 78.214] LinBytesPerScanLine: 320 [ 78.214] BnkNumberOfImagePages: 62 [ 78.214] LinNumberOfImagePages: 62 [ 78.214] LinRedMaskSize: 0 [ 78.214] LinRedFieldPosition: 0 [ 78.214] LinGreenMaskSize: 0 [ 78.214] LinGreenFieldPosition: 0 [ 78.214] LinBlueMaskSize: 0 [ 78.214] LinBlueFieldPosition: 0 [ 78.214] LinRsvdMaskSize: 0 [ 78.214] LinRsvdFieldPosition: 0 [ 78.214] MaxPixelClock: 229500000 [ 78.216] Mode: 131 (320x400) [ 78.216] ModeAttributes: 0x3bf [ 78.216] WinAAttributes: 0x7 [ 78.216] WinBAttributes: 0x0 [ 78.216] WinGranularity: 64 [ 78.216] WinSize: 64 [ 78.216] WinASegment: 0xa000 [ 78.216] WinBSegment: 0x0 [ 78.216] WinFuncPtr: 0xc0007d60 [ 78.216] BytesPerScanline: 320 [ 78.216] XResolution: 320 [ 78.216] YResolution: 400 [ 78.216] XCharSize: 8 [ 78.216] YCharSize: 16 [ 78.216] NumberOfPlanes: 1 [ 78.216] BitsPerPixel: 8 [ 78.216] NumberOfBanks: 1 [ 78.216] MemoryModel: 4 [ 78.216] BankSize: 0 [ 78.216] NumberOfImages: 30 [ 78.216] RedMaskSize: 0 [ 78.216] RedFieldPosition: 0 [ 78.216] GreenMaskSize: 0 [ 78.216] GreenFieldPosition: 0 [ 78.216] BlueMaskSize: 0 [ 78.216] BlueFieldPosition: 0 [ 78.216] RsvdMaskSize: 0 [ 78.216] RsvdFieldPosition: 0 [ 78.216] DirectColorModeInfo: 0 [ 78.216] PhysBasePtr: 0xcf000000 [ 78.216] LinBytesPerScanLine: 320 [ 78.216] BnkNumberOfImagePages: 30 [ 78.216] LinNumberOfImagePages: 30 [ 78.216] LinRedMaskSize: 0 [ 78.216] LinRedFieldPosition: 0 [ 78.216] LinGreenMaskSize: 0 [ 78.216] LinGreenFieldPosition: 0 [ 78.216] LinBlueMaskSize: 0 [ 78.216] LinBlueFieldPosition: 0 [ 78.216] LinRsvdMaskSize: 0 [ 78.216] LinRsvdFieldPosition: 0 [ 78.216] MaxPixelClock: 229500000 [ 78.218] Mode: 132 (320x400) [ 78.218] ModeAttributes: 0x3bf [ 78.218] WinAAttributes: 0x7 [ 78.218] WinBAttributes: 0x0 [ 78.218] WinGranularity: 64 [ 78.218] WinSize: 64 [ 78.218] WinASegment: 0xa000 [ 78.218] WinBSegment: 0x0 [ 78.218] WinFuncPtr: 0xc0007d60 [ 78.218] BytesPerScanline: 640 [ 78.218] XResolution: 320 [ 78.218] YResolution: 400 [ 78.218] XCharSize: 8 [ 78.218] YCharSize: 16 [ 78.218] NumberOfPlanes: 1 [ 78.218] BitsPerPixel: 16 [ 78.218] NumberOfBanks: 1 [ 78.218] MemoryModel: 6 [ 78.218] BankSize: 0 [ 78.218] NumberOfImages: 14 [ 78.218] RedMaskSize: 5 [ 78.218] RedFieldPosition: 11 [ 78.218] GreenMaskSize: 6 [ 78.218] GreenFieldPosition: 5 [ 78.218] BlueMaskSize: 5 [ 78.218] BlueFieldPosition: 0 [ 78.218] RsvdMaskSize: 0 [ 78.218] RsvdFieldPosition: 0 [ 78.218] DirectColorModeInfo: 0 [ 78.218] PhysBasePtr: 0xcf000000 [ 78.218] LinBytesPerScanLine: 640 [ 78.218] BnkNumberOfImagePages: 14 [ 78.218] LinNumberOfImagePages: 14 [ 78.218] LinRedMaskSize: 5 [ 78.218] LinRedFieldPosition: 11 [ 78.218] LinGreenMaskSize: 6 [ 78.218] LinGreenFieldPosition: 5 [ 78.218] LinBlueMaskSize: 5 [ 78.218] LinBlueFieldPosition: 0 [ 78.218] LinRsvdMaskSize: 0 [ 78.218] LinRsvdFieldPosition: 0 [ 78.218] MaxPixelClock: 229500000 [ 78.220] *Mode: 133 (320x400) [ 78.220] ModeAttributes: 0x3bf [ 78.220] WinAAttributes: 0x7 [ 78.220] WinBAttributes: 0x0 [ 78.220] WinGranularity: 64 [ 78.220] WinSize: 64 [ 78.220] WinASegment: 0xa000 [ 78.220] WinBSegment: 0x0 [ 78.220] WinFuncPtr: 0xc0007d60 [ 78.220] BytesPerScanline: 1280 [ 78.220] XResolution: 320 [ 78.220] YResolution: 400 [ 78.220] XCharSize: 8 [ 78.220] YCharSize: 16 [ 78.220] NumberOfPlanes: 1 [ 78.220] BitsPerPixel: 32 [ 78.220] NumberOfBanks: 1 [ 78.220] MemoryModel: 6 [ 78.220] BankSize: 0 [ 78.220] NumberOfImages: 6 [ 78.220] RedMaskSize: 8 [ 78.220] RedFieldPosition: 16 [ 78.220] GreenMaskSize: 8 [ 78.220] GreenFieldPosition: 8 [ 78.220] BlueMaskSize: 8 [ 78.220] BlueFieldPosition: 0 [ 78.220] RsvdMaskSize: 8 [ 78.220] RsvdFieldPosition: 24 [ 78.220] DirectColorModeInfo: 0 [ 78.220] PhysBasePtr: 0xcf000000 [ 78.220] LinBytesPerScanLine: 1280 [ 78.220] BnkNumberOfImagePages: 6 [ 78.220] LinNumberOfImagePages: 6 [ 78.220] LinRedMaskSize: 8 [ 78.220] LinRedFieldPosition: 16 [ 78.220] LinGreenMaskSize: 8 [ 78.220] LinGreenFieldPosition: 8 [ 78.220] LinBlueMaskSize: 8 [ 78.220] LinBlueFieldPosition: 0 [ 78.220] LinRsvdMaskSize: 8 [ 78.220] LinRsvdFieldPosition: 24 [ 78.220] MaxPixelClock: 229500000 [ 78.222] Mode: 134 (320x240) [ 78.222] ModeAttributes: 0x3bf [ 78.222] WinAAttributes: 0x7 [ 78.222] WinBAttributes: 0x0 [ 78.222] WinGranularity: 64 [ 78.222] WinSize: 64 [ 78.222] WinASegment: 0xa000 [ 78.222] WinBSegment: 0x0 [ 78.222] WinFuncPtr: 0xc0007d60 [ 78.222] BytesPerScanline: 320 [ 78.222] XResolution: 320 [ 78.222] YResolution: 240 [ 78.222] XCharSize: 8 [ 78.222] YCharSize: 8 [ 78.222] NumberOfPlanes: 1 [ 78.222] BitsPerPixel: 8 [ 78.222] NumberOfBanks: 1 [ 78.222] MemoryModel: 4 [ 78.222] BankSize: 0 [ 78.222] NumberOfImages: 30 [ 78.222] RedMaskSize: 0 [ 78.222] RedFieldPosition: 0 [ 78.222] GreenMaskSize: 0 [ 78.222] GreenFieldPosition: 0 [ 78.222] BlueMaskSize: 0 [ 78.222] BlueFieldPosition: 0 [ 78.222] RsvdMaskSize: 0 [ 78.222] RsvdFieldPosition: 0 [ 78.222] DirectColorModeInfo: 0 [ 78.222] PhysBasePtr: 0xcf000000 [ 78.222] LinBytesPerScanLine: 320 [ 78.222] BnkNumberOfImagePages: 30 [ 78.222] LinNumberOfImagePages: 30 [ 78.222] LinRedMaskSize: 0 [ 78.222] LinRedFieldPosition: 0 [ 78.222] LinGreenMaskSize: 0 [ 78.222] LinGreenFieldPosition: 0 [ 78.222] LinBlueMaskSize: 0 [ 78.222] LinBlueFieldPosition: 0 [ 78.222] LinRsvdMaskSize: 0 [ 78.222] LinRsvdFieldPosition: 0 [ 78.222] MaxPixelClock: 229500000 [ 78.224] Mode: 135 (320x240) [ 78.224] ModeAttributes: 0x3bf [ 78.224] WinAAttributes: 0x7 [ 78.224] WinBAttributes: 0x0 [ 78.224] WinGranularity: 64 [ 78.224] WinSize: 64 [ 78.224] WinASegment: 0xa000 [ 78.224] WinBSegment: 0x0 [ 78.224] WinFuncPtr: 0xc0007d60 [ 78.224] BytesPerScanline: 640 [ 78.224] XResolution: 320 [ 78.224] YResolution: 240 [ 78.224] XCharSize: 8 [ 78.224] YCharSize: 8 [ 78.224] NumberOfPlanes: 1 [ 78.224] BitsPerPixel: 16 [ 78.224] NumberOfBanks: 1 [ 78.224] MemoryModel: 6 [ 78.224] BankSize: 0 [ 78.224] NumberOfImages: 19 [ 78.224] RedMaskSize: 5 [ 78.224] RedFieldPosition: 11 [ 78.224] GreenMaskSize: 6 [ 78.224] GreenFieldPosition: 5 [ 78.224] BlueMaskSize: 5 [ 78.224] BlueFieldPosition: 0 [ 78.224] RsvdMaskSize: 0 [ 78.224] RsvdFieldPosition: 0 [ 78.224] DirectColorModeInfo: 0 [ 78.224] PhysBasePtr: 0xcf000000 [ 78.224] LinBytesPerScanLine: 640 [ 78.224] BnkNumberOfImagePages: 19 [ 78.224] LinNumberOfImagePages: 19 [ 78.224] LinRedMaskSize: 5 [ 78.224] LinRedFieldPosition: 11 [ 78.224] LinGreenMaskSize: 6 [ 78.224] LinGreenFieldPosition: 5 [ 78.224] LinBlueMaskSize: 5 [ 78.224] LinBlueFieldPosition: 0 [ 78.224] LinRsvdMaskSize: 0 [ 78.224] LinRsvdFieldPosition: 0 [ 78.224] MaxPixelClock: 229500000 [ 78.226] *Mode: 136 (320x240) [ 78.226] ModeAttributes: 0x3bf [ 78.226] WinAAttributes: 0x7 [ 78.226] WinBAttributes: 0x0 [ 78.226] WinGranularity: 64 [ 78.226] WinSize: 64 [ 78.226] WinASegment: 0xa000 [ 78.226] WinBSegment: 0x0 [ 78.226] WinFuncPtr: 0xc0007d60 [ 78.226] BytesPerScanline: 1280 [ 78.226] XResolution: 320 [ 78.226] YResolution: 240 [ 78.226] XCharSize: 8 [ 78.226] YCharSize: 8 [ 78.226] NumberOfPlanes: 1 [ 78.226] BitsPerPixel: 32 [ 78.226] NumberOfBanks: 1 [ 78.226] MemoryModel: 6 [ 78.226] BankSize: 0 [ 78.226] NumberOfImages: 10 [ 78.226] RedMaskSize: 8 [ 78.226] RedFieldPosition: 16 [ 78.226] GreenMaskSize: 8 [ 78.226] GreenFieldPosition: 8 [ 78.226] BlueMaskSize: 8 [ 78.226] BlueFieldPosition: 0 [ 78.226] RsvdMaskSize: 8 [ 78.226] RsvdFieldPosition: 24 [ 78.226] DirectColorModeInfo: 0 [ 78.226] PhysBasePtr: 0xcf000000 [ 78.226] LinBytesPerScanLine: 1280 [ 78.226] BnkNumberOfImagePages: 10 [ 78.226] LinNumberOfImagePages: 10 [ 78.226] LinRedMaskSize: 8 [ 78.226] LinRedFieldPosition: 16 [ 78.226] LinGreenMaskSize: 8 [ 78.226] LinGreenFieldPosition: 8 [ 78.226] LinBlueMaskSize: 8 [ 78.226] LinBlueFieldPosition: 0 [ 78.226] LinRsvdMaskSize: 8 [ 78.226] LinRsvdFieldPosition: 24 [ 78.226] MaxPixelClock: 229500000 [ 78.228] Mode: 13d (640x400) [ 78.228] ModeAttributes: 0x3bf [ 78.228] WinAAttributes: 0x7 [ 78.228] WinBAttributes: 0x0 [ 78.228] WinGranularity: 64 [ 78.228] WinSize: 64 [ 78.228] WinASegment: 0xa000 [ 78.228] WinBSegment: 0x0 [ 78.228] WinFuncPtr: 0xc0007d60 [ 78.228] BytesPerScanline: 1280 [ 78.228] XResolution: 640 [ 78.228] YResolution: 400 [ 78.228] XCharSize: 8 [ 78.228] YCharSize: 16 [ 78.228] NumberOfPlanes: 1 [ 78.228] BitsPerPixel: 16 [ 78.228] NumberOfBanks: 1 [ 78.228] MemoryModel: 6 [ 78.228] BankSize: 0 [ 78.228] NumberOfImages: 6 [ 78.228] RedMaskSize: 5 [ 78.228] RedFieldPosition: 11 [ 78.228] GreenMaskSize: 6 [ 78.228] GreenFieldPosition: 5 [ 78.228] BlueMaskSize: 5 [ 78.228] BlueFieldPosition: 0 [ 78.228] RsvdMaskSize: 0 [ 78.228] RsvdFieldPosition: 0 [ 78.228] DirectColorModeInfo: 0 [ 78.228] PhysBasePtr: 0xcf000000 [ 78.228] LinBytesPerScanLine: 1280 [ 78.228] BnkNumberOfImagePages: 6 [ 78.228] LinNumberOfImagePages: 6 [ 78.228] LinRedMaskSize: 5 [ 78.228] LinRedFieldPosition: 11 [ 78.228] LinGreenMaskSize: 6 [ 78.228] LinGreenFieldPosition: 5 [ 78.228] LinBlueMaskSize: 5 [ 78.228] LinBlueFieldPosition: 0 [ 78.228] LinRsvdMaskSize: 0 [ 78.228] LinRsvdFieldPosition: 0 [ 78.228] MaxPixelClock: 229500000 [ 78.229] *Mode: 13e (640x400) [ 78.229] ModeAttributes: 0x3bf [ 78.229] WinAAttributes: 0x7 [ 78.229] WinBAttributes: 0x0 [ 78.229] WinGranularity: 64 [ 78.229] WinSize: 64 [ 78.229] WinASegment: 0xa000 [ 78.229] WinBSegment: 0x0 [ 78.229] WinFuncPtr: 0xc0007d60 [ 78.229] BytesPerScanline: 2560 [ 78.229] XResolution: 640 [ 78.230] YResolution: 400 [ 78.230] XCharSize: 8 [ 78.230] YCharSize: 16 [ 78.230] NumberOfPlanes: 1 [ 78.230] BitsPerPixel: 32 [ 78.230] NumberOfBanks: 1 [ 78.230] MemoryModel: 6 [ 78.230] BankSize: 0 [ 78.230] NumberOfImages: 2 [ 78.230] RedMaskSize: 8 [ 78.230] RedFieldPosition: 16 [ 78.230] GreenMaskSize: 8 [ 78.230] GreenFieldPosition: 8 [ 78.230] BlueMaskSize: 8 [ 78.230] BlueFieldPosition: 0 [ 78.230] RsvdMaskSize: 8 [ 78.230] RsvdFieldPosition: 24 [ 78.230] DirectColorModeInfo: 0 [ 78.230] PhysBasePtr: 0xcf000000 [ 78.230] LinBytesPerScanLine: 2560 [ 78.230] BnkNumberOfImagePages: 2 [ 78.230] LinNumberOfImagePages: 2 [ 78.230] LinRedMaskSize: 8 [ 78.230] LinRedFieldPosition: 16 [ 78.230] LinGreenMaskSize: 8 [ 78.230] LinGreenFieldPosition: 8 [ 78.230] LinBlueMaskSize: 8 [ 78.230] LinBlueFieldPosition: 0 [ 78.230] LinRsvdMaskSize: 8 [ 78.230] LinRsvdFieldPosition: 24 [ 78.230] MaxPixelClock: 229500000 [ 78.231] Mode: 14b (1920x1080) [ 78.231] ModeAttributes: 0x3bf [ 78.231] WinAAttributes: 0x7 [ 78.231] WinBAttributes: 0x0 [ 78.231] WinGranularity: 64 [ 78.231] WinSize: 64 [ 78.231] WinASegment: 0xa000 [ 78.231] WinBSegment: 0x0 [ 78.231] WinFuncPtr: 0xc0007d60 [ 78.231] BytesPerScanline: 1920 [ 78.231] XResolution: 1920 [ 78.231] YResolution: 1080 [ 78.231] XCharSize: 8 [ 78.231] YCharSize: 16 [ 78.231] NumberOfPlanes: 1 [ 78.231] BitsPerPixel: 8 [ 78.231] NumberOfBanks: 1 [ 78.231] MemoryModel: 4 [ 78.231] BankSize: 0 [ 78.231] NumberOfImages: 1 [ 78.231] RedMaskSize: 0 [ 78.231] RedFieldPosition: 0 [ 78.232] GreenMaskSize: 0 [ 78.232] GreenFieldPosition: 0 [ 78.232] BlueMaskSize: 0 [ 78.232] BlueFieldPosition: 0 [ 78.232] RsvdMaskSize: 0 [ 78.232] RsvdFieldPosition: 0 [ 78.232] DirectColorModeInfo: 0 [ 78.232] PhysBasePtr: 0xcf000000 [ 78.232] LinBytesPerScanLine: 1920 [ 78.232] BnkNumberOfImagePages: 1 [ 78.232] LinNumberOfImagePages: 1 [ 78.232] LinRedMaskSize: 0 [ 78.232] LinRedFieldPosition: 0 [ 78.232] LinGreenMaskSize: 0 [ 78.232] LinGreenFieldPosition: 0 [ 78.232] LinBlueMaskSize: 0 [ 78.232] LinBlueFieldPosition: 0 [ 78.232] LinRsvdMaskSize: 0 [ 78.232] LinRsvdFieldPosition: 0 [ 78.232] MaxPixelClock: 229500000 [ 78.233] Mode: 14c (1920x1080) [ 78.233] ModeAttributes: 0x3bf [ 78.233] WinAAttributes: 0x7 [ 78.233] WinBAttributes: 0x0 [ 78.233] WinGranularity: 64 [ 78.233] WinSize: 64 [ 78.233] WinASegment: 0xa000 [ 78.233] WinBSegment: 0x0 [ 78.233] WinFuncPtr: 0xc0007d60 [ 78.233] BytesPerScanline: 3840 [ 78.233] XResolution: 1920 [ 78.233] YResolution: 1080 [ 78.233] XCharSize: 8 [ 78.233] YCharSize: 16 [ 78.233] NumberOfPlanes: 1 [ 78.233] BitsPerPixel: 16 [ 78.233] NumberOfBanks: 1 [ 78.233] MemoryModel: 6 [ 78.233] BankSize: 0 [ 78.233] NumberOfImages: 1 [ 78.233] RedMaskSize: 5 [ 78.233] RedFieldPosition: 11 [ 78.233] GreenMaskSize: 6 [ 78.233] GreenFieldPosition: 5 [ 78.233] BlueMaskSize: 5 [ 78.233] BlueFieldPosition: 0 [ 78.233] RsvdMaskSize: 0 [ 78.233] RsvdFieldPosition: 0 [ 78.233] DirectColorModeInfo: 0 [ 78.233] PhysBasePtr: 0xcf000000 [ 78.233] LinBytesPerScanLine: 3840 [ 78.233] BnkNumberOfImagePages: 1 [ 78.233] LinNumberOfImagePages: 1 [ 78.234] LinRedMaskSize: 5 [ 78.234] LinRedFieldPosition: 11 [ 78.234] LinGreenMaskSize: 6 [ 78.234] LinGreenFieldPosition: 5 [ 78.234] LinBlueMaskSize: 5 [ 78.234] LinBlueFieldPosition: 0 [ 78.234] LinRsvdMaskSize: 0 [ 78.234] LinRsvdFieldPosition: 0 [ 78.234] MaxPixelClock: 229500000 [ 78.235] *Mode: 14d (1920x1080) [ 78.235] ModeAttributes: 0x3bf [ 78.235] WinAAttributes: 0x7 [ 78.235] WinBAttributes: 0x0 [ 78.235] WinGranularity: 64 [ 78.235] WinSize: 64 [ 78.235] WinASegment: 0xa000 [ 78.235] WinBSegment: 0x0 [ 78.235] WinFuncPtr: 0xc0007d60 [ 78.235] BytesPerScanline: 7680 [ 78.235] XResolution: 1920 [ 78.235] YResolution: 1080 [ 78.235] XCharSize: 8 [ 78.235] YCharSize: 16 [ 78.235] NumberOfPlanes: 1 [ 78.235] BitsPerPixel: 32 [ 78.235] NumberOfBanks: 1 [ 78.235] MemoryModel: 6 [ 78.235] BankSize: 0 [ 78.235] NumberOfImages: 1 [ 78.235] RedMaskSize: 8 [ 78.235] RedFieldPosition: 16 [ 78.235] GreenMaskSize: 8 [ 78.235] GreenFieldPosition: 8 [ 78.235] BlueMaskSize: 8 [ 78.235] BlueFieldPosition: 0 [ 78.235] RsvdMaskSize: 8 [ 78.235] RsvdFieldPosition: 24 [ 78.235] DirectColorModeInfo: 0 [ 78.235] PhysBasePtr: 0xcf000000 [ 78.235] LinBytesPerScanLine: 7680 [ 78.235] BnkNumberOfImagePages: 1 [ 78.235] LinNumberOfImagePages: 1 [ 78.235] LinRedMaskSize: 8 [ 78.235] LinRedFieldPosition: 16 [ 78.235] LinGreenMaskSize: 8 [ 78.235] LinGreenFieldPosition: 8 [ 78.235] LinBlueMaskSize: 8 [ 78.235] LinBlueFieldPosition: 0 [ 78.235] LinRsvdMaskSize: 8 [ 78.235] LinRsvdFieldPosition: 24 [ 78.235] MaxPixelClock: 229500000 [ 78.237] Mode: 160 (1280x800) [ 78.237] ModeAttributes: 0x3bf [ 78.237] WinAAttributes: 0x7 [ 78.237] WinBAttributes: 0x0 [ 78.237] WinGranularity: 64 [ 78.237] WinSize: 64 [ 78.237] WinASegment: 0xa000 [ 78.237] WinBSegment: 0x0 [ 78.237] WinFuncPtr: 0xc0007d60 [ 78.237] BytesPerScanline: 1280 [ 78.237] XResolution: 1280 [ 78.237] YResolution: 800 [ 78.237] XCharSize: 8 [ 78.237] YCharSize: 16 [ 78.237] NumberOfPlanes: 1 [ 78.237] BitsPerPixel: 8 [ 78.237] NumberOfBanks: 1 [ 78.237] MemoryModel: 4 [ 78.237] BankSize: 0 [ 78.237] NumberOfImages: 2 [ 78.237] RedMaskSize: 0 [ 78.237] RedFieldPosition: 0 [ 78.237] GreenMaskSize: 0 [ 78.237] GreenFieldPosition: 0 [ 78.237] BlueMaskSize: 0 [ 78.237] BlueFieldPosition: 0 [ 78.237] RsvdMaskSize: 0 [ 78.237] RsvdFieldPosition: 0 [ 78.237] DirectColorModeInfo: 0 [ 78.237] PhysBasePtr: 0xcf000000 [ 78.237] LinBytesPerScanLine: 1280 [ 78.237] BnkNumberOfImagePages: 2 [ 78.237] LinNumberOfImagePages: 2 [ 78.237] LinRedMaskSize: 0 [ 78.237] LinRedFieldPosition: 0 [ 78.237] LinGreenMaskSize: 0 [ 78.237] LinGreenFieldPosition: 0 [ 78.237] LinBlueMaskSize: 0 [ 78.237] LinBlueFieldPosition: 0 [ 78.237] LinRsvdMaskSize: 0 [ 78.237] LinRsvdFieldPosition: 0 [ 78.237] MaxPixelClock: 229500000 [ 78.239] *Mode: 161 (1280x800) [ 78.239] ModeAttributes: 0x3bf [ 78.239] WinAAttributes: 0x7 [ 78.239] WinBAttributes: 0x0 [ 78.239] WinGranularity: 64 [ 78.239] WinSize: 64 [ 78.239] WinASegment: 0xa000 [ 78.239] WinBSegment: 0x0 [ 78.239] WinFuncPtr: 0xc0007d60 [ 78.239] BytesPerScanline: 5120 [ 78.239] XResolution: 1280 [ 78.239] YResolution: 800 [ 78.239] XCharSize: 8 [ 78.239] YCharSize: 16 [ 78.239] NumberOfPlanes: 1 [ 78.239] BitsPerPixel: 32 [ 78.239] NumberOfBanks: 1 [ 78.239] MemoryModel: 6 [ 78.239] BankSize: 0 [ 78.239] NumberOfImages: 1 [ 78.239] RedMaskSize: 8 [ 78.239] RedFieldPosition: 16 [ 78.239] GreenMaskSize: 8 [ 78.239] GreenFieldPosition: 8 [ 78.239] BlueMaskSize: 8 [ 78.239] BlueFieldPosition: 0 [ 78.239] RsvdMaskSize: 8 [ 78.239] RsvdFieldPosition: 24 [ 78.239] DirectColorModeInfo: 0 [ 78.239] PhysBasePtr: 0xcf000000 [ 78.239] LinBytesPerScanLine: 5120 [ 78.239] BnkNumberOfImagePages: 1 [ 78.239] LinNumberOfImagePages: 1 [ 78.239] LinRedMaskSize: 8 [ 78.239] LinRedFieldPosition: 16 [ 78.239] LinGreenMaskSize: 8 [ 78.239] LinGreenFieldPosition: 8 [ 78.239] LinBlueMaskSize: 8 [ 78.239] LinBlueFieldPosition: 0 [ 78.239] LinRsvdMaskSize: 8 [ 78.239] LinRsvdFieldPosition: 24 [ 78.239] MaxPixelClock: 229500000 [ 78.239] [ 78.239] (II) VESA(0): Total Memory: 256 64KB banks (16384kB) [ 78.239] (II) VESA(0): <default monitor>: Using hsync range of 30.00-80.00 kHz [ 78.239] (II) VESA(0): <default monitor>: Using vrefresh range of 55.00-76.00 Hz [ 78.239] (II) VESA(0): <default monitor>: Using maximum pixel clock of 175.00 MHz [ 78.239] (WW) VESA(0): Unable to estimate virtual size [ 78.243] (II) VESA(0): Not using built-in mode "640x400" (no mode of this name) [ 78.243] (II) VESA(0): Not using built-in mode "320x400" (no mode of this name) [ 78.243] (II) VESA(0): Not using built-in mode "320x240" (no mode of this name) [ 78.243] (II) VESA(0): Not using built-in mode "320x200" (no mode of this name) [ 78.243] (--) VESA(0): Virtual size is 1920x1080 (pitch 1920) [ 78.243] (**) VESA(0): *Built-in mode "1920x1080" [ 78.243] (**) VESA(0): *Built-in mode "1280x1024" [ 78.243] (**) VESA(0): *Built-in mode "1280x800" [ 78.243] (**) VESA(0): *Built-in mode "1024x768" [ 78.243] (**) VESA(0): *Built-in mode "800x600" [ 78.243] (**) VESA(0): *Built-in mode "640x480" [ 78.243] (**) VESA(0): Display dimensions: (530, 300) mm [ 78.243] (**) VESA(0): DPI set to (92, 91) [ 78.243] (**) VESA(0): Using "Shadow Framebuffer" [ 78.243] (II) Loading sub module "shadow" [ 78.243] (II) LoadModule: "shadow" [ 78.243] (II) Loading /usr/lib64/xorg/modules/libshadow.so [ 78.243] (II) Module shadow: vendor="X.Org Foundation" [ 78.243] compiled for 1.19.5, module version = 1.1.0 [ 78.243] ABI class: X.Org ANSI C Emulation, version 0.4 [ 78.243] (II) Loading sub module "fb" [ 78.243] (II) LoadModule: "fb" [ 78.243] (II) Loading /usr/lib64/xorg/modules/libfb.so [ 78.244] (II) Module fb: vendor="X.Org Foundation" [ 78.244] compiled for 1.19.5, module version = 1.0.0 [ 78.244] ABI class: X.Org ANSI C Emulation, version 0.4 [ 78.244] (==) Depth 24 pixmap format is 32 bpp [ 78.244] (II) Loading sub module "int10" [ 78.244] (II) LoadModule: "int10" [ 78.244] (II) Loading /usr/lib64/xorg/modules/libint10.so [ 78.244] (II) Module int10: vendor="X.Org Foundation" [ 78.244] compiled for 1.19.5, module version = 1.0.0 [ 78.244] ABI class: X.Org Video Driver, version 23.0 [ 78.244] (II) VESA(0): initializing int10 [ 78.244] (II) VESA(0): Primary V_BIOS segment is: 0xc000 [ 78.310] (II) VESA(0): VESA BIOS detected [ 78.310] (II) VESA(0): VESA VBE Version 3.0 [ 78.310] (II) VESA(0): VESA VBE Total Mem: 16384 kB [ 78.310] (II) VESA(0): VESA VBE OEM: NVIDIA [ 78.310] (II) VESA(0): VESA VBE OEM Software Rev: 132.4 [ 78.310] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation [ 78.310] (II) VESA(0): VESA VBE OEM Product: GM204 Board [ 78.310] (II) VESA(0): VESA VBE OEM Product Rev: Chip Rev [ 78.310] (II) VESA(0): virtual address = 0x7f5ac8adc000, physical address = 0xcf000000, size = 16777216 [ 78.333] (II) VESA(0): Setting up VESA Mode 0x14D (1920x1080) [ 78.412] (==) VESA(0): Default visual is TrueColor [ 78.412] (==) VESA(0): Backing store enabled [ 78.412] (==) VESA(0): DPMS enabled [ 78.412] (==) RandR enabled [ 78.415] (II) SELinux: Disabled by boolean [ 78.416] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found) [ 78.466] (II) config/udev: Adding input device Power Button (/dev/input/event1) [ 78.466] (**) Power Button: Applying InputClass "evdev keyboard catchall" [ 78.466] (**) Power Button: Applying InputClass "libinput keyboard catchall" [ 78.467] (**) Power Button: Applying InputClass "system-keyboard" [ 78.467] (II) LoadModule: "libinput" [ 78.467] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so [ 78.473] (II) Module libinput: vendor="X.Org Foundation" [ 78.473] compiled for 1.19.3, module version = 0.26.0 [ 78.473] Module class: X.Org XInput Driver [ 78.473] ABI class: X.Org XInput driver, version 24.1 [ 78.473] (II) Using input driver 'libinput' for 'Power Button' [ 78.474] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 20 paused 0 [ 78.474] (**) Power Button: always reports core events [ 78.474] (**) Option "Device" "/dev/input/event1" [ 78.474] (**) Option "_source" "server/udev" [ 78.475] (II) event1 - (II) Power Button: (II) is tagged by udev as: Keyboard [ 78.475] (II) event1 - (II) Power Button: (II) device is a keyboard [ 78.475] (II) event1 - (II) Power Button: (II) device removed [ 78.475] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1" [ 78.475] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6) [ 78.475] (**) Option "xkb_layout" "gb,pl" [ 78.475] (**) Option "xkb_variant" "," [ 78.496] (II) event1 - (II) Power Button: (II) is tagged by udev as: Keyboard [ 78.496] (II) event1 - (II) Power Button: (II) device is a keyboard [ 78.497] (II) config/udev: Adding input device Power Button (/dev/input/event0) [ 78.497] (**) Power Button: Applying InputClass "evdev keyboard catchall" [ 78.497] (**) Power Button: Applying InputClass "libinput keyboard catchall" [ 78.497] (**) Power Button: Applying InputClass "system-keyboard" [ 78.497] (II) Using input driver 'libinput' for 'Power Button' [ 78.498] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 23 paused 0 [ 78.498] (**) Power Button: always reports core events [ 78.498] (**) Option "Device" "/dev/input/event0" [ 78.498] (**) Option "_source" "server/udev" [ 78.499] (II) event0 - (II) Power Button: (II) is tagged by udev as: Keyboard [ 78.499] (II) event0 - (II) Power Button: (II) device is a keyboard [ 78.499] (II) event0 - (II) Power Button: (II) device removed [ 78.499] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0" [ 78.499] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7) [ 78.499] (**) Option "xkb_layout" "gb,pl" [ 78.499] (**) Option "xkb_variant" "," [ 78.500] (II) event0 - (II) Power Button: (II) is tagged by udev as: Keyboard [ 78.500] (II) event0 - (II) Power Button: (II) device is a keyboard [ 78.500] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event4) [ 78.500] (II) No input driver specified, ignoring this device. [ 78.500] (II) This device may have been added with another device file. [ 78.501] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event5) [ 78.501] (II) No input driver specified, ignoring this device. [ 78.501] (II) This device may have been added with another device file. [ 78.502] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event6) [ 78.502] (II) No input driver specified, ignoring this device. [ 78.502] (II) This device may have been added with another device file. [ 78.502] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event7) [ 78.502] (II) No input driver specified, ignoring this device. [ 78.502] (II) This device may have been added with another device file. [ 78.503] (II) config/udev: Adding input device HDA Creative Line (/dev/input/event9) [ 78.503] (II) No input driver specified, ignoring this device. [ 78.503] (II) This device may have been added with another device file. [ 78.504] (II) config/udev: Adding input device HDA Creative Line Out Front (/dev/input/event10) [ 78.504] (II) No input driver specified, ignoring this device. [ 78.504] (II) This device may have been added with another device file. [ 78.504] (II) config/udev: Adding input device HDA Creative Line Out Surround (/dev/input/event11) [ 78.504] (II) No input driver specified, ignoring this device. [ 78.504] (II) This device may have been added with another device file. [ 78.505] (II) config/udev: Adding input device HDA Creative Line Out CLFE (/dev/input/event12) [ 78.505] (II) No input driver specified, ignoring this device. [ 78.505] (II) This device may have been added with another device file. [ 78.506] (II) config/udev: Adding input device HDA Creative Line Out Side (/dev/input/event13) [ 78.506] (II) No input driver specified, ignoring this device. [ 78.506] (II) This device may have been added with another device file. [ 78.506] (II) config/udev: Adding input device HDA Creative Front Headphone (/dev/input/event14) [ 78.506] (II) No input driver specified, ignoring this device. [ 78.506] (II) This device may have been added with another device file. [ 78.507] (II) config/udev: Adding input device HDA Creative Mic (/dev/input/event8) [ 78.507] (II) No input driver specified, ignoring this device. [ 78.507] (II) This device may have been added with another device file. [ 78.508] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event2) [ 78.508] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall" [ 78.508] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall" [ 78.508] (**) Logitech USB Receiver: Applying InputClass "system-keyboard" [ 78.508] (II) Using input driver 'libinput' for 'Logitech USB Receiver' [ 78.509] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 24 paused 0 [ 78.509] (**) Logitech USB Receiver: always reports core events [ 78.509] (**) Option "Device" "/dev/input/event2" [ 78.509] (**) Option "_source" "server/udev" [ 78.510] (II) event2 - (II) Logitech USB Receiver: (II) is tagged by udev as: Keyboard [ 78.510] (II) event2 - (II) Logitech USB Receiver: (II) device is a keyboard [ 78.510] (II) event2 - (II) Logitech USB Receiver: (II) device removed [ 78.510] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.1/usb7/7-1/7-1:1.0/0003:046D:C534.0001/input/input3/event2" [ 78.510] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 8) [ 78.510] (**) Option "xkb_layout" "gb,pl" [ 78.510] (**) Option "xkb_variant" "," [ 78.511] (II) event2 - (II) Logitech USB Receiver: (II) is tagged by udev as: Keyboard [ 78.511] (II) event2 - (II) Logitech USB Receiver: (II) device is a keyboard [ 78.512] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event3) [ 78.512] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall" [ 78.512] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall" [ 78.512] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall" [ 78.512] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall" [ 78.512] (**) Logitech USB Receiver: Applying InputClass "system-keyboard" [ 78.512] (II) Using input driver 'libinput' for 'Logitech USB Receiver' [ 78.513] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 25 paused 0 [ 78.513] (**) Logitech USB Receiver: always reports core events [ 78.513] (**) Option "Device" "/dev/input/event3" [ 78.513] (**) Option "_source" "server/udev" [ 78.514] (II) event3 - (II) Logitech USB Receiver: (II) is tagged by udev as: Keyboard Mouse [ 78.514] (II) event3 - (II) Logitech USB Receiver: (II) device is a pointer [ 78.514] (II) event3 - (II) Logitech USB Receiver: (II) device is a keyboard [ 78.514] (II) event3 - (II) Logitech USB Receiver: (II) device removed [ 78.514] (II) libinput: Logitech USB Receiver: needs a virtual subdevice [ 78.514] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.1/usb7/7-1/7-1:1.1/0003:046D:C534.0002/input/input4/event3" [ 78.514] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 9) [ 78.514] (**) Option "AccelerationScheme" "none" [ 78.514] (**) Logitech USB Receiver: (accel) selected scheme none/0 [ 78.514] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000 [ 78.514] (**) Logitech USB Receiver: (accel) acceleration threshold: 4 [ 78.515] (II) event3 - (II) Logitech USB Receiver: (II) is tagged by udev as: Keyboard Mouse [ 78.515] (II) event3 - (II) Logitech USB Receiver: (II) device is a pointer [ 78.515] (II) event3 - (II) Logitech USB Receiver: (II) device is a keyboard [ 78.516] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0) [ 78.516] (**) Logitech USB Receiver: Applying InputClass "system-keyboard" [ 78.516] (II) No input driver specified, ignoring this device. [ 78.516] (II) This device may have been added with another device file. [ 78.517] (II) config/udev: Adding input device FULL HD 1080P Webcam: FULL HD 1 (/dev/input/event15) [ 78.517] (**) FULL HD 1080P Webcam: FULL HD 1: Applying InputClass "evdev keyboard catchall" [ 78.517] (**) FULL HD 1080P Webcam: FULL HD 1: Applying InputClass "libinput keyboard catchall" [ 78.517] (**) FULL HD 1080P Webcam: FULL HD 1: Applying InputClass "system-keyboard" [ 78.517] (II) Using input driver 'libinput' for 'FULL HD 1080P Webcam: FULL HD 1' [ 78.518] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 26 paused 0 [ 78.518] (**) FULL HD 1080P Webcam: FULL HD 1: always reports core events [ 78.518] (**) Option "Device" "/dev/input/event15" [ 78.518] (**) Option "_source" "server/udev" [ 78.519] (II) event15 - (II) FULL HD 1080P Webcam: FULL HD 1: (II) is tagged by udev as: Keyboard [ 78.519] (II) event15 - (II) FULL HD 1080P Webcam: FULL HD 1: (II) device is a keyboard [ 78.519] (II) event15 - (II) FULL HD 1080P Webcam: FULL HD 1: (II) device removed [ 78.519] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.7/usb2/2-5/2-5:1.0/input/input16/event15" [ 78.519] (II) XINPUT: Adding extended input device "FULL HD 1080P Webcam: FULL HD 1" (type: KEYBOARD, id 10) [ 78.519] (**) Option "xkb_layout" "gb,pl" [ 78.519] (**) Option "xkb_variant" "," [ 78.520] (II) event15 - (II) FULL HD 1080P Webcam: FULL HD 1: (II) is tagged by udev as: Keyboard [ 78.520] (II) event15 - (II) FULL HD 1080P Webcam: FULL HD 1: (II) device is a keyboard [ 78.532] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall" [ 78.532] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall" [ 78.532] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall" [ 78.532] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall" [ 78.532] (**) Logitech USB Receiver: Applying InputClass "system-keyboard" [ 78.532] (II) Using input driver 'libinput' for 'Logitech USB Receiver' [ 78.532] (II) systemd-logind: returning pre-existing fd for /dev/input/event3 13:67 [ 78.532] (**) Logitech USB Receiver: always reports core events [ 78.532] (**) Option "Device" "/dev/input/event3" [ 78.532] (**) Option "_source" "_driver/libinput" [ 78.532] (II) libinput: Logitech USB Receiver: is a virtual subdevice [ 78.532] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.1/usb7/7-1/7-1:1.1/0003:046D:C534.0002/input/input4/event3" [ 78.532] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 11) [ 78.532] (**) Option "xkb_layout" "gb,pl" [ 78.532] (**) Option "xkb_variant" "," [ 79.277] (**) Option "fd" "20" [ 79.277] (II) event1 - (II) Power Button: (II) device removed [ 79.277] (**) Option "fd" "23" [ 79.277] (II) event0 - (II) Power Button: (II) device removed [ 79.277] (**) Option "fd" "24" [ 79.277] (II) event2 - (II) Logitech USB Receiver: (II) device removed [ 79.278] (**) Option "fd" "25" [ 79.278] (**) Option "fd" "26" [ 79.278] (II) event15 - (II) FULL HD 1080P Webcam: FULL HD 1: (II) device removed [ 79.278] (**) Option "fd" "25" [ 79.278] (II) event3 - (II) Logitech USB Receiver: (II) device removed [ 79.279] (II) UnloadModule: "libinput" [ 79.279] (II) systemd-logind: not releasing fd for 13:67, still in use [ 79.279] (II) UnloadModule: "libinput" [ 79.279] (II) systemd-logind: releasing fd for 13:79 [ 79.287] (II) UnloadModule: "libinput" [ 79.287] (II) systemd-logind: releasing fd for 13:67 [ 79.297] (II) UnloadModule: "libinput" [ 79.297] (II) systemd-logind: releasing fd for 13:66 [ 79.301] (II) UnloadModule: "libinput" [ 79.301] (II) systemd-logind: releasing fd for 13:64 [ 79.306] (II) UnloadModule: "libinput" [ 79.306] (II) systemd-logind: releasing fd for 13:65 [ 79.496] (II) Server terminated successfully (0). Closing log file. a to dla sterownika 384 ze strony nVidia: [ 201.335] (--) Log file renamed from "/var/log/Xorg.pid-16564.log" to "/var/log/Xorg.0.log" [ 201.336] X.Org X Server 1.19.5 Release Date: 2017-10-12 [ 201.336] X Protocol Version 11, Revision 0 [ 201.336] Build Operating System: 4.12.9-300.fc26.x86_64 [ 201.336] Current Operating System: Linux localhost.localdomain 4.14.11-300.fc27.x86_64 #1 SMP Wed Jan 3 13:52:28 UTC 2018 x86_64 [ 201.336] Kernel command line: BOOT_IMAGE=/vmlinuz-4.14.11-300.fc27.x86_64 root=/dev/mapper/fedora-root ro rd.lvm.lv=fedora/root rd.lvm.lv=fedora/swap rhgb quiet LANG=pl_PL.UTF-8 [ 201.336] Build Date: 12 October 2017 07:35:27PM [ 201.336] Build ID: xorg-x11-server 1.19.5-1.fc27 [ 201.336] Current version of pixman: 0.34.0 [ 201.336] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 201.336] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 201.336] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 4 13:00:40 2018 [ 201.337] (==) Using config file: "/etc/X11/xorg.conf" [ 201.337] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 201.337] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 201.337] (==) ServerLayout "Layout0" [ 201.337] (**) |-->Screen "Screen0" (0) [ 201.337] (**) | |-->Monitor "Monitor0" [ 201.337] (**) | |-->Device "Device0" [ 201.337] (**) |-->Input Device "Keyboard0" [ 201.337] (**) |-->Input Device "Mouse0" [ 201.337] (==) Automatically adding devices [ 201.337] (==) Automatically enabling devices [ 201.337] (==) Automatically adding GPU devices [ 201.337] (==) Automatically binding GPU devices [ 201.337] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 201.337] (==) FontPath set to: catalogue:/etc/X11/fontpath.d, built-ins [ 201.337] (==) ModulePath set to "/usr/lib64/xorg/modules" [ 201.337] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled. [ 201.337] (WW) Disabling Keyboard0 [ 201.337] (WW) Disabling Mouse0 [ 201.337] (II) Loader magic: 0x821e00 [ 201.337] (II) Module ABI versions: [ 201.337] X.Org ANSI C Emulation: 0.4 [ 201.337] X.Org Video Driver: 23.0 [ 201.337] X.Org XInput driver : 24.1 [ 201.337] X.Org Server Extension : 10.0 [ 201.339] (++) using VT number 1 [ 201.342] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c503 [ 201.344] (--) PCI:*(0:1:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xfd000000/16777216, 0xd0000000/268435456, 0xce000000/33554432, I/O @ 0x0000ac00/128, BIOS @ 0x????????/131072 [ 201.344] (II) LoadModule: "glx" [ 201.345] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so [ 201.351] (II) Module glx: vendor="NVIDIA Corporation" [ 201.351] compiled for 4.0.2, module version = 1.0.0 [ 201.351] Module class: X.Org Server Extension [ 201.351] (II) NVIDIA GLX Module 384.98 Thu Oct 26 14:35:55 PDT 2017 [ 201.351] (II) LoadModule: "nvidia" [ 201.351] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so [ 201.352] (II) Module nvidia: vendor="NVIDIA Corporation" [ 201.352] compiled for 4.0.2, module version = 1.0.0 [ 201.352] Module class: X.Org Video Driver [ 201.352] (II) NVIDIA dlloader X Driver 384.98 Thu Oct 26 14:06:45 PDT 2017 [ 201.352] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs [ 201.352] (II) Loading sub module "fb" [ 201.352] (II) LoadModule: "fb" [ 201.352] (II) Loading /usr/lib64/xorg/modules/libfb.so [ 201.352] (II) Module fb: vendor="X.Org Foundation" [ 201.352] compiled for 1.19.5, module version = 1.0.0 [ 201.353] ABI class: X.Org ANSI C Emulation, version 0.4 [ 201.353] (II) Loading sub module "wfb" [ 201.353] (II) LoadModule: "wfb" [ 201.353] (II) Loading /usr/lib64/xorg/modules/libwfb.so [ 201.353] (II) Module wfb: vendor="X.Org Foundation" [ 201.353] compiled for 1.19.5, module version = 1.0.0 [ 201.353] ABI class: X.Org ANSI C Emulation, version 0.4 [ 201.353] (II) Loading sub module "ramdac" [ 201.353] (II) LoadModule: "ramdac" [ 201.353] (II) Module "ramdac" already built-in [ 201.360] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the [ 201.360] (EE) NVIDIA: system's kernel log for additional error messages and [ 201.360] (EE) NVIDIA: consult the NVIDIA README for details. [ 201.360] (EE) No devices detected. [ 201.360] (EE) Fatal server error: [ 201.360] (EE) no screens found(EE) [ 201.360] (EE) Please consult the Fedora Project support at http://wiki.x.org for help. [ 201.360] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information. [ 201.360] (EE) [ 201.361] (EE) Server terminated with error (1). Closing log file. Nie próbowałem instalacji sterowników z repo na jajku 4.14.8-300 ale wydaje mi się że pewnie by działały. Spróbuj odinstalować sterowniki nvidii całkowicie. Te z repozytoriów przeważnie działają. Następnie zainstaluj te z repozytorium. Musisz tylko ustalić jaka wersja tych sterowników jest odpowiednia dla Twojej karty graficznej. Ten link to nie była strona tylko wklejona zawartość pliku tekstowego z informacją. << Zrobiłem tak: Odinstalowałem i zainstalowałem sterowniki NVidii ponownie: Uruchomiłem ponownie komputer wybierając najnowszy kernel. Nacisnąłem kombinację klawiszy Ctrl Alt F2 czasami dopiero F3 daje skutek. Zalogowałem się. Przełączyłem się na poziom uruchomienia 3 #telinit 3 (normalny poziom to 5 i na nim nie da się przeprowadzić tych operacji) Odinstalowałem wszystko co było związane ze sterownikami grafiki: W związku z tym, że mogę korzystać z polecenia sudo: #sudo dnf erase *\nvidia\* W innym przypadku zamiast sudo wpisuje się: #su -c "dnf erase *\nvidia\* W przypadku sudo podaje się hasło do swego konta - nie roota Następnie zainstalowałem sterowniki do nvidii z repozytorium: #sudo dnf install akmod-nvidia-340xx (celowo dodałem przed nazwą pakietu literę a, oznacza ona że przy aktualizacjach systemu sterowniki do grafiki będą się automatycznie aktualizować. Pakiet bez litery a na początku jest pakietem "sztywnym" przeważnie działa tylko gdy nie aktualizujemy systemu:)) Jeżeli będzie taka potrzeba to jeszcze instalujemy jak nie to pomijamy ten krok: #sudo dnf install xorg-x11-drv-nvidia-340xx Żeby sprawdzić czy mamy ten pakiet po instalacji, piszemy: #rpm -qa | grep nvidia W moim przypadku wynik polecenia jest taki: xorg-x11-drv-nvidia-340xx-kmodsrc-340.102-1.fc25.x86_64 kmod-nvidia-340xx-4.11.3-202.fc25.x86_64-340.102-3.fc25.x86_64 xorg-x11-drv-nvidia-340xx-libs-340.102-1.fc25.x86_64 akmod-nvidia-340xx-340.102-3.fc25.x86_64 xorg-x11-drv-nvidia-340xx-340.102-1.fc25.x86_64 Sterowniki są już zainstalowane. Na wszelki wypadek daję: #sudo dnf update Po ewentualnej aktualizacji systemu przechodzę na poziom uruchomienia 5 (normalny) #sudo telinit 5 #startx U mnie np. pojawiło się u góry białe okinko z informacją o DBus. Nacisnąłem OK. Potem znów na Ctrl Alt F2 czasami dopiero F3 daje skutek Zalogowałem się na konto zwykłego użytkownika. Następnie zresetowałem komputer: #reboot Po ponownym uruchomieniu wybrałem najnowszy kernel Sprawdziłem w konsoli jak wykrywa mój monitor: #xrandr Wynik polecenia jest taki: Screen 0: minimum 8 x 8, current 1360 x 768, maximum 8192 x 8192 DVI-I-0 disconnected (normal left inverted right x axis y axis) VGA-0 connected primary 1360x768+0+0 (normal left inverted right x axis y axis) 406mm x 229mm 1360x768 60.02*+ 1280x768 59.87 1024x768 75.03 70.07 60.00 800x600 75.00 60.32 640x480 75.00 59.94 DVI-I-1 disconnected (normal left inverted right x axis y axis) HDMI-0 disconnected (normal left inverted right x axis y axis) To by było na tyle. Mam nadzieję, że Komuś to się przyda. >> Jak coś to przed poleceniami nie używaj # 1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
zibi743 Napisano Styczeń 7, 2018 Zgłoszenie Share Napisano Styczeń 7, 2018 On 06.01.2018 at 1:13 PM, SeeM said: Na kernelu 4.14.11-300 już działa, podobnie jak inne zamknięte sterowniki typu wifi broadcoma. Mogę znowu pograć. I to jest radocha jak coś nie działało a teraz działa. Tak trzymać:) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
