Pyaudio - Command 'gcc' Failed With Exit Status 1
Murt
Witam
Jak w temacie, przy próbie instalacji PyAudio pip3 sypie błąd:
[root@murtrag portaudio]# pip3 install PyAudio
Collecting PyAudio
  Using cached PyAudio-0.2.10.tar.gz
Building wheels for collected packages: PyAudio
  Running setup.py bdist_wheel for PyAudio ... error
  Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-wluo1gih/PyAudio/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmp1hcw718lpip-wheel- --python-tag cp35:
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-x86_64-3.5
  copying src/pyaudio.py -> build/lib.linux-x86_64-3.5
  running build_ext
  building '_portaudio' extension
  creating build/temp.linux-x86_64-3.5
  creating build/temp.linux-x86_64-3.5/src
  gcc -pthread -Wno-unused-result -Wsign-compare -DDYNAMIC_ANNOTATIONS_ENABLED=1 -DNDEBUG -O2 -g -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -fPIC -I/usr/include/python3.5m -c src/_portaudiomodule.c -o build/temp.linux-x86_64-3.5/src/_portaudiomodule.o
  src/_portaudiomodule.c:28:20: fatal error: Python.h: No such file or directory
   #include "Python.h"
  compilation terminated.
  error: command 'gcc' failed with exit status 1
  Failed building wheel for PyAudio
  Running setup.py clean for PyAudio
Failed to build PyAudio
Installing collected packages: PyAudio
  Running setup.py install for PyAudio ... error
    Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-wluo1gih/PyAudio/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-qqe1uvoj-record/install-record.txt --single-version-externally-managed --compile:
    running install
    running build
    running build_py
    creating build
    running build_ext
     #include "Python.h"
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-wluo1gih/PyAudio/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-qqe1uvoj-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-wluo1gih/PyAudio/
Nie wiem jak sobie z tym poradzić.
Ps:
Fedora 24, Python 3.5.2, pip 9.0.1
Ps:
Komunikat jest dość jasny "fatal error: Python.h: No such file or directory".
Musisz doinstalować python3-devel, nie wiem jak f24, ale w f25 pyaudio jest jest w repozytorium i nie trzeba samodzielnie kompilować.
Do postów doświadczonych kolegów dodam oczywistą radę - przed otwieraniem nowego (starego!!!) tematu należy wpisać w wyszukiwarce Google hasło "python.h". Najobszerniejsza dyskusja na ten temat jest w witrynie "http://stackoverflow.com/questions/21530577/fatal-error-python-h-no-such-file-or-directory".
Mam lepszy pomysł. Skoro Fedora 25 ma pyaudio zarówno dla py2 i py3, możesz też ściągnąć pakiet źródłowy ftp://ftp.icm.edu.pl/vol/rzm5/linux-fedora/linux/releases/25/Everything/source/tree/Packages/p/pyaudio-0.2.9-3.fc25.src.rpm i przebudować go u siebie. Unikniesz śmiecenia pipem w /usr/lib i będziesz miał też pewność, że wszystkie zależności są w porządku.
