Gość Napisano Luty 27, 2023 Zgłoszenie Share Napisano Luty 27, 2023 [alieno@alieno-pc ~]$ sudo journalctl|grep ntfs [sudo] hasło użytkownika alieno: lut 24 09:33:55 localhost-live packagekitd[1192]: Failed to get cache filename for ntfs-3g lut 24 09:33:55 localhost-live packagekitd[1192]: Failed to get cache filename for ntfs-3g-libs lut 24 09:33:55 localhost-live packagekitd[1192]: Failed to get cache filename for ntfsprogs lut 24 09:35:13 alieno-pc kernel: ntfs3: Max link count 4000 lut 24 09:35:13 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 24 09:35:13 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 24 09:35:13 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 24 09:35:13 alieno-pc ntfs-3g[3084]: Version 2022.5.17 integrated FUSE 28 lut 24 09:35:13 alieno-pc ntfs-3g[3084]: Mounted /dev/sdb1 (Read-Only, label "Dane", NTFS 3.1) lut 24 09:35:13 alieno-pc ntfs-3g[3084]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 24 09:35:13 alieno-pc ntfs-3g[3084]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 24 09:35:13 alieno-pc ntfs-3g[3084]: Global ownership and permissions enforced, configuration type 7 lut 24 09:50:23 alieno-pc ntfs-3g[3084]: Unmounting /dev/sdb1 (Dane) lut 24 10:08:32 alieno-pc kernel: ntfs3: Max link count 4000 lut 24 10:08:32 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 24 10:08:32 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 24 10:08:32 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 24 10:08:32 alieno-pc ntfs-3g[4281]: Version 2022.10.3 integrated FUSE 28 lut 24 10:08:32 alieno-pc ntfs-3g[4281]: Mounted /dev/sdb1 (Read-Only, label "Dane", NTFS 3.1) lut 24 10:08:32 alieno-pc ntfs-3g[4281]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 24 10:08:32 alieno-pc ntfs-3g[4281]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 24 10:08:32 alieno-pc ntfs-3g[4281]: Global ownership and permissions enforced, configuration type 7 lut 24 10:31:31 alieno-pc ntfs-3g[4281]: Unmounting /dev/sdb1 (Dane) lut 24 10:49:52 alieno-pc kernel: ntfs3: Max link count 4000 lut 24 10:49:52 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 24 10:49:52 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 24 10:49:52 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 24 10:49:52 alieno-pc ntfs-3g[2772]: Version 2022.10.3 integrated FUSE 28 lut 24 10:49:52 alieno-pc ntfs-3g[2772]: Mounted /dev/sdb2 (Read-Only, label "Muzyka", NTFS 3.1) lut 24 10:49:52 alieno-pc ntfs-3g[2772]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 24 10:49:52 alieno-pc ntfs-3g[2772]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb2,blkdev,blksize=4096 lut 24 10:49:52 alieno-pc ntfs-3g[2772]: Global ownership and permissions enforced, configuration type 7 lut 24 10:53:59 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 24 10:53:59 alieno-pc ntfs-3g[3184]: Version 2022.10.3 integrated FUSE 28 lut 24 10:53:59 alieno-pc ntfs-3g[3184]: Mounted /dev/sdb3 (Read-Only, label "Wideo", NTFS 3.1) lut 24 10:53:59 alieno-pc ntfs-3g[3184]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 24 10:53:59 alieno-pc ntfs-3g[3184]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb3,blkdev,blksize=4096 lut 24 10:53:59 alieno-pc ntfs-3g[3184]: Global ownership and permissions enforced, configuration type 7 lut 24 11:03:01 alieno-pc ntfs-3g[2772]: Unmounting /dev/sdb2 (Muzyka) lut 24 11:03:01 alieno-pc ntfs-3g[3184]: Unmounting /dev/sdb3 (Wideo) lut 24 11:08:49 alieno-pc sudo[2915]: alieno : TTY=pts/0 ; PWD=/home/alieno ; USER=root ; COMMAND=/usr/bin/dnf install ntfs-3g ntfsprogs lut 24 19:30:55 alieno-pc kernel: ntfs3: Max link count 4000 lut 24 19:30:55 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 24 19:30:55 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 24 19:30:55 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 24 19:30:55 alieno-pc ntfs-3g[2445]: Version 2022.10.3 integrated FUSE 28 lut 24 19:30:55 alieno-pc ntfs-3g[2445]: Mounted /dev/sdb1 (Read-Only, label "Dane", NTFS 3.1) lut 24 19:30:55 alieno-pc ntfs-3g[2445]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 24 19:30:55 alieno-pc ntfs-3g[2445]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 24 19:30:55 alieno-pc ntfs-3g[2445]: Global ownership and permissions enforced, configuration type 7 lut 24 20:01:09 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 24 20:01:09 alieno-pc ntfs-3g[5006]: Version 2022.10.3 integrated FUSE 28 lut 24 20:01:09 alieno-pc ntfs-3g[5006]: Mounted /dev/sdb2 (Read-Only, label "Muzyka", NTFS 3.1) lut 24 20:01:09 alieno-pc ntfs-3g[5006]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 24 20:01:09 alieno-pc ntfs-3g[5006]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb2,blkdev,blksize=4096 lut 24 20:01:09 alieno-pc ntfs-3g[5006]: Global ownership and permissions enforced, configuration type 7 lut 24 20:07:43 alieno-pc ntfs-3g[2445]: Unmounting /dev/sdb1 (Dane) lut 24 20:07:43 alieno-pc ntfs-3g[5006]: Unmounting /dev/sdb2 (Muzyka) lut 25 08:07:44 alieno-pc kernel: ntfs3: Max link count 4000 lut 25 08:07:44 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 25 08:07:44 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 25 08:07:44 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 08:07:45 alieno-pc ntfs-3g[2447]: Version 2022.10.3 integrated FUSE 28 lut 25 08:07:45 alieno-pc ntfs-3g[2447]: Mounted /dev/sdb1 (Read-Write, label "Dane", NTFS 3.1) lut 25 08:07:45 alieno-pc ntfs-3g[2447]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 08:07:45 alieno-pc ntfs-3g[2447]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 25 08:07:45 alieno-pc ntfs-3g[2447]: Global ownership and permissions enforced, configuration type 7 lut 25 08:08:00 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 08:08:00 alieno-pc ntfs-3g[2482]: Version 2022.10.3 integrated FUSE 28 lut 25 08:08:00 alieno-pc ntfs-3g[2482]: Mounted /dev/sdb2 (Read-Write, label "Muzyka", NTFS 3.1) lut 25 08:08:00 alieno-pc ntfs-3g[2482]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 08:08:00 alieno-pc ntfs-3g[2482]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb2,blkdev,blksize=4096 lut 25 08:08:00 alieno-pc ntfs-3g[2482]: Global ownership and permissions enforced, configuration type 7 lut 25 08:08:10 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 08:08:10 alieno-pc ntfs-3g[2519]: Version 2022.10.3 integrated FUSE 28 lut 25 08:08:10 alieno-pc ntfs-3g[2519]: Mounted /dev/sdb3 (Read-Write, label "Wideo", NTFS 3.1) lut 25 08:08:10 alieno-pc ntfs-3g[2519]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 08:08:10 alieno-pc ntfs-3g[2519]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb3,blkdev,blksize=4096 lut 25 08:08:10 alieno-pc ntfs-3g[2519]: Global ownership and permissions enforced, configuration type 7 lut 25 08:26:04 alieno-pc ntfs-3g[2519]: Unmounting /dev/sdb3 (Wideo) lut 25 08:26:04 alieno-pc ntfs-3g[2482]: Unmounting /dev/sdb2 (Muzyka) lut 25 08:26:04 alieno-pc ntfs-3g[2447]: Unmounting /dev/sdb1 (Dane) lut 25 09:55:38 alieno-pc kernel: ntfs3: Max link count 4000 lut 25 09:55:38 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 25 09:55:38 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 25 09:55:38 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 09:55:38 alieno-pc ntfs-3g[2500]: Version 2022.10.3 integrated FUSE 28 lut 25 09:55:38 alieno-pc ntfs-3g[2500]: Mounted /dev/sdb5 (Read-Only, label "Dane", NTFS 3.1) lut 25 09:55:38 alieno-pc ntfs-3g[2500]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 09:55:38 alieno-pc ntfs-3g[2500]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb5,blkdev,blksize=4096 lut 25 09:55:38 alieno-pc ntfs-3g[2500]: Global ownership and permissions enforced, configuration type 7 lut 25 09:56:11 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 09:56:11 alieno-pc ntfs-3g[2558]: Version 2022.10.3 integrated FUSE 28 lut 25 09:56:11 alieno-pc ntfs-3g[2558]: Mounted /dev/sdb6 (Read-Only, label "Muzyka", NTFS 3.1) lut 25 09:56:11 alieno-pc ntfs-3g[2558]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 09:56:11 alieno-pc ntfs-3g[2558]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb6,blkdev,blksize=4096 lut 25 09:56:11 alieno-pc ntfs-3g[2558]: Global ownership and permissions enforced, configuration type 7 lut 25 09:57:11 alieno-pc ntfs-3g[2558]: Unmounting /dev/sdb6 (Muzyka) lut 25 09:57:11 alieno-pc ntfs-3g[2500]: Unmounting /dev/sdb5 (Dane) lut 25 11:14:35 alieno-pc kernel: ntfs3: Max link count 4000 lut 25 11:14:35 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 25 11:14:35 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 25 11:14:35 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 11:14:35 alieno-pc ntfs-3g[2474]: Version 2022.10.3 integrated FUSE 28 lut 25 11:14:35 alieno-pc ntfs-3g[2474]: Mounted /dev/sda5 (Read-Only, label "Dane", NTFS 3.1) lut 25 11:14:35 alieno-pc ntfs-3g[2474]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 11:14:35 alieno-pc ntfs-3g[2474]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sda5,blkdev,blksize=4096 lut 25 11:14:35 alieno-pc ntfs-3g[2474]: Global ownership and permissions enforced, configuration type 7 lut 25 11:16:10 alieno-pc ntfs-3g[2474]: Unmounting /dev/sda5 (Dane) lut 25 11:26:03 alieno-pc kernel: ntfs3: Max link count 4000 lut 25 11:26:03 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 25 11:26:03 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 25 11:26:03 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 11:26:03 alieno-pc ntfs-3g[2449]: Version 2022.10.3 integrated FUSE 28 lut 25 11:26:03 alieno-pc ntfs-3g[2449]: Mounted /dev/sda5 (Read-Only, label "Dane", NTFS 3.1) lut 25 11:26:03 alieno-pc ntfs-3g[2449]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 11:26:03 alieno-pc ntfs-3g[2449]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sda5,blkdev,blksize=4096 lut 25 11:26:03 alieno-pc ntfs-3g[2449]: Global ownership and permissions enforced, configuration type 7 lut 25 11:35:35 alieno-pc ntfs-3g[2449]: Unmounting /dev/sda5 (Dane) lut 25 11:37:58 alieno-pc kernel: ntfs3: Max link count 4000 lut 25 11:37:58 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 25 11:37:58 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 25 11:37:58 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 11:37:58 alieno-pc ntfs-3g[2411]: Version 2022.10.3 integrated FUSE 28 lut 25 11:37:58 alieno-pc ntfs-3g[2411]: Mounted /dev/sdb5 (Read-Only, label "Dane", NTFS 3.1) lut 25 11:37:58 alieno-pc ntfs-3g[2411]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 11:37:58 alieno-pc ntfs-3g[2411]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb5,blkdev,blksize=4096 lut 25 11:37:58 alieno-pc ntfs-3g[2411]: Global ownership and permissions enforced, configuration type 7 lut 25 11:38:10 alieno-pc ntfs-3g[2411]: Unmounting /dev/sdb5 (Dane) lut 25 11:46:00 alieno-pc kernel: ntfs3: Max link count 4000 lut 25 11:46:00 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 25 11:46:00 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 25 11:46:00 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 11:46:00 alieno-pc ntfs-3g[2401]: Version 2022.10.3 integrated FUSE 28 lut 25 11:46:00 alieno-pc ntfs-3g[2401]: Mounted /dev/sdb5 (Read-Write, label "Dane", NTFS 3.1) lut 25 11:46:00 alieno-pc ntfs-3g[2401]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 11:46:00 alieno-pc ntfs-3g[2401]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb5,blkdev,blksize=4096 lut 25 11:46:00 alieno-pc ntfs-3g[2401]: Global ownership and permissions enforced, configuration type 7 lut 25 11:53:19 alieno-pc ntfs-3g[2401]: Unmounting /dev/sdb5 (Dane) lut 25 12:53:50 alieno-pc kernel: ntfs3: Max link count 4000 lut 25 12:53:50 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 25 12:53:50 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 25 12:53:50 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 12:53:51 alieno-pc ntfs-3g[2449]: Version 2022.10.3 integrated FUSE 28 lut 25 12:53:51 alieno-pc ntfs-3g[2449]: Mounted /dev/sdb1 (Read-Write, label "Dane", NTFS 3.1) lut 25 12:53:51 alieno-pc ntfs-3g[2449]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 12:53:51 alieno-pc ntfs-3g[2449]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 25 12:53:51 alieno-pc ntfs-3g[2449]: Global ownership and permissions enforced, configuration type 7 lut 25 12:54:03 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 12:54:04 alieno-pc ntfs-3g[2486]: Version 2022.10.3 integrated FUSE 28 lut 25 12:54:04 alieno-pc ntfs-3g[2486]: Mounted /dev/sdb2 (Read-Write, label "Muzyka", NTFS 3.1) lut 25 12:54:04 alieno-pc ntfs-3g[2486]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 12:54:04 alieno-pc ntfs-3g[2486]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb2,blkdev,blksize=4096 lut 25 12:54:04 alieno-pc ntfs-3g[2486]: Global ownership and permissions enforced, configuration type 7 lut 25 12:54:12 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 12:54:12 alieno-pc ntfs-3g[2529]: Version 2022.10.3 integrated FUSE 28 lut 25 12:54:12 alieno-pc ntfs-3g[2529]: Mounted /dev/sdb3 (Read-Write, label "Wideo", NTFS 3.1) lut 25 12:54:12 alieno-pc ntfs-3g[2529]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 12:54:12 alieno-pc ntfs-3g[2529]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb3,blkdev,blksize=4096 lut 25 12:54:12 alieno-pc ntfs-3g[2529]: Global ownership and permissions enforced, configuration type 7 lut 25 13:06:18 alieno-pc ntfs-3g[2449]: Unmounting /dev/sdb1 (Dane) lut 25 13:06:18 alieno-pc ntfs-3g[2486]: Unmounting /dev/sdb2 (Muzyka) lut 25 13:06:18 alieno-pc ntfs-3g[2529]: Unmounting /dev/sdb3 (Wideo) lut 25 19:35:35 alieno-pc kernel: ntfs3: Max link count 4000 lut 25 19:35:35 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 25 19:35:35 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 25 19:35:35 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 19:35:35 alieno-pc ntfs-3g[2507]: Version 2022.10.3 integrated FUSE 28 lut 25 19:35:35 alieno-pc ntfs-3g[2507]: Mounted /dev/sdb1 (Read-Only, label "Dane", NTFS 3.1) lut 25 19:35:35 alieno-pc ntfs-3g[2507]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 19:35:35 alieno-pc ntfs-3g[2507]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 25 19:35:35 alieno-pc ntfs-3g[2507]: Global ownership and permissions enforced, configuration type 7 lut 25 19:37:44 alieno-pc ntfs-3g[2507]: Unmounting /dev/sdb1 (Dane) lut 25 19:40:11 alieno-pc kernel: ntfs3: Max link count 4000 lut 25 19:40:11 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 25 19:40:11 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 25 19:40:11 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 19:40:11 alieno-pc ntfs-3g[2374]: Version 2022.10.3 integrated FUSE 28 lut 25 19:40:11 alieno-pc ntfs-3g[2374]: Mounted /dev/sdb1 (Read-Only, label "Dane", NTFS 3.1) lut 25 19:40:11 alieno-pc ntfs-3g[2374]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 19:40:11 alieno-pc ntfs-3g[2374]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 25 19:40:11 alieno-pc ntfs-3g[2374]: Global ownership and permissions enforced, configuration type 7 lut 25 19:40:39 alieno-pc ntfs-3g[2374]: Unmounting /dev/sdb1 (Dane) lut 25 19:42:26 alieno-pc kernel: ntfs3: Max link count 4000 lut 25 19:42:26 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 25 19:42:26 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 25 19:42:26 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 19:42:26 alieno-pc ntfs-3g[2416]: Version 2022.10.3 integrated FUSE 28 lut 25 19:42:26 alieno-pc ntfs-3g[2416]: Mounted /dev/sdb1 (Read-Only, label "Dane", NTFS 3.1) lut 25 19:42:26 alieno-pc ntfs-3g[2416]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 19:42:26 alieno-pc ntfs-3g[2416]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 25 19:42:26 alieno-pc ntfs-3g[2416]: Global ownership and permissions enforced, configuration type 7 lut 25 19:42:41 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 25 19:42:41 alieno-pc ntfs-3g[2467]: Version 2022.10.3 integrated FUSE 28 lut 25 19:42:41 alieno-pc ntfs-3g[2467]: Mounted /dev/sdb2 (Read-Only, label "Muzyka", NTFS 3.1) lut 25 19:42:41 alieno-pc ntfs-3g[2467]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 25 19:42:41 alieno-pc ntfs-3g[2467]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb2,blkdev,blksize=4096 lut 25 19:42:41 alieno-pc ntfs-3g[2467]: Global ownership and permissions enforced, configuration type 7 lut 25 19:54:18 alieno-pc ntfs-3g[2416]: Unmounting /dev/sdb1 (Dane) lut 25 19:54:19 alieno-pc ntfs-3g[2467]: Unmounting /dev/sdb2 (Muzyka) lut 26 08:56:54 alieno-pc kernel: ntfs3: Max link count 4000 lut 26 08:56:54 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 26 08:56:54 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 26 08:56:54 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 08:56:54 alieno-pc ntfs-3g[2468]: Version 2022.10.3 integrated FUSE 28 lut 26 08:56:54 alieno-pc ntfs-3g[2468]: Mounted /dev/sdb5 (Read-Only, label "Dane", NTFS 3.1) lut 26 08:56:54 alieno-pc ntfs-3g[2468]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 08:56:54 alieno-pc ntfs-3g[2468]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb5,blkdev,blksize=4096 lut 26 08:56:54 alieno-pc ntfs-3g[2468]: Global ownership and permissions enforced, configuration type 7 lut 26 08:57:18 alieno-pc ntfs-3g[2468]: Unmounting /dev/sdb5 (Dane) lut 26 08:59:52 alieno-pc kernel: ntfs3: Max link count 4000 lut 26 08:59:52 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 26 08:59:52 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 26 08:59:52 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 08:59:52 alieno-pc ntfs-3g[2438]: Version 2022.10.3 integrated FUSE 28 lut 26 08:59:52 alieno-pc ntfs-3g[2438]: Mounted /dev/sda5 (Read-Only, label "Dane", NTFS 3.1) lut 26 08:59:52 alieno-pc ntfs-3g[2438]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 08:59:52 alieno-pc ntfs-3g[2438]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sda5,blkdev,blksize=4096 lut 26 08:59:52 alieno-pc ntfs-3g[2438]: Global ownership and permissions enforced, configuration type 7 lut 26 09:00:13 alieno-pc ntfs-3g[2438]: Unmounting /dev/sda5 (Dane) lut 26 09:08:35 alieno-pc kernel: ntfs3: Max link count 4000 lut 26 09:08:35 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 26 09:08:35 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 26 09:08:35 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 09:08:35 alieno-pc ntfs-3g[2464]: Version 2022.10.3 integrated FUSE 28 lut 26 09:08:35 alieno-pc ntfs-3g[2464]: Mounted /dev/sdb5 (Read-Write, label "Dane", NTFS 3.1) lut 26 09:08:35 alieno-pc ntfs-3g[2464]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 09:08:35 alieno-pc ntfs-3g[2464]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb5,blkdev,blksize=4096 lut 26 09:08:35 alieno-pc ntfs-3g[2464]: Global ownership and permissions enforced, configuration type 7 lut 26 09:09:38 alieno-pc ntfs-3g[2464]: Unmounting /dev/sdb5 (Dane) lut 26 09:15:31 alieno-pc kernel: ntfs3: Max link count 4000 lut 26 09:15:31 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 26 09:15:31 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 26 09:15:31 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 09:15:31 alieno-pc ntfs-3g[2447]: Version 2022.10.3 integrated FUSE 28 lut 26 09:15:31 alieno-pc ntfs-3g[2447]: Mounted /dev/sdb1 (Read-Write, label "Dane", NTFS 3.1) lut 26 09:15:31 alieno-pc ntfs-3g[2447]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 09:15:31 alieno-pc ntfs-3g[2447]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 26 09:15:31 alieno-pc ntfs-3g[2447]: Global ownership and permissions enforced, configuration type 7 lut 26 09:15:41 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 09:15:41 alieno-pc ntfs-3g[2486]: Version 2022.10.3 integrated FUSE 28 lut 26 09:15:41 alieno-pc ntfs-3g[2486]: Mounted /dev/sdb2 (Read-Write, label "Muzyka", NTFS 3.1) lut 26 09:15:41 alieno-pc ntfs-3g[2486]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 09:15:41 alieno-pc ntfs-3g[2486]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb2,blkdev,blksize=4096 lut 26 09:15:41 alieno-pc ntfs-3g[2486]: Global ownership and permissions enforced, configuration type 7 lut 26 09:15:52 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 09:15:52 alieno-pc ntfs-3g[2520]: Version 2022.10.3 integrated FUSE 28 lut 26 09:15:52 alieno-pc ntfs-3g[2520]: Mounted /dev/sdb3 (Read-Write, label "Wideo", NTFS 3.1) lut 26 09:15:52 alieno-pc ntfs-3g[2520]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 09:15:52 alieno-pc ntfs-3g[2520]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb3,blkdev,blksize=4096 lut 26 09:15:52 alieno-pc ntfs-3g[2520]: Global ownership and permissions enforced, configuration type 7 lut 26 10:39:52 alieno-pc ntfs-3g[2520]: Unmounting /dev/sdb3 (Wideo) lut 26 10:39:52 alieno-pc ntfs-3g[2486]: Unmounting /dev/sdb2 (Muzyka) lut 26 10:39:52 alieno-pc ntfs-3g[2447]: Unmounting /dev/sdb1 (Dane) lut 26 10:41:09 alieno-pc kernel: ntfs3: Max link count 4000 lut 26 10:41:09 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 26 10:41:09 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 26 10:41:09 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 10:41:09 alieno-pc ntfs-3g[2430]: Version 2022.10.3 integrated FUSE 28 lut 26 10:41:09 alieno-pc ntfs-3g[2430]: Mounted /dev/sdb1 (Read-Write, label "Dane", NTFS 3.1) lut 26 10:41:09 alieno-pc ntfs-3g[2430]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 10:41:09 alieno-pc ntfs-3g[2430]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 26 10:41:09 alieno-pc ntfs-3g[2430]: Global ownership and permissions enforced, configuration type 7 lut 26 10:41:13 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 10:41:13 alieno-pc ntfs-3g[2462]: Version 2022.10.3 integrated FUSE 28 lut 26 10:41:13 alieno-pc ntfs-3g[2462]: Mounted /dev/sdb2 (Read-Write, label "Muzyka", NTFS 3.1) lut 26 10:41:13 alieno-pc ntfs-3g[2462]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 10:41:13 alieno-pc ntfs-3g[2462]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb2,blkdev,blksize=4096 lut 26 10:41:13 alieno-pc ntfs-3g[2462]: Global ownership and permissions enforced, configuration type 7 lut 26 10:41:19 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 10:41:19 alieno-pc ntfs-3g[2487]: Version 2022.10.3 integrated FUSE 28 lut 26 10:41:19 alieno-pc ntfs-3g[2487]: Mounted /dev/sdb3 (Read-Write, label "Wideo", NTFS 3.1) lut 26 10:41:19 alieno-pc ntfs-3g[2487]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 10:41:19 alieno-pc ntfs-3g[2487]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb3,blkdev,blksize=4096 lut 26 10:41:19 alieno-pc ntfs-3g[2487]: Global ownership and permissions enforced, configuration type 7 lut 26 12:28:40 alieno-pc ntfs-3g[2487]: Unmounting /dev/sdb3 (Wideo) lut 26 12:28:40 alieno-pc ntfs-3g[2462]: Unmounting /dev/sdb2 (Muzyka) lut 26 12:28:40 alieno-pc ntfs-3g[2430]: Unmounting /dev/sdb1 (Dane) lut 26 12:31:51 alieno-pc kernel: ntfs3: Max link count 4000 lut 26 12:31:51 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 26 12:31:51 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 26 12:31:51 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 12:31:51 alieno-pc ntfs-3g[2772]: Version 2022.10.3 integrated FUSE 28 lut 26 12:31:51 alieno-pc ntfs-3g[2772]: Mounted /dev/sdb3 (Read-Write, label "Wideo", NTFS 3.1) lut 26 12:31:51 alieno-pc ntfs-3g[2772]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 12:31:51 alieno-pc ntfs-3g[2772]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb3,blkdev,blksize=4096 lut 26 12:31:51 alieno-pc ntfs-3g[2772]: Global ownership and permissions enforced, configuration type 7 lut 26 13:34:31 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 13:34:31 alieno-pc ntfs-3g[5006]: Version 2022.10.3 integrated FUSE 28 lut 26 13:34:31 alieno-pc ntfs-3g[5006]: Mounted /dev/sdb1 (Read-Write, label "Dane", NTFS 3.1) lut 26 13:34:31 alieno-pc ntfs-3g[5006]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 13:34:31 alieno-pc ntfs-3g[5006]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 26 13:34:31 alieno-pc ntfs-3g[5006]: Global ownership and permissions enforced, configuration type 7 lut 26 15:01:05 alieno-pc ntfs-3g[2772]: Unmounting /dev/sdb3 (Wideo) lut 26 15:01:05 alieno-pc ntfs-3g[5006]: Unmounting /dev/sdb1 (Dane) lut 26 17:52:14 alieno-pc kernel: ntfs3: Max link count 4000 lut 26 17:52:14 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 26 17:52:14 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 26 17:52:14 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 17:52:14 alieno-pc ntfs-3g[2335]: Version 2022.10.3 integrated FUSE 28 lut 26 17:52:14 alieno-pc ntfs-3g[2335]: Mounted /dev/sdb1 (Read-Only, label "Dane", NTFS 3.1) lut 26 17:52:14 alieno-pc ntfs-3g[2335]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 17:52:14 alieno-pc ntfs-3g[2335]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 26 17:52:14 alieno-pc ntfs-3g[2335]: Global ownership and permissions enforced, configuration type 7 lut 26 17:52:39 alieno-pc ntfs-3g[2335]: Unmounting /dev/sdb1 (Dane) lut 26 17:54:42 alieno-pc kernel: ntfs3: Max link count 4000 lut 26 17:54:42 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 26 17:54:42 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 26 17:54:42 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 17:54:42 alieno-pc ntfs-3g[2330]: Version 2022.10.3 integrated FUSE 28 lut 26 17:54:42 alieno-pc ntfs-3g[2330]: Mounted /dev/sda1 (Read-Only, label "Dane", NTFS 3.1) lut 26 17:54:42 alieno-pc ntfs-3g[2330]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 17:54:42 alieno-pc ntfs-3g[2330]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sda1,blkdev,blksize=4096 lut 26 17:54:42 alieno-pc ntfs-3g[2330]: Global ownership and permissions enforced, configuration type 7 lut 26 17:55:36 alieno-pc ntfs-3g[2330]: Unmounting /dev/sda1 (Dane) lut 26 17:58:10 alieno-pc kernel: ntfs3: Max link count 4000 lut 26 17:58:10 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 26 17:58:10 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 26 17:58:10 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 17:58:10 alieno-pc ntfs-3g[2329]: Version 2022.10.3 integrated FUSE 28 lut 26 17:58:10 alieno-pc ntfs-3g[2329]: Mounted /dev/sdb1 (Read-Only, label "Dane", NTFS 3.1) lut 26 17:58:10 alieno-pc ntfs-3g[2329]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 17:58:10 alieno-pc ntfs-3g[2329]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 26 17:58:10 alieno-pc ntfs-3g[2329]: Global ownership and permissions enforced, configuration type 7 lut 26 18:43:20 alieno-pc ntfs-3g[2329]: Unmounting /dev/sdb1 (Dane) lut 26 19:55:49 alieno-pc kernel: ntfs3: Max link count 4000 lut 26 19:55:49 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 26 19:55:49 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 26 19:55:49 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 19:55:49 alieno-pc ntfs-3g[2344]: Version 2022.10.3 integrated FUSE 28 lut 26 19:55:49 alieno-pc ntfs-3g[2344]: Mounted /dev/sdb5 (Read-Only, label "Dane", NTFS 3.1) lut 26 19:55:49 alieno-pc ntfs-3g[2344]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 19:55:49 alieno-pc ntfs-3g[2344]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb5,blkdev,blksize=4096 lut 26 19:55:49 alieno-pc ntfs-3g[2344]: Global ownership and permissions enforced, configuration type 7 lut 26 19:56:07 alieno-pc ntfs-3g[2344]: Unmounting /dev/sdb5 (Dane) lut 26 19:58:32 alieno-pc kernel: ntfs3: Max link count 4000 lut 26 19:58:32 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 26 19:58:32 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 26 19:58:32 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 19:58:32 alieno-pc ntfs-3g[2406]: Version 2022.10.3 integrated FUSE 28 lut 26 19:58:32 alieno-pc ntfs-3g[2406]: Mounted /dev/sda5 (Read-Only, label "Dane", NTFS 3.1) lut 26 19:58:32 alieno-pc ntfs-3g[2406]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 19:58:32 alieno-pc ntfs-3g[2406]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sda5,blkdev,blksize=4096 lut 26 19:58:32 alieno-pc ntfs-3g[2406]: Global ownership and permissions enforced, configuration type 7 lut 26 19:58:51 alieno-pc ntfs-3g[2406]: Unmounting /dev/sda5 (Dane) lut 26 20:03:51 alieno-pc kernel: ntfs3: Max link count 4000 lut 26 20:03:51 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 26 20:03:51 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 26 20:03:51 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 20:03:51 alieno-pc ntfs-3g[2350]: Version 2022.10.3 integrated FUSE 28 lut 26 20:03:51 alieno-pc ntfs-3g[2350]: Mounted /dev/sdb5 (Read-Write, label "Dane", NTFS 3.1) lut 26 20:03:51 alieno-pc ntfs-3g[2350]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 20:03:51 alieno-pc ntfs-3g[2350]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb5,blkdev,blksize=4096 lut 26 20:03:51 alieno-pc ntfs-3g[2350]: Global ownership and permissions enforced, configuration type 7 lut 26 20:04:04 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 20:04:04 alieno-pc ntfs-3g[2464]: Version 2022.10.3 integrated FUSE 28 lut 26 20:04:04 alieno-pc ntfs-3g[2464]: Mounted /dev/sdb6 (Read-Write, label "Muzyka", NTFS 3.1) lut 26 20:04:04 alieno-pc ntfs-3g[2464]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 20:04:04 alieno-pc ntfs-3g[2464]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb6,blkdev,blksize=4096 lut 26 20:04:04 alieno-pc ntfs-3g[2464]: Global ownership and permissions enforced, configuration type 7 lut 26 20:04:14 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 26 20:04:14 alieno-pc ntfs-3g[2509]: Version 2022.10.3 integrated FUSE 28 lut 26 20:04:14 alieno-pc ntfs-3g[2509]: Mounted /dev/sdb7 (Read-Write, label "Wideo", NTFS 3.1) lut 26 20:04:14 alieno-pc ntfs-3g[2509]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 26 20:04:14 alieno-pc ntfs-3g[2509]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb7,blkdev,blksize=4096 lut 26 20:04:14 alieno-pc ntfs-3g[2509]: Global ownership and permissions enforced, configuration type 7 lut 26 20:52:35 alieno-pc ntfs-3g[2464]: Unmounting /dev/sdb6 (Muzyka) lut 26 20:52:35 alieno-pc ntfs-3g[2509]: Unmounting /dev/sdb7 (Wideo) lut 26 20:52:35 alieno-pc ntfs-3g[2350]: Unmounting /dev/sdb5 (Dane) lut 27 09:17:38 alieno-pc kernel: ntfs3: Max link count 4000 lut 27 09:17:38 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 27 09:17:38 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 27 09:17:38 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 27 09:17:38 alieno-pc ntfs-3g[2417]: Version 2022.10.3 integrated FUSE 28 lut 27 09:17:38 alieno-pc ntfs-3g[2417]: Mounted /dev/sdb5 (Read-Only, label "Dane", NTFS 3.1) lut 27 09:17:38 alieno-pc ntfs-3g[2417]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 27 09:17:38 alieno-pc ntfs-3g[2417]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,ro,default_permissions,fsname=/dev/sdb5,blkdev,blksize=4096 lut 27 09:17:38 alieno-pc ntfs-3g[2417]: Global ownership and permissions enforced, configuration type 7 lut 27 09:18:05 alieno-pc ntfs-3g[2417]: Unmounting /dev/sdb5 (Dane) lut 27 09:20:19 alieno-pc kernel: ntfs3: Max link count 4000 lut 27 09:20:19 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 27 09:20:19 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 27 09:20:19 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 27 09:20:19 alieno-pc ntfs-3g[2351]: Version 2022.10.3 integrated FUSE 28 lut 27 09:20:19 alieno-pc ntfs-3g[2351]: Mounted /dev/sdb5 (Read-Write, label "Dane", NTFS 3.1) lut 27 09:20:19 alieno-pc ntfs-3g[2351]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 27 09:20:19 alieno-pc ntfs-3g[2351]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb5,blkdev,blksize=4096 lut 27 09:20:19 alieno-pc ntfs-3g[2351]: Global ownership and permissions enforced, configuration type 7 lut 27 09:20:50 alieno-pc ntfs-3g[2351]: Unmounting /dev/sdb5 (Dane) lut 27 09:25:10 alieno-pc kernel: ntfs3: Max link count 4000 lut 27 09:25:10 alieno-pc kernel: ntfs3: Enabled Linux POSIX ACLs support lut 27 09:25:10 alieno-pc kernel: ntfs3: Read-only LZX/Xpress compression included lut 27 09:25:10 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 27 09:25:11 alieno-pc ntfs-3g[2371]: Version 2022.10.3 integrated FUSE 28 lut 27 09:25:11 alieno-pc ntfs-3g[2371]: Mounted /dev/sdb1 (Read-Write, label "Dane", NTFS 3.1) lut 27 09:25:11 alieno-pc ntfs-3g[2371]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 27 09:25:11 alieno-pc ntfs-3g[2371]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb1,blkdev,blksize=4096 lut 27 09:25:11 alieno-pc ntfs-3g[2371]: Global ownership and permissions enforced, configuration type 7 lut 27 09:25:22 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 27 09:25:22 alieno-pc ntfs-3g[2464]: Version 2022.10.3 integrated FUSE 28 lut 27 09:25:22 alieno-pc ntfs-3g[2464]: Mounted /dev/sdb2 (Read-Write, label "Muzyka", NTFS 3.1) lut 27 09:25:22 alieno-pc ntfs-3g[2464]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 27 09:25:22 alieno-pc ntfs-3g[2464]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb2,blkdev,blksize=4096 lut 27 09:25:22 alieno-pc ntfs-3g[2464]: Global ownership and permissions enforced, configuration type 7 lut 27 09:25:32 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names' lut 27 09:25:32 alieno-pc ntfs-3g[2499]: Version 2022.10.3 integrated FUSE 28 lut 27 09:25:32 alieno-pc ntfs-3g[2499]: Mounted /dev/sdb3 (Read-Write, label "Wideo", NTFS 3.1) lut 27 09:25:32 alieno-pc ntfs-3g[2499]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2 lut 27 09:25:32 alieno-pc ntfs-3g[2499]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sdb3,blkdev,blksize=4096 lut 27 09:25:32 alieno-pc ntfs-3g[2499]: Global ownership and permissions enforced, configuration type 7 [alieno@alieno-pc ~]$ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Luty 27, 2023 Zgłoszenie Share Napisano Luty 27, 2023 5 godzin temu, xarx napisał: Mounted /dev/sdb2 (Read-Write, label "Muzyka", NTFS 3.1) 5 godzin temu, xarx napisał: Mounted /dev/sdb1 (Read-Write, label "Dane", NTFS 3.1) Jak widać czasami system jest montowany w trybie do odczytu i zapisu 5 godzin temu, xarx napisał: Mounted /dev/sdb5 (Read-Only, label "Dane", NTFS 3.1) a czasami tylko do odczytu, prawdę mówiąc nie wiem czemu tak się dzieje. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Fedoras Napisano Marzec 4, 2023 Zgłoszenie Share Napisano Marzec 4, 2023 "lut 26 20:04:14 alieno-pc kernel: ntfs3: Unknown parameter 'windows_names'" ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SeeM Napisano Marzec 4, 2023 Zgłoszenie Share Napisano Marzec 4, 2023 W dniu 27.02.2023 o 15:14, sunrise napisał: Jak widać czasami system jest montowany w trybie do odczytu i zapisu a czasami tylko do odczytu, prawdę mówiąc nie wiem czemu tak się dzieje. Kiedyś, dawno i nie wiem, czy prawda. Ktoś mi pisał, że to zależy: czy system Windows poprawnie zamknie złoży system plików przy wyłączaniu systemu, czy nie. Jeżeli nie (co łatwo później poznać, kiedy przy starcie systemu uruchomi się scandisk) ntfs-3g ma kłopoty z zapisywaniem na takiej partycji. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Marzec 4, 2023 Zgłoszenie Share Napisano Marzec 4, 2023 31 minut temu, SeeM napisał: Kiedyś, dawno i nie wiem, czy prawda. Generalnie to prawda, jeżeli na partycji ntfs są błędy to ntf-3g zamontuje w trybie RO. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
