Fedora 12
greeg
No niestety w dalszym ciągu brakuje dźwięku. Po usunięciu Pulseaudio nadal nic nie gra.
Oto moje wyniki z lspci i lsmod
[root@localhost ~]# lsmod | grep snd
snd_cs4236             30520  0
snd_wss_lib            24292  1 snd_cs4236
snd_cmipci             32536  2
snd_opl3_lib           10012  2 snd_cs4236,snd_cmipci
snd_pcm                70960  3 snd_cs4236,snd_wss_lib,snd_cmipci
snd_timer              19504  3 snd_wss_lib,snd_opl3_lib,snd_pcm
snd_page_alloc          8572  2 snd_wss_lib,snd_pcm
snd_hwdep               7388  1 snd_opl3_lib
snd_mpu401              7244  0
snd_mpu401_uart         7456  3 snd_cs4236,snd_cmipci,snd_mpu401
snd_rawmidi            20700  1 snd_mpu401_uart
snd_seq_device          7080  2 snd_opl3_lib,snd_rawmidi
snd                    56420  15 snd_cs4236,snd_wss_lib,snd_cmipci,snd_opl3_lib,snd_pcm,snd_timer,snd_hwdep,snd_m
pu401,snd_mpu401_uart,snd_rawmidi,snd_seq_device
gameport               11112  3 snd_cmipci,ns558
soundcore               6160  1 snd
snd_cs4236             30520  0
snd_cmipci             32536  2
snd_mpu401              7244  0
[root@localhost ~]# lspci
00:00.0 Host bridge: VIA Technologies, Inc. VT8377 [KT400/KT600 AGP] Host Bridge (rev 80)
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237/VX700 PCI Bridge
00:0a.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 61)
00:0a.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 61)
00:0a.2 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 63)
00:0b.0 Multimedia audio controller: C-Media Electronics Inc CM8738 (rev 10)
00:0f.0 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.4 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 86)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237 ISA bridge [KT600/K8T800/K8T890 South]
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 78)
01:00.0 VGA compatible controller: nVidia Corporation NV34 [GeForce FX 5500] (rev a1)
[root@localhost ~]#
  • Odpowiedzi 68
  • Created
  • Ostatniej odpowiedzi
Top Posters In This Topic
Witam,
Jakby ktoś potrzebował zainstalować sterowniki do nvidii, to tu jest link: http://forums.fedoraforum.org/showthread.p...111#post1272111
Pozdrawiam,
Esail
Tak wiec udalo mi sie zainstalowac i uruchomic drivery nvidii na F12 x86_64.
Robilem wg linka wklejonego przeze mnie dwa posty powyzej. Byl jednak maly
problem. Dostawalem co prawda ekran logowania kdm'a ale po wpisaniu usera
i hasla x'y sie restartowaly. Problem stwarzal oczywicie SELinux. Po uzyciu
 setsebool -P allow_execstack 1
setsebool -P allow_execmem 1
moje KDE gra i buczy. Wycinek z glxinfo:
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 9600M GS/PCI/SSE2
OpenGL version string: 3.2.0 NVIDIA 190.36
OpenGL shading language version string: 1.50 NVIDIA via Cg compiler
Glxgears:
dariusz ~  $  glxgears
Running synchronized to the vertical refresh.  The framerate should be
approximately the same as the monitor refresh rate.
26996 frames in 5.0 seconds = 5399.049 FPS
27115 frames in 5.0 seconds = 5422.979 FPS
Esail.
Zainstalowałem 12 dziś na komputerze stacjonarnym, zero problemów. Problemy natomiast są z laptopem, podczas instalacji zanim ruszy anaconda "zawiesza się" (albo szuka i szuka i szuka... kto wie) podczas "detecting hardware". Podejrzewam że chodzi o to że szuka floppy - fedora 11 mi tak robiła i musiałem floppy dodać do blacklist - czy da się coś analogicznego zrobić dla instalatora?
ale z tego co się orientuję jedyne sterowniki wspierające Xorg 1.7 to 190.xx
Skąd te informacje? Jeśli to to prawda to będzie tragedia, bo wyszedł właśnie 190.42, czyli Release Candidate 190 i prawdopodobnie nie zostanie nic poprawione, a na mojej karcie nadal sterownik się wiesza i występuje mrowienie...
Zachęcony opiniami postanowiłem spróbować fedory 12 i mam problem z myszą ,kursor blokuje się na dole ekranu.Niby można go przesunąć po ekranie ,ale on co chwila wraca na dół, pomyślałem że to wina moich "ulubionych" sterowników nouveau więc wypróbowałem już dodanie do lini kernela
 nouveau.modeset=0
,także usunięcie pakietów z nouveau i instalacja sterów do nvidi z oficjalnej strony, niestety nie pomaga żadna z powyższych metod. Macie jakiś pomysł co zrobić aby okiełznać "mysza"
Jeśli chodzi o wyłączenie (całkowite) nouveau, to do pliku /etc/modprobe.d/blacklist-nouveau.conf wpisz linię
blacklist nouveau
Jeśli lsmod nadal będzie pokazywał że nouveau jest załadowany, to wykonaj
cp /boot/initramfs-$(uname -r).img /boot/initramfs-$(uname -r).img.old
mkinitrd -f /boot/initramfs-$(uname -r).img $(uname -r)
BTW. Wie ktoś dlaczego initramfs zamiast starego dobrego initrd?
