Fatal: Module Bt878 Not Found.
ALvarez
henryk@zefir ~]$ dmesg | tail
[ 74.016158] <3>13 00 38 ea 10 00 00 1e 00 00 00 fd 00 32 a0 1e ..8..........2..
[ 74.016164] <3>60 19 00 0a 20 20 20 20 20 20 00 ff ff ff ff ff `... ......
[ 74.016170] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 74.016176] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 74.016185]
[ 74.758765] fuse init (API version 7.14)
[ 74.824745] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
[ 74.825892] SELinux: initialized (dev fusectl, type fusectl), uses genfs_contexts
[ 2363.121067] bt878: Unknown parameter `card'
[ 3249.191810] bt878: Unknown parameter `card'
Tak, karta jest widoczna.
Z dmesg:
[ 13.409409] bttv: using 4 buffers with 2080k (520 pages) each for capture
[ 13.409451] bttv: Bt8xx card found (0).
[ 13.409481] bttv 0000:02:06.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 13.409731] bttv0: Bt878 (rev 17) at 0000:02:06.0, irq: 20, latency: 32, mmio: 0xfdcff000
[ 13.409760] bttv0: using: Prolink Pixelview PV-BT878P+9B (PlayTV Pro rev.9B FM+NICAM) [card=72,insmod option]
[ 13.409811] bttv0: gpio: en=00000000, out=00000000 in=00ffc0ff [init]
[ 13.409862] bttv0: tuner type=28
[ 13.460721] IR RC6 protocol handler initialized
[ 13.969353] IR JVC protocol handler initialized
[ 13.979893] IR Sony protocol handler initialized
[ 13.985950] tvaudio 3-0058: found tda9874a.
[ 13.985954] tvaudio 3-0058: tda9874h/a found @ 0xb0 (bt878 #0 [sw])
[ 13.995394] lirc_dev: IR Remote Control driver registered, major 250
[ 13.997554] IR LIRC bridge handler initialized
[ 14.004669] tuner 3-0061: chip found @ 0xc2 (bt878 #0 [sw])
[ 14.058568] tuner-simple 3-0061: creating new instance
[ 14.058573] tuner-simple 3-0061: type set to 28 (LG PAL_BG+FM (TPI8PSB01D))
[ 14.059454] bttv0: registered device video0
[ 14.059498] bttv0: registered device vbi0
[ 14.059535] bttv0: registered device radio0
[ 14.059567] bttv0: PLL: 28636363 => 35468950 .. ok
[ 14.133143] Registered IR keymap rc-pixelview
[ 14.133254] input: bttv IR (card=72) as /devices/pci0000:00/0000:00:14.4/0000:02:06.0/rc/rc0/input4
[ 14.133324] rc0: bttv IR (card=72) as /devices/pci0000:00/0000:00:14.4/0000:02:06.0/rc/rc0
po
su -c " modprobe bttv card=72 tuner=28"
przejscie do lini komend bez komunikatu.
po lsmod | grep bttv
bttv 96648 0
v4l2_common 6710 4 tuner,tvaudio,tda7432,bttv
videodev 60378 5 tuner,tvaudio,tda7432,bttv,v4l2_common
videobuf_dma_sg 7244 1 bttv
videobuf_core 13379 2 bttv,videobuf_dma_sg
btcx_risc 3086 1 bttv
rc_core 14291 9 rc_pixelview,ir_lirc_codec,ir_sony_decoder,ir_jvc_decoder,ir_rc6_decoder,bttv,ir_rc5_decoder,ir_nec_decoder
tveeprom 10185 1 bttv
i2c_algo_bit 4197 2 bttv,radeon
i2c_core 21552 13 tuner_simple,tuner,tvaudio,tda7432,bttv,v4l2_common,videodev,i2c_piix4,tveeprom,radeon,drm_kms_helper,drm,i2c_algo_bit
dmesg | grep bt878
Dla mnie jest to o tyle dziwne, ze ta karta z tymi parametrami pracuje na drugim dysku pod mandriva.
dmesg | grep bt878
Dla mnie jest to o tyle dziwne, że ta karta z tymi parametrami pracuje na drugim dysku pod mandrivą.
Ale te komunikaty to są z poprzednich operacji spójrz na czasy (te w nawiasach kwadratowych)
Dla mojej karty (inny model PixelView PlayTV) mam tak:
cat /etc/modprobe.d/bttv.conf
alias char-major-37 bttv
options bttv radio=1 card=37 tuner=5 gbuffers=4
options bttv card=37 pll=1 radio=1 tuner=5 gbuffers=4
Takie wpisy posiadam od dawna, być może ten alias nie jest już potrzebny i wystarczą same opcje. Opcje trzeba dobrać oczywiście dla Twojego modelu karty.
Nie będę bardzo zaprzeczał. Doszkoły chodziłem w czasach kiedy nalezało "rozumieć" czterech wielkich rewolucjonistów a wię proszę o wyrozumiałość.
To już nie moja epoka.
umnie config wygląda tak:
alias char-major-81 bttv
alias char-major-81 videodev
alias char-major-81-0 bttv
options bttv radio=1 card=72 tuner=28 gbuffers=4
