Virtualbox 4.1.6
ALvarez
Witam.
Przeczytalem opisy na forum ale w moim przypadku niewiele mi pomogly.
Zainstalowale VirtualBox 1.4.6
Zalozenie maszyny virtualnej "ubuntu", przy próbie uruchomienia komunikat:
1.Kernel driver not installed (rc=-1908)
The VirtualBox Linux kernel driver (vboxdrv) is either not loaded or there is a permission problem with /dev/vboxdrv. Please reinstall the kernel module by executing
'/etc/init.d/vboxdrv setup'
as root. If it is available in your distribution, you should install the DKMS package first. This package keeps track of Linux kernel changes and recompiles the vboxdrv kernel module if necessary.
uruchamiam bez dkms:
wynik:
Stopping VirtualBox kernel modules                         [  OK  ]
Uninstalling old VirtualBox DKMS kernel modules            [  OK  ]
Trying to register the VirtualBox kernel modules using DKMS[NIEUDANE]
 (Failed, trying without DKMS)
Recompiling VirtualBox kernel modules                      [NIEUDANE]
 (Look at /var/log/vbox-install.log to find out what went wrong)
wyniki:
w katalogu dev nie ma pliku vboxdrv
/var/log/vbox-install.log:
Makefile:172: *** Error: unable to find the sources of your current Linux kernel. Specify KERN_DIR=<directory> and run Make again. Stop.
uruchamiam z dkms:
Error! Your kernel source for kernel 2.6.35.14-103.fc14.i686.PAE cannot be found at
/lib/modules/2.6.35.14-103.fc14.i686.PAE/build or /lib/modules/2.6.35.14-103.fc14.i686.PAE/source.
                                                          [NIEUDANE]
Uninstalling modules from DKMS
 removing old DKMS module vboxhost version  4.1.4
Deleting module version: 4.1.4
completely from the DKMS tree.
Done.
Attempting to install using DKMS
Creating symlink /var/lib/dkms/vboxhost/4.1.6/source ->
                /usr/src/vboxhost-4.1.6
DKMS: add Completed.
You can use the --kernelsourcedir option to tell DKMS where it's located.
Failed to install using DKMS, attempting to install without
                                                          [NIEUDANE]
i wg mnie tu jest problem tylko nie wiem to znaczy chyba wiem/nie umiem go rozwiazac.
W wymienionym wyzej katalogu sa pliki build i source jako dowiazania do katalogu /usr/src/kernels/2.6.35.14-103.fc14.i686
W trybie rozpaczy dopisalem na koncu PAE i po vboxdrv setup w logu dkms_autoinstaller
vboxhost (4.1.6): Already installed on this kernel.
Restart kompa, uruchomienie VirtualBox OK, uruchomienie maszyny - ten sam komunikat co na poczatku.
Komunikat w boot.log:
Starting VirtualBox kernel modules [60G[[0;31mNIEUDANE[0;39m]
modprobe vboxdrv:
FATAL: Error inserting vboxdrv (/lib/modules/2.6.35.14-103.fc14.i686.PAE/extra/vboxdrv.ko): Invalid module format.
Przepraszam, wymiekam, moje widomosci ulegly wyczerpaniu.
Moze ma ktos dobry pomysl co z tym zrobic.
Juz dziekuje za pomoc.
Pozdrawiam.
ALvarez
Przepraszam, jak wyslalem to widze jaki jest balagan.
Edytowane przez WalDo
tagi "code"
Pokaz
uname -r
rpm -qa | grep kernel-devel
Inaczej to sie tutaj bedziemy 100 lat bawic.
[EDIT]
Z logów ewidentnie wynika, ze masz kernel-devel niedopasowany do kernel.
Sam piszesz o
a w logach jest o
Polecam
yum install kernel-devel-PAE
[/EDIT]
P.S. Zakladam, ze chodzi o VB 4.1.6 a nie 1.4.6? ;) Zmienie tytul, zeby nie mylil.
Stosuj znaczniki "code" a przy dlugich "wklejkach" znaczniki "codebox"
Witam.
Dziękuję WalDo za poprawki.
Poniżej to co mam zainstalowane.
yum list installed kernel\*
Wczytane wtyczki: langpacks, presto, refresh-packagekit
Adding pl_PL to language list
Zainstalowane pakiety
kernel-PAE.i686                     2.6.35.14-97.fc14                   @updates
kernel-PAE.i686                     2.6.35.14-100.fc14                  @updates
kernel-PAE.i686                     2.6.35.14-103.fc14                  @updates
kernel-devel.i686                   2.6.35.14-97.fc14                   @updates
kernel-devel.i686                   2.6.35.14-100.fc14                  @updates
kernel-devel.i686                   2.6.35.14-103.fc14                  @updates
kernel-doc.noarch                   2.6.35.14-103.fc14                  @updates
kernel-headers.i686                 2.6.35.14-103.fc14                  @updates
uname -r
kernel-devel-2.6.35.14-100.fc14.i686
kernel-devel-2.6.35.14-97.fc14.i686
kernel-devel-2.6.35.14-103.fc14.i686
A gdzie są właściwe kernele, nie ma ich ani na rpm.pbone.net ani na google.
Przeczytaj dokladnie co bylo napisane wczesniej. Pomylilem nieco nazwe pakietu
yum install kernel-PAE-devel
i to wszystko.
Jak masz kernel PAE, to i devele musisz brac dla PAE. Te wszystkie kernel-devel bez PAE mozesz usunac
yum remove kernel-devel\*
[EDIT]
A jak masz < 4GB RAM to mozesz sobie spokojnie zainstalowac zwykly 32-bitowy kernel, taki bez PAE
yum install kernel
Wielkie dzięki, działa, właśnie instaluje się Mageia.
Rozwiązanie było proste.
Tylko dlaczego to wszystko nie instaluje się domyślnie?
Jeszce raz wielkie dzięki.
Temat można uznać za wyczerpany.
Pozdrawiam.
ALvarez
Tylko dlaczego to wszystko nie instaluje sie domyslnie?
VirtualBox jest spoza repozytoriów wspieranych przez Fedore. Instalujac VirtualBox-OSE (z repo) unikasz tych problemów. Oczywiscie nie masz tez (przynajmniej kiedys tak bylo) obslugi USB ;)
Co do kernela: chciales zeby yum zainstalowal Ci kernel-devel, to zainstalowal. Kazales kernel-PAE-devel - masz. Nie win mlotka za to, ze uderzyles sie w palec przy wbijaniu gwozdzia.
BTW. Od dzisiaj mamy juz oficjalnie Fedore 16, wiec dla Fedory 14 konczy sie okres wsparcia, nie bedzie juz aktualizacji.
Witam.
Miałem zainstalowane VB-OSE fakt działało ok ale bez USB.
Chciałem mieć dostęp do USB.
Co do instalacji domyślnej. Jeżeli instalator przy instalacji systemu instaluje kernel PAE(domyślny jeżeli jest
odpowiedni hardware) to i reszta plików powinna być z tym zgodna.
Wg mnie dotyczy to również udate'u a znalezienie właściwych plików okazało się nieskuteczne.
Wydaje mi się, że miałem dobry kierunek działań aczkolwiek nie dokładny.
Dziękuję wszystkim za pomoc. Mageia już hula.
Pozdrawiam.
ALvarez
[...] to i reszta plików powinna byc z tym zgodna.
I jest :)
Wszelkie pliki *-devel to dosc specyficzna grupa. WYobraz sobie, ze ktos posiada tak jak Ty kernel PAE, ale chce przygotowac zwykly kernel. Musi jakos odróznic pakiet z naglówkami kernel-PAE od zwyklego kernel. Jeszcze raz: nie mlotek winien, tylko - w tym przypadku - brak pewnej dosc specyficznej wiedzy.
  • 1 year later...
A po co Ci kernel-PAE? Jak ktos napisze rm -rf / to tez wykonasz bez zastanowienia sie po co?
Pokaz
uname -r
rpm -qa | grep VirtualBox
[EDIT]
A tak w ogóle, to jesli instalowales z repozytorium to zainstalowal sie kmod i nie bedziesz mial etc/init.d/vboxdrv. Sprawdz czy masz zainstalowane moduly vbox
lsmod | grep vbox
Wklej tutaj wyniki wszystkich polecen oraz przekopiuj dokladnie komunikat bledu.
To nie jest do konca tak, ze bez zastanowienia instaluje wszystko co popadnie. Przy instalacji kierowalem sie poradnikiem na http://wiki.fedora.pl/wiki/VirtualBox, gdzie równiez wspominaja o tym pliku. Na innych forach w tym temacie równiez znalazlem taka informacje. Na koncu odwiedzilem nasze forum, gdzie zobaczylem iz ALvarez mial identyczny problem, równiez pisze o tym pliku a jednoczesnie nie wspomina nic o swojej konfiguracji (oprócz tego ze ma Fedore jako system). Dlatego nie wzbudzilo to moich podejrzen.
Wykonalem reinstalacje VB, która okazala sie wybawieniem z sytuacji i program juz dziala. Jednak postawiony na nim ubuntu 12.10 chodzi baaardzo wolno, nawet myszka na ekranie ma skoki.
Moje ustawienia:
  • dysk wirtualny 8gb
  • ram 1200mb
  • grafika 80mb
  • akceleracja 3d wlaczona
Zacinanie sie mnie zdziwilo, gdyz system odpalony z live-dvd chodzi plynnie - oczywiscie biorac pod uwage ze to live-dvd.
No i tu dochodzimy do sedna tematu chyba. Pierwsze zasadnicze pytanie, to czy instalacja tak jak napisales powyzej wykonala instalacje VB z repozytorium Oracle'a (opisane na wiki) czy z repozytorium Fedory RPM Fusion. Wydaje mi sie, ze
yum install VirtualBox
wykonuje instalacje z repo Fedory RPM Fusion natomiast
yum install ViertualBox-4.2
z repozytorium Oracle.
Przyspieszenie systemu-goscia uzyskasz po zainstalowaniu dodatków z VBoxGuestAdditions.iso (m.in. sterownik grafiki). Byc moze Ubuntu ma jakies swoje paczki w przypadku, gdy jest gosciem na maszynie wirtualnej i wtedy nie ma potrzeby kompilacji dodatków z tego obrazu *.iso - wystarczy instalacja pakietu. O szczególy musisz popytac na Ubuntu albo na forum VB.
[EDIT]
Z tym repo Fedory to oczywiscie przesadzilem. Chodzilo mi o RPM Fusion.
